Old 23rd January 2020, 16:00   #29221  |  Link
jdobbs
BD Rebuilder v0.61.05
I have updated the first post of this thread with a link to the most recent version of BD-RB (v0.61.05). Changes for this release:
- Corrected an issue that could result in
  blocky or distorted display during FF or
  REW on full backups.
- Fixed an issue in which an imported source
  (very rarely) might not have its frame rate
  detected by MEDIAINFO.
- Added an "*" to the "HEVC" callout of the
  stream display for sources that have HDR and
  "**" for those that also have Dolby Vision.
- Changed the setting for adjustment/scan of
  MKV during import.  Should have been off by
  default instead of on.
- Updated prediction routines for CRF encodes
  to more accurately predict UHD output when
  CRF is selected.  Still needs testing.
- Updated TSMUXER4K to a more recent nightly
  release.
- Other minor corrections and cosmetic fixes.
Website: www.jdobbs.net
Old 23rd January 2020, 23:17   #29222  |  Link
FilipeAmadeuO
@jdobbs
The “Corrected an issue that could result in blocky or distorted display during FF or REW on full backups.”
was a TSmuxer ou BdRebuilder bug ?
Because with this last version the problem is fixed. And now UHD backup is perfect.
But before I had same issue using only Tsmuxer.
Now subtitles/audio in GUI replacement is what I miss
FilipeAmadeuO is offline   Reply With Quote
Old 27th January 2020, 13:49   #29223  |  Link
jdobbs
Originally Posted by FilipeAmadeuO View Post
@jdobbs
The one mentioned in the log was a BD Rebuilder bug. Not sure if there was another bug fixed in TSMUXER. If so, I wasn't aware of it.
Old 27th January 2020, 17:32   #29224  |  Link
Michi
BD-RB encodes 4K import without HDR in HDR. I tested this with a x264 4K mkv file.
Since 61.05 BD-RB uses higher bitrates than 35Mbit on UHD rebuilds. Is this normal?
For me this is a feature and not a bug.
Michi is online now   Reply With Quote
Old 27th January 2020, 19:01   #29225  |  Link
jdobbs
Yes. I originally left it at the maximum for a standard BD while I was testing it (to be safe). But, after some testing, I've now increased it since a UHD BD-25/50 has a higher maximum bitrate.
Just remember, though, that this is just the maximum bitrate (associated with peaks). The actual bitrate for VBR is typically much lower (unless the source is small enough that it reaches the maximum with the selected target).
Old 31st January 2020, 11:56   #29226  |  Link
Priapismic
Done.
Priapismic is offline   Reply With Quote
Old 31st January 2020, 20:34   #29227  |  Link
Michi
The crf encoded files are to big and the second pass crashed:
[01.31.20] BD Rebuilder v0.61.05
[14:14:12] Source:  DER_WILDE_PAZIFIK
  - Input BD size: 24,30 GB
  - Approximate total content: [00:56:24.305]
  - Target BD size: 8,01 GB
  - Windows Version: 6.2 [9200]
  - Quality: Highest (Very Slow), CRF
  - Decoding/Frame serving: FFMPEG
  - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[14:14:12] PHASE ONE, Encoding
 - [14:14:12] Processing: VID_00002 (1 of 3)
 - [14:14:12] Extracting A/V streams [VID_00002]
 - [14:14:19] Reencoding video [VID_00002]
   - Source Video: HEVC, 3840x2160
   - Rate/Length: 23,976fps, 888 frames
 - [14:14:19] Performing CRF Prediction...
   - Analyzing 20,70 30,95 32,15 31,55 31,25 31,10 31,03 31,06 31,08 31,07 31,07 31,07 31,07 31,07 31,07 31,07 31,07 31,07 31,07 31,07 [31,07]
 - [14:17:41] Encoding using constant rate factor.
 - [14:20:15] Video Encode complete
 - [14:20:15] Processing audio tracks
   - Track 4352 (deu): Keeping original audio
 - [14:20:15] Multiplexing M2TS
 - [14:20:19] Processing: VID_00003 (2 of 3)
 - [14:20:19] Extracting A/V streams [VID_00003]
 - [14:24:17] Reencoding video [VID_00003]
   - Rate/Length: 23,976fps, 75.083 frames
 - [14:24:17] Performing CRF Prediction...
   - Analyzing 20,70 22,70 21,70 21,20 20,95 20,83 20,76 20,73 20,72 20,72 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 20,73 [20,73]
 - [15:26:16] Encoding using constant rate factor.
   - Performing size-correcting second pass...
[20:19:03] - Failed video encode, aborted
Old 31st January 2020, 23:22   #29228  |  Link
jdobbs
Wow. I'm really confused as to how it could get caught using the same CRF value that many times during prediction??? I'll look at it.
Can you post your REBUILDER.INI file?
Old 31st January 2020, 23:31   #29229  |  Link
Michi
BD-Rebuilder.ini:
[Options]
VERSION=0.61.0.5
MODE=0
ENCODER_MENU=1
ENCODE_QUALITY=5
ONEPASS_ENCODING=2
AUTO_QUALITY=0
AUDIO_TO_KEEP=deu;gem;ger;
SUBS_TO_KEEP=deu;gem;ger;gmh;goh;gsw;
SD_CONVERT=0
OPEN_GOP=1
RESIZE_1080=0
DEINTERLACE=0
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=0
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=1
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=1
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
DGDECNV=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=66000
TARGET_SIZE=23200
AUTO_BURN=2
MOVIEONLY_TYPE=40
ALTCRF=18
ARCHIVE_265=1
ARCHIVE_AUDIO=100
ARCHIVE_CRF=16
ARCHIVE_ENABLE=1
ARCHIVE_LIMIT=1
ALT_TARGET=7800
ALTMETHOD=0
ALTAUTOCROP=0
QUICK_EXTRAS=0
OUTPUT_3D=0
RESIZE_1440=0
RESIZE_720=0
NEROAAC=0
SUPTITLE=0
IGNORE_3D=0
OUTPUT_SBS=0
ENCODER_MENU=1
HC_PROFILE=BEST
IMPORT_HEVC_INTACT=1
MIN_M2TS_SIZE=20
NEW_CRF_PREDICTION=1
MULTIPROCESS=0
THREADS=auto
BD5_SIZE=4520
BD9_SIZE=8200
BD25_SIZE=23200
QUALITY_ULTRA=1
FRIMSOURCE=0
ENCODER=0
DGDECIM=1
FRIM_SW_DECODE=1
FRIM_SW_ENCODE=1
PRIORITY_CLASS=1
IMPORT_THRESHOLD=15
QUICK_PLAY_THRESHOLD=10
MENU_AUTO_BACKGROUND=1
MENU_PLAY_SEQUENTIAL=0
MENU_START_WITH_MENU=1
DECODER=0
AUDIO_DRC=0
MENU_AUTO_DVDAUDIO=1
IMPORT_LIMIT_LANG=0
IMPORT_KEEP_PLAYALL=0
ALT_CRF_TARGET=4000
PGSTOSRT=0
UHD_MAXRATE=60000
UHD_VBV_BUFFER=60000
TWEAK_X265=--no-open-gop --no-sao --no-slow-firstpass --no-rskip --subme 4 --weightb --ctu 32
[Paths]
SOURCE_PATH=F:\4K\
WORKING_PATH=Q:\4K\
Old 2nd February 2020, 20:32   #29230  |  Link
jfcarbel
Programmer
Updating to latest build and been using NeroAAC in past due to quality, But wondering if this is still case. Is the built in one now just as good if not better?
Also building a new Ryzen 3900X system, is MULTIPROCESS setting even needed anymore as I seem to recall that both x264 and x265 and multi-threaded by default.
jfcarbel is offline   Reply With Quote
Old 2nd February 2020, 23:17   #29231  |  Link
BuddTX
JDobbs, I would also be interested in a future version of BD Rebuilder with NVEnc/NVEncC or similar nVidia GPU Hardware encoding for 4K/UHD x265 encoding.
I did a test with the evaluation version of CloneBD using x265 and NVEnc and it took about 30 minutes to make a MKV using the highest settings, whereas the same source took over a day using BD 61.05 and x265. this is NOT A COMPLAINT at all, I love BD Rebuilder! I am very appreciative of all you have done!
While I have an older PC (10 years old!), it is still a powerhouse, it is a 6 core Intel Xeon W3680 3.33 Ghz, 12 cores with hyperthreading, 24 gig of triple channel ram, and two SSD hard drives. The video card I have is a NVIDIA GeForce GTX 1050 TI. Still using W7 if that matters.
Thank you!
BuddTX is offline   Reply With Quote
Old 3rd February 2020, 16:15   #29232  |  Link
jdobbs
Thank you!
In order to build and test it I need to have an Nvidia card that supports it. Right now with donations virtually non-existent I have a hard time justifying the cost to myself. Not trying to jockey for donations, just stating the facts.
Old 3rd February 2020, 18:20   #29233  |  Link
cartman0208
If you don't mind missing some of the newer features like 8k and B-Frame support and 4k 4:4:4 and lossless support, I could send you my spare GTX960 ...
I just looked up shipping prices to US and its less than I feared
cartman0208 is offline   Reply With Quote
Old 3rd February 2020, 18:56   #29234  |  Link
MrVideo
MrVideo's Avatar
I think it needs to be a GTX-1050, or better, for HEVC hardware encoding support.
The GTX-1050 has the 2176p issue. AIUI, it needs to be a RTX-20xx to get 2160p support (a turing card).
My Total Eclipse 2017 Photos
Old 3rd February 2020, 19:04   #29235  |  Link
MrVideo
MrVideo's Avatar
Jdobbs: There is currently an unbranded GTX-1050 on E-bay for $80. I'll be happy to buy it and sent it to you. Just let me know right away before it goes away.
Old 3rd February 2020, 19:48   #29236  |  Link
cartman0208
Doesn't need to be a RTX... GTX1660 is also Turing (I've got one), but starts around $200
Old 3rd February 2020, 20:00   #29237  |  Link
jdobbs
I appreciate it. But I'll just wait until I can afford a Turing card. I want to be able to encode with B frames.
I'll probably end up buying one soon enough. My will power for frugality is pretty lame.
Old 3rd February 2020, 20:05   #29238  |  Link
jdobbs
Yeah. I was thinking about a GTX1660 or GTX1660 ti, and that's around the price point I've been seeing too. Have you done any HEVC encoding with it? Opinion?
Old 3rd February 2020, 20:27   #29239  |  Link
MrVideo
MrVideo's Avatar
How about I get you this one: http://www.ebay.com/itm/EVGA-GeForce...MAAOSwgiVeN0~T
Old 3rd February 2020, 20:28   #29240  |  Link
MrVideo
MrVideo's Avatar
Thanks for the update.
