Old 12th May 2014, 11:18   #1001  |  Link
jpsdr
I have a little question.
Even if the answer seems to be "no", i just want to be sure.
Is it possible to make 5.1 FLAC with LameXP ?
Old 12th May 2014, 14:37   #1002  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Sure, why not?
LameXP is just a front-end, so if you feed it with a 5.1 source, it will send your 5.1 source to the FLAC encoder and thus create a 5.1 FLAC file.
Actually what is not currently possible is creating a Stereo or Mono FLAC file from a 5.1 channel source...
Old 12th May 2014, 16:46   #1003  |  Link
jpsdr
... Ok. Interesting, but i'll ask differently, to precisely explain what i have i mind, because i think you're not telepath, and so can't guess...
Is it possible with LameXP to create a 5.1 FLAC file from 6 wav files ?
If yes, how ?
Before asking, i've just take a look at the 'user manual'... very interesting... ^_^
Not found any clue in the FAQ.
Edit :
If i understand the links you can feed directly .dts, interesting to know.
Is it possible also to feed directly .dtshd ?
(But i think in this cases eac3to can also do it...)
What i truly want to know, it's if i have to decode a DTSHD-MA or a THD file into wave files, edit these files (cuting or anything), having finaly 6 new wave files, is it possible to use LameXP to create a 5.1 FLAC file from these ?
Old 12th May 2014, 16:54   #1004  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
In short, no!
But you can generate a 5.1Ch FLAC file from a 'single' 5.1(6)Ch PCM.wav file
Old 12th May 2014, 17:20   #1005  |  Link
LoRd_MuldeR
Software Developer
Nope. Currently each input file is considered a separate encoding job. So we have an 1:1 input file to output file mapping.
Nope. You either need to process the DTS file directly or combine your 1ch Wave files to a single 6ch file before processing them with LameXP.
Should be possible as long as MediaInfo can detect it and as long as Valdec (AC3Filter) can decompress it. Just give it a try
Old 13th May 2014, 11:01   #1006  |  Link
jpsdr
Ok, thanks for your answers.
Old 19th May 2014, 20:12   #1007  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.10 RC1:
Changes between v4.09 and v4.10 [unreleased]:
* Upgraded build environment to Microsoft Visual Studio 2013 with Update-2
* Updated Qt runtime libraries to v4.8.6 (2014-04-25), compiled with MSVC 12.0
* Updated Opus libraries v1.1.x and Opus-Tools v0.1.8 to latest Git Master (2014-04-13)
* Updated MediaInfo to v0.7.69 (2014-04-26), compiled with ICL 14.0 and MSVC 12.0
* Updated mpg123 decoder to v1.19.0 (2014-03-08), compiled with GCC 4.8.2
* Fixed a bug that could cause the cover artwork to be lost under certain circumstances
* Added command-line options to adjust the LameXP font size (see FAQ doc for details)
If you find any showstopper bugs, then please report NOW
Old 25th May 2014, 15:29   #1008  |  Link
Motenai Yoda
Motenai Yoda's Avatar
LoRd_MuldeR I notice now, but with Lame, on High Quality, q shouldn't be 2?
PHP Code:
LameXP v4.09 (Build #1524), compiled on 2014-01-26 at 18:20:04
C:/Users/xxx/AppData/Local/Temp/a24c3764c4bbc8e6/lxp_flac.exe ----o C:\Users\xxx\AppData\Local\Temp\a24c3764c4bbc8e6\c1440c995af24db9.wav "C:\xxx.flac"
flac 1.3.0Copyright (C2000-20092011-2013 Josh Coalson Xiph.Org Foundation
flac comes with ABSOLUTELY NO WARRANTY
This is free software, and you are
welcome to redistribute it under certain conditions
Type `flac' for details.
done
Exited with code: 0x0000
C:/Users/xxx/AppData/Local/Temp/a24c3764c4bbc8e6/lxp_sox.exe --i C:/Users/xxx/AppData/Local/Temp/a24c3764c4bbc8e6/c1440c995af24db9.wav
Input File : 'C:/Users/xxx/AppData/Local/Temp/a24c3764c4bbc8e6/c1440c995af24db9.wav'
Channels : 2
Sample Rate : 44100
Precision : 16-bit
Duration : 00:04:35.48 = 12148668 samples = 20661 CDDA sectors
File Size : 48.6M
Bit Rate : 1.41M
Sample Encoding: 16-bit Signed Integer PCM
C:/Users/xxx/AppData/Local/Temp/a24c3764c4bbc8e6/lxp_lame.exe --nohist -q 3 --abr 128 C:\Users\xxx\AppData\Local\Temp\a24c3764c4bbc8e6\c1440c995af24db9.wav "C:\xxx.mp3"
LAME 3.99.5 32bits (http://lame.sf.net)
CPU features: MMX (ASM used), SSE (ASM used), SSE2
Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
Encoding C:\Users\xxx\AppData\Local\Temp\a24c3764c4bbc8e6\c1440c995af24db9.wav
to C:\xxx.mp3
Encoding as 44.1 kHz j-stereo MPEG-1 Layer III (11x) average 128 kbps qval=3
Frame | CPU time/estim | REAL time/estim | play/CPU | ETA
Writing LAME Tag...done
ReplayGain: -7.9dB
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 25th May 2014, 17:06   #1009  |  Link
LoRd_MuldeR
Software Developer
Nope. The LAME default is "-q3" now, which also is the default in LameXP, aka "High Quality".
The LAME CLI help seems to be a bit outdated here (it claims the default is "-q5"), but you can see the up-to-date documentation here:
http://lame.cvs.sourceforge.net/view...etailed.html#q
Especially note that with the "new" VBR mode, which is the default since LAME 0.98, there are only three quality "levels" anyway:
-q 0 to -q 4	include all features of the other modes and additionally use the best search when applying Huffman coding.
-q 5 and -q 6	include all features of -q7, calculate and consider actual quantisation noise, and additionally enable subblock gain.
-q 7 to -q 9	This level uses a psymodel but does not calculate quantisation noise when encoding: it takes a quick guess.
For example: You can easily check with MediaInfo that any setting in the "-q0" to "-q4" range will actually result in "-q0"
Old 25th May 2014, 18:58   #1010  |  Link
Motenai Yoda
The LAME CLI help seems to be a bit outdated here, but you can see the up-to-date documentation here:
but -h still set -q 2
0.98 was relased years before this project began.
MediaInfo says
Formato                                 : MPEG Audio
Dimensione                              : 4,11MiB
Durata                                  : 4min 35s
Modo bitrate generale                   : Variabile
Bitrate totale                          : 125 Kbps
Compressore                             : LAME3.99r
Audio
Versione formato                        : Version 1
Profilo formato                         : Layer 3
Modo                                    : Joint stereo
Estensione modo                         : MS Stereo
Durata                                  : 4min 35s
Modalità bitrate                        : Variabile
Bitrate                                 : 128 Kbps
Canali                                  : 2 canali
Frequenza campionamento                 : 44,1 KHz
Modo compressione                       : Con perdita
Dimensione della traccia                : 4,11MiB (100%)
Impostazioni compressione               : -m j -V 4 -q 3 -lowpass 17 --abr 128
so for abr, cbr, and vbr_old q is the same as ever?
Old 25th May 2014, 19:27   #1011  |  Link
LoRd_MuldeR
Software Developer
Yes, I think so. Even though, to my understanding, setting "-q2" makes zero difference compared to the default.
At least for (new) VBR mode - which is what most users should be using most of the time.
Furthermore, since the default is "-q3" for all RC modes in current LAME, the default value in LameXP is consistent with LAME's default.
AFAIK, LAME v3.98 was released on July 4 2008 (changelog), while the first version of LameXP was released around 2004 (and used something like LAME v3.93).
Also I'm not quite sure how this is releated...
Yes, just as described in the documentation:
(Note that there are two separate tables)
Old 25th May 2014, 23:51   #1012  |  Link
Motenai Yoda
1- I'm an idiot.
2- why all this time only with the latest versions there was this change?
Those docs is somewhat ambiguous, for vbr_new table depict the various levels, but the table for other modes only describes the various degrees of q, but it's the same q as 3.97 and older...
but if -q 2 doesn't change anything for vbr_new, but does and is still recommended for the other modes, why not set -q 2 instead of -q 3 with high quality?
Old 26th May 2014, 00:23   #1013  |  Link
LoRd_MuldeR
Software Developer
Well, because originally the LameXP code had been written following LAME's command-line help:
-q <arg>        <arg> = 0...9.  Default  -q 5
                -q 0:  Highest quality, very slow
                -q 9:  Poor quality, but fast
-h              Same as -q 2.   Recommended.
-f              Same as -q 7.   Fast, ok quality
So, at some point in LAME history, LAME's default apparently was "-q5", though the developers recommended using "-q2" (aka "-h").
Consequently, back at that time, making "-q5" the default of LameXP didn't seem like a good idea, even though it was LAME's default. Therefore, I decided to have a "-q2" setting and make that the default (as recommended).
However when I revisited the LameXP code (and studied the LAME documentation) later, I noticed that the LAME command-line help is actually outdated!
Current LAME versions use "-q3" as default. And they make no difference between "-q0" and "-q4" for the default (new) VBR mode anyway. Hence I decided to make LameXP more consistent with up-to-date LAME.
I think the tables are quite clear. One is for everything except "new" VBR (which includes CBR, ABR and "old" VBR), and one is exclusively for "new" VBR.
(Yes, the table for the "old" modes also summarizes several values in a single row. But from the description it's clear they are not the same, e.g. "decreasing precision of parameters the further from -q 0")
Well, because "-q3" is LAME's default. And so I though that it might be a good idea to make LameXP's default consistent with LAME's default as well as the LAME documentation.
Also I certainly do not want to expose all the possible "-q" values in LameXP - especially because most of these values are actually the same with "new" VBR.
Consequently, I decided to break it down to only four distinct "quality" modes in LameXP: 0 (when speed doesn't matter), 3 (the LAME default setting), 7 (fast setting with "okay" quality) and 9 (when only speed matters).
This decision isn't fixed. But, up to now, nobody has ever complained or made a better suggestion
BTW: You are right that for the "new" VBR mode it doesn't matter whether we use "-q3" or "-q2", but for the other modes I wanted "-q3" to be the default. And if we have "-q3" already, I didn't want to have "-q2" too
Old 27th May 2014, 18:38   #1014  |  Link
porcupene
error when choosing overwrite
Maybe this needs to be addressed.
I'm doing flac to flac conversion. If I choose "Overwrite existing files" in the advanced options I get an error for each file, the originals are deleted and no files are converted. I just lose the original files.
This does not happen if I chose to save the converted files to a different folder. It seems the program first deletes the originals and then it tries to convert files that are no longer there.
It happens every time.
Version 4.09 final
Win7 64
porcupene is offline   Reply With Quote
Old 27th May 2014, 22:08   #1015  |  Link
LoRd_MuldeR
Software Developer
Version 4.09 final
Win7 64
Hi, porcupene.
If you run LameXP in "overwrite existing files" mode and the output file actually does exist already, then LameXP will try to delete that file. If successful, the output file can be saved to the location of the old/deleted file. Otherwise it can't. Now, if the file was successfully deleted, but the subsequent conversion fails, there won't be any file left, obviously. But the actual important question here is why your conversion has failed. So please post your log file...
Old 27th May 2014, 22:43   #1016  |  Link
porcupene
Here follows the error output:
Target output file already exists, going to delete existing file:
M:\BMF\1.flac
C:/Users/balaban/AppData/Local/Temp/c900e9a58ccecfa7/lxp_flac.exe -d -F -f -o C:\Users\balaban\AppData\Local\Temp\c900e9a58ccecfa7\a40358720d579be0.wav M:\BMF\1.flac
flac 1.3.0, Copyright (C) 2000-2009, 2011-2013 Josh Coalson & Xiph.Org Foundation
flac comes with ABSOLUTELY NO WARRANTY. This is free software, and you are
welcome to redistribute it under certain conditions. Type `flac' for details.
1.flac: ERROR while decoding metadata
state = FLAC__STREAM_DECODER_END_OF_STREAM
Exited with code: 0x0001
And for comparison the OK output for the same file once I switch to saving to a different folder.
C:/Users/balaban/AppData/Local/Temp/c900e9a58ccecfa7/lxp_flac.exe -d -F -f -o C:\Users\balaban\AppData\Local\Temp\c900e9a58ccecfa7\065b18cc3f56ed67.wav M:\BMF\1.flac
done
C:/Users/balaban/AppData/Local/Temp/c900e9a58ccecfa7/lxp_sox.exe --i C:/Users/balaban/AppData/Local/Temp/c900e9a58ccecfa7/065b18cc3f56ed67.wav
Input File : 'C:/Users/balaban/AppData/Local/Temp/c900e9a58ccecfa7/065b18cc3f56ed67.wav'
Channels : 2
Sample Rate : 44100
Precision : 16-bit
Duration : 00:05:33.69 = 14715876 samples = 25027 CDDA sectors
File Size : 58.9M
Bit Rate : 1.41M
C:/Users/balaban/AppData/Local/Temp/c900e9a58ccecfa7/lxp_flac.exe -8 --channel-map=none -T "xxxxxxxxxxxxxxxx" -T "artist=xxxxxxxxxxxxxx" -T "album=xxxxxxxxxxxxxxx" -T genre=Vocal -T "comment=Encoded with LameXP" -T date=1995 -T track=1 -f -o M:\BMF\BMA\1.flac C:\Users\balaban\AppData\Local\Temp\c900e9a58ccecfa7\065b18cc3f56ed67.wav
wrote 32676327 bytes, ratio=0.555
So does it delete the flac before converting to a temporary wav file?
Last edited by porcupene; 27th May 2014 at 22:45. Reason: Needed to add a question.
Old 28th May 2014, 02:25   #1017  |  Link
LoRd_MuldeR
Software Developer
So your first log clearly shows that FLAC failed in the decoding step. This indicates that you have a broken/unsupported input FLAC file.
Note that the target output file (and therefore the "overwrite" mode) does not effect this step at all! That's because the job didn't even get to the encoding step!
Strangely, in your second log, the 100% identical command has succeeded, apparently. So the input FLAC file must have changed in the meantime...
(Either that, or the phase of the moon )
Yes. Even before the encoding job is started.
Be aware that the input and output file are parameters of the encoding job, (passed in the constructor. So they are determined at the moment when the new job is about to be created.
In order to "overwrite", we must delete the existing file first. If, and only if, that succeeded, we can use the (no longer) existing file's path as the output file for the new job.
Old 28th May 2014, 06:57   #1018  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
The reason the second succeeded is because a wav file exists, but it's just a header with zero data. A new empty flac file may or may not exist, either way it signaled some sort of spurious success. That's computers for you. The only way to check would be to decode both and ensure they're the same length, which LameXp never does.
Overall, overwriting the original files seems more dangerous than it's worth. Don't do it unless you're so space limited that you have no choice. (Might be a good idea to call this out as dangerous in the UI, most people won't realize that.)
Old 28th May 2014, 13:09   #1019  |  Link
LoRd_MuldeR
Software Developer
Huh?
Note that each conversion job consists of (at least) two phases: The decoding phase and the encoding phase. We are talking about the decoding phase here. In this phase, LameXP will decode the original input file (a FLAC file in this case) to a temporary WAV file. This temporary WAV file will never exist before. LameXP generates a random file name in its TEMP directory for this purpose and even makes sure the file really does not exist yet. The "overwrite existing file" option has absolutely no effect in this phase! It does have an effect only on the final encoding phase (where LameXP encodes from the temporary WAV to the target output file), but we didn't even get to this point, in the case where the job failed.
And indeed, if you look at his two logs, you'll notice that both logs start with the exactly same FLAC decoding command (except for the randomly generated TEMP file name, of course). The "strange" thing is that the identical command has failed in his first log, but apparently has succeeded in the second log. In the first log, FLAC rejected his input file. In the second log it didn't. This can only mean the original input FLAC file has changed in the meantime. Either that, or FLAC has some strange bug that triggers depending on the phase of moon. Or some buggy anti-virus software has interfered with FLAC (wouldn't be the first time). But it's impossible to say from here...
(Just to make it clear: The "overwrite existing file" option does not touch the original input file at all. Instead, it overwrites the target output file, if such file happens to already exist in the selected output directory)
I perfectly agree with you. But the "overwrite existing file" option has been requested by users. It's not enabled by default. And there's a fat warning, when you select this option.
Old 29th May 2014, 07:08   #1020  |  Link
porcupene
Ok...
First ... if I'm annoying anyone with my silly error I'll stop
If not, here goes:
I use AVG and I disabled it temporarily, nothing changed.
It turns out it's not only FLAC but it happens also with mp3 and ogg (I suspect all the other encoders too). I know it's pointless to convert mp3 to mp3 but I just wanted to check the functionality.
So if I choose to save the files in the same folder and "Overwrite existing files" and do mp3 to mp3 or ogg to ogg conversion this happens:
M:\BMF\1.mp3
C:/Users/balaban/AppData/Local/Temp/af3619121cd06397/lxp_lame.exe --nohist -q 0 -V 0 -m s M:\BMF\1.mp3 M:\BMF\1.mp3
Input file and Output file are the same. Abort.
Exited with code: 0xFFFFFFFF
or for ogg:
M:\BMF\2.ogg
C:/Users/balaban/AppData/Local/Temp/af3619121cd06397/lxp_oggdec.exe -w C:\Users\balaban\AppData\Local\Temp\af3619121cd06397\fc2d59288aef2cda.wav M:\BMF\2.ogg
OggDec v1.9.7 (libVorbis 1.3.2), Compiled on: Dec 27 2010
Input M:\BMF\2.ogg does not appear to be an Ogg bitstream.
********** Done decoding all input files. **********
And here is the ok output once I choose to save to a different folder:
C:/Users/balaban/AppData/Local/Temp/af3619121cd06397/lxp_lame.exe --nohist -q 0 -V 0 -m s M:\BMF\1.mp3 M:\BMF\BMA\1.mp3
polyphase lowpass filter disabled
Encoding M:\BMF\1.mp3 to M:\BMF\BMA\1.mp3
Encoding as 44.1 kHz stereo MPEG-1 Layer III VBR(q=0)
ReplayGain: -4.3dB
and for ogg:
C:/Users/balaban/AppData/Local/Temp/af3619121cd06397/lxp_oggdec.exe -w C:\Users\balaban\AppData\Local\Temp\af3619121cd06397\1190288fb69d1bc3.wav M:\BMF\2.ogg
Encoder Version: 0
Serial Number: 18706
Bitstream is 2 channel, 44100Hz
Scale = 1.0000
Decoded length: 14004984 samples = 5:17 mins.
Encoded by: AO; aoTuV [20110424] (based on Xiph.Org's libVorbis)
Decoding: M:\BMF\2.ogg
C:/Users/balaban/AppData/Local/Temp/af3619121cd06397/lxp_oggenc2.exe -q 9 -o M:\BMF\BMA\2.ogg C:\Users\balaban\AppData\Local\Temp\af3619121cd06397\1190288fb69d1bc3.wav
Opening with wav module: WAV file reader
Encoding "C:\Users\balaban\AppData\Local\Temp\af3619121cd06397\1190288fb69d1bc3.wav" to
"M:\BMF\BMA\2.ogg"
at quality 9.00
Done encoding file "M:\BMF\BMA\2.ogg"
File length: 5m 17.0s
Elapsed time: 0m 08.0s
Rate: 39.6967
Average bitrate: 329.9 kb/s
I did read the warning the program gives if I choose "Overwrite existing files" but is says I will loose the original file not both
Far be it from me to criticize this great program which I have used a long time but could it not just first save the wav file to a temporary folder and then and only then check if the target file already exists so it can safely be deleted?
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis
