Old 11th January 2020, 13:09   #5061  |  Link
stax76
stax76's Avatar
Yes, I tried negative pitch, causes a crash, height is defined as UINT32.
edit:
I can research if Direct2D can flip it faster.
stax76 is offline
Old 11th January 2020, 15:42   #5062  |  Link
it also invokes FlipVertical, no clue why AviSynth/VapourSynth RGB32 isn't directly D2D compatible without FlipVertical.
RGB is upside down compared to YUV, top line is usually got via something like
    int x=0,y=0;
    int step =( vi.IsRGB24() ) ? 3 : 4;    // RGB24 or RGB32
    BYTE *dp = dst->GetWritePtr() + ((height-1 - y) * pitch) + (x*step);
    dp -= pitch; // down 1 line
StainlessS is offline
Old 11th January 2020, 19:52   #5063  |  Link
stax76
stax76's Avatar
The pixel array is a block of 32-bit DWORDs, that describes the image pixel by pixel. Usually pixels are stored "bottom-up", starting in the lower left corner, going from left to right, and then row by row from the bottom to the top of the image.[4] Unless BITMAPCOREHEADER is used, uncompressed Windows bitmaps also can be stored from the top to bottom, when the Image Height value is negative.
https://en.wikipedia.org/wiki/BMP_fi...#Pixel_storage
I tried negative height in source and target rect and everywhere else where a height is defined and it's not working. On StackOverflow it's unanswered:
https://stackoverflow.com/questions/...textdrawbitmap
stax76 is offline
Old 12th January 2020, 08:18   #5064  |  Link
v0lt
Hello.
Now if I open the script in video players, I get the wrong colors in many situations.
Is it possible to use the structure VIDEOINFOHEADER2 instead of VIDEOINFOHEADER? This will make it possible to use the dwControlFlags field. If you set AMCONTROL_COLORINFO_PRESENT, you can use DXVA_ExtendedFormat to specify additional parameters (nominal range, transfer matrix) for the video stream.
v0lt is offline
Old 12th January 2020, 14:47   #5065  |  Link
V0lt,
What script ???
Here the script:
AviSource("h:\Tape 1\capture_1.avi")
converttoyv12(interlaced=true)
assumeTFF()
separatefields()
temporalsoften(4,4,8,10,mode=2)
fluxsmoothST(3,3)
weave()
assumefps(25)
It works when I put temporalsoften AFTER fluxsmooth.
Edit:
It also works when I put crop(2,0,-0,-0) before temporalsoften. (The frame then becomes 718x576).
Edit2:
It looks like temporalsoften must not be the first filter after separatefields()
Verified Access Violation with below script.
Colorbars(pixel_type="YV12")
#BilinearResize(720,576)
#converttoyv12(interlaced=true)
#assumeTFF()
separatefields()
#fluxsmoothST(3,3)
#weave()
#assumefps(25)
removing comments (Access Violation)
Colorbars(pixel_type="YV12")    # 640x480
separatefields()                # 640x240
EDIT: Avs+ v3.4.0
EDIT: No Access Violation
BlankClip(width=640,height=240,pixel_type="YV12")
AssumeFieldBased
EDIT: Also Access Violation
BlankClip(pixel_type="YV12")    # 640x480
AssumeFrameBased
Old 12th January 2020, 16:09   #5066  |  Link
v0lt
What script ???
ImageSource("1000px-SMPTE_Color_Bars_16x9.png")
AddBorders(0, 3, 0, 2)
ConvertToYUV420(matrix="Rec601")
# or
#ConvertToYUV420(matrix="Rec709")
# or
#ConvertToYUV420(matrix="Rec2020")
I get different colors on the player depending on the matrix parameter in the script. The video player is not able to find out what parameters were used when converting the frame from RGB to YV12.
v0lt is offline
Old 12th January 2020, 16:25   #5067  |  Link
poisondeathray
# or
# or
Avisynth frameserves uncompressed audio and video. No metadata is passed . Also, the video player does not "see" what is in the script; it only "sees" the final output as uncompressed video
How the video converts from YUV to RGB for display varies by the player, and renderer setup, sometimes drivers. Many assume Rec709 for height >576
poisondeathray is offline
Old 12th January 2020, 16:54   #5068  |  Link
There is no colorspace matrix info embedded in AVI.
I guess defaults are player dependant (I dont ever bother with such stuff).
Here looks like relevant for PotPlayer
EDIT: PDR beat me.
Old 13th January 2020, 15:48   #5069  |  Link
stax76
stax76's Avatar
A video player can't know what exactly a script does (at least not easily), it could however parse the script to find out some basic parameters like the original source file or even a matrix parameter, with regex that's not 100% reliable but fairly simple to do. VapourSynth maybe has better metadata capabilities.
stax76 is offline
Old 13th January 2020, 16:39   #5070  |  Link
v0lt
When AviSynth converts the color space from RGB to YUV, then another filter can find out which matrix was used for this?
v0lt is offline
Old 13th January 2020, 16:47   #5071  |  Link
poisondeathray
Not automatically .
You have to do it "manually" with something like colorbars or known colors. If you get back the original colors when you convert back to RGB (or very close, due to rounding errors , and RGB<=>YUV gamut errors, clipping) then it's the correct matrix
This is true for any RGB<=>YUV conversion with any program, not just avisynth
Old 13th January 2020, 17:08   #5072  |  Link
poisondeathray
It does... but it's pros/cons IMO . Easy to get burned if not careful
If file is tagged correctly, the source filters read and pass on various metadata as clip "props" or properites
All manipulations "automatically" assume or take on those values, unless otherwise specified . e.g. if you resize or RGB preview ,everything is done correctly as per the metadata. e.g. if file was interlaced, tagged interlaced, then the resizing and conversion to RGB will be done interlaced aware
If file was tagged correctly, great. Everything just works(TM)
If it's not, trouble. e.g. if you get file from somewhere else. e.g handbrake often tags incorrectly . eg. progressive PAL DVD's are tagged interlaced. You end up having to double check everything.
Old 14th January 2020, 15:59   #5073  |  Link
TheFluff
Excessively jovial fellow
BITMAPINFOHEADER and friends are old GDI stuff. D2D exclusively uses unsigned coordinates growing left to right, top to bottom. You're not supposed to use clever tricks like negative pitch or height anymore, presumably because these coordinates are getting increasingly abstract and they don't want you to think in terms of pointers and offsets anymore, even though it happens to make sense in the context of plain old RGB bitmaps. You don't really just push raw memory areas to the screen anymore anyway at this high of an API level - D2D supports UI scaling, for example.
Instead the intended way of doing it is manipulating how the input coordinates are mapped to the output coordinates by setting a transformation matrix on the render target using ID2D1RenderTarget::SetTransform().
D2D doesn't come with a vertical mirroring matrix convenience method (rotation around a point isn't the same thing), but you can just create your own 3x2 transform, like so:
0   -1
0    0
which should give you a vertical flip.
Avisynth predates D2D by over a decade, so that's sort of a silly question. Avisynth directly supports VfW and GDI, which is what was available at the time. VS on the other hand only supports packed RGB32 as a backwards compatibility thing, where the thing it's backwards compatible with is mostly Avisynth.
TheFluff is offline
Old 14th January 2020, 18:09   #5074  |  Link
stax76
stax76's Avatar
@TheFluff
Thanks for the hint, I will have to do some math research to understand it.
stax76 is offline
Old 14th January 2020, 18:57   #5075  |  Link
TheFluff
Here's a quick cheat sheet, first hit on duckduckgo: https://code-industry.net/masterpdfe...mation-matrix/
e: It's not really necessary to confuse yourself with cross products in this case if you don't want to. Basically what you're doing here is just multiplying horizontal coordinates (X axis) by 1 (top left of the matrix) and vertical coordinates (Y axis) by -1 (middle right of the matrix). This is effectively the same thing as setting a negative height, so the topmost row of pixels in the input becomes the bottom row in the output - a vertical flip, in other words.
TheFluff is offline
Old 15th January 2020, 16:30   #5076  |  Link
pinterf
Here the script:
assumeTFF()
separatefields()
fluxsmoothST(3,3)
weave()
assumefps(25)
Edit:
Edit2:
Happy New Year!
Temporalsoften bug is fixed. Changes are merged into main repository.
pinterf is offline
Old 15th January 2020, 17:39   #5077  |  Link
Sharc
Originally Posted by pinterf View Post
Happy New Year!
Happy New Year! Thank you for the fix
Sharc is offline
Old 15th January 2020, 23:19   #5078  |  Link
Cheers P, you are a sweetie.
Old 28th January 2020, 14:02   #5079  |  Link
qyot27
qyot27's Avatar
Test build
The hope with the above build is that you don't see/feel anything different from the most recent builds from the master branch (plus the fixes pinterf mentioned above, re: temporalsoften).
qyot27 is offline
Old 28th January 2020, 15:11   #5080  |  Link
pinterf
Originally Posted by qyot27 View Post
Test build
Thanks, there are other changes are in progress, mainly a long-time requested helper parameter for Expr - along with masktools. (real.finder)
Btw. as I have changed the test version to 3.4.1 instead of 3.5, scripts that were parsing VersionString to get the build number at the exact 17th position no longer worked. Aside from this fact, is there any other reason why the 3rd part of the version (BUGFIX_VERSION) was not included in AVS_FULLVERSION?
E.g. now it reports 3.4 even for 3.4.1?
I've done the modification to include this 3rd part in it but real.finder noted me the problem, so I temporarily reversed the change.
Anyway, I have included (not commited yet) a new IsVersionOrGreater function which is checking the current version against the given parameters (similar to a Windows API function)
e.g.
if IsVersionOrGreater(3, 4) or IsVersionOrGreater(3, 5, 8)
and results in true if the current version is equal or greater than the required one in the parameters.
pinterf is offline
