20th May 2012, 19:49 | #11223 | Link | |
What I have to do now, is I encode them with Nero Recode at ridiculous bit rate of 4+ so that the chapters and such are encoded in each ep. Then I reEncode those files with Ripbot to get reasonable sized files. |
20th May 2012, 20:48 | #11224 | Link |
can you just separate each episode with dvd decrypter?
21st May 2012, 02:11 | #11226 | Link |
LOL!!! Just set DVD Decrypter to Vob ID instead of file ID for the file mode splitting options and poof. 7 Freaken Years I've been using this version of DVD Decrypter. OMG!! Thanks ATAK.
*update* An online tutorial suggests using ifo mode. I'll try that as well and see if it makes a diff. Problem. Ripbot doesn't like the files that are being produced. They look good to me and MPC plays each vob file fine, but ripbot gives this error; MPEG2Source : unable to load D2V file "C:\Temp\RipBot264temp\job19\job19.d2v" (C:\Temp\RipBot264temp\job19\getinfo.avs, line 2) Suggestions? Last edited by rc71; 21st May 2012 at 07:06. |
21st May 2012, 08:45 | #11227 | Link |
vob sample to www.mediafire.com please...
21st May 2012, 13:46 | #11228 | Link |
1.7.2 Beta Error
Getting a new error using the 1.7.2 Beta during distributed encoding. Example of the error and trying to type it in exactly, spaces included:
Exception EConvertError in module EncodingClient.exe at 00023F16. '192.168.9.7 -> [3.4%] 49/1441 frames, 3.89 fps, 5944 kbps, eta 0:05:57 ' is not a valid integer value. |
21st May 2012, 17:30 | #11229 | Link |
@rc71 When i rip episodes from dvd i use ifo mode and rip the pgc's i want one by one. It's important that you use a seperate subfolder for each episode otherwise they will be overwritten. That's the way i do it.
If you do it your way you must rename the "episode" files to VTS_01_1.VOB, VTS_02_1.VOB and so on. and if you want subtitles need to rename the .ifo to match the names of your vobs. So i believe it's easier to use the ifo way and create a few subdirectories for your episodes than rename a lot of files to get it to work properly. //Trayman |
21st May 2012, 23:28 | #11231 | Link | |
Hi, Atak The file 'EncodingClient.exe' failed for NOD32/ESET. Only the products 'ESET' accuses this problem. Message: Probably unknown NewHeur_PE Thanks! Last edited by jandor; 21st May 2012 at 23:37. |
22nd May 2012, 08:59 | #11233 | Link |
typical false alarm. dump your anti virus and just use less annoying mse
22nd May 2012, 15:02 | #11235 | Link | |
I trust in the archives of RipBot264... It was just an observation I made. Do not change the 'ESET Smart Security' by any other. Thanks! |
22nd May 2012, 16:14 | #11236 | Link | |
22nd May 2012, 16:17 | #11237 | Link |
Hi Atak
Strange issue with a FLV. It encodes for 2-3 seconds and then finishes without errors. I was wondering if it was just my rig of what. Thanks. 17mb http://jumbofiles.com/s4ar9dzbdtrj I would use MF, but I couldn't see how to upload. They've made some major changes. |
22nd May 2012, 16:19 | #11238 | Link |
Even though it's stated that DE now supports MKV, I can't seem to get mpg's to convert to mkv with DE...am I doing something wrong ???
I'm lovin' DE, when using 3 PC's, the Server is an i7 3930K, and the clients are an i7 980x & an i7 2600K (all overclocked), it's only taking about 20 - 30 minutes to do a conversion. |
23rd May 2012, 01:08 | #11239 | Link | |
Happen on all of them. Here some log: Code:
[JobSettings] VideoFile=D:\--= Complete =--\The.Grey.*** VideoCodec=h264 VideoWidth=1920 VideoHeight=800 VideoAspectRatio=1:1 VideoProfile=[HIGH 4.0] HD . Progressive SourceFPS=23.976 MovieFPS=23.976 FPSinGUI=23.976 SourceNumberOfFrames=168770 SourceMovieLength=7039.12245578912 CurrentMovieLength=7039.12245578912 SourceAudioLength=7039.02933333333 Frames=168770 Duration=1:57:19.122 Mode=2-Pass kbps=6739 AudioFile=E:\Temp\RipBot264temp\job1\1_audio_Undetermined.dts AudioFileSize=1327736908 AudioCodec=dts AudioBPS=1509750 AudioProfile=x.x C O P Y S T R E A M Frequency=48000 Channels=6 DurationAudio=1:57:19.029 AudioLength=7039.02933333333 Normalize=OFF AudioDelay=0 AudioLang=French [fre] Output=E:\BLURAY\The Grey 1080P FF DVD9.AVCHD Container=ts LockSize=1 Size=7425 Deinterlace=Do not deinterlace Crop=Do not crop CropTop=0 CropBottom=0 CropLeft=0 CropRight=0 Resize=HD-Full 1920x1080 [2,40:1] ResX=1920 ResY=800 Decimate=Do not decimate Colors=Do not change colors hue=0 sat=1 bright=0 cont=1 subtitles=Do not use subtitles subtitleFileSize=15161396 path= Denoise=Do not denoise DenoiseLumaNoise=0 DenoiseChromaNoise=0 AssumeFPS=Do not change Forced_Subtitles=3_subtitles_Undetermined_1080.sup Code:
General Complete name : D:\--= Complete =--\The.Grey.mkv Format : Matroska Format version : Version 2 File size : 9.83 GiB Duration : 1h 57mn Overall bit rate : 12.0 Mbps Writing application : mkvmerge v4.1.1 ('Bouncin' Back') built on Jul 3 2010 22:54:08 Writing library : libebml v1.0.0 + libmatroska v1.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 57mn Bit rate : 8 975 Kbps Width : 1 920 pixels Height : 800 pixels Display aspect ratio : 2.40:1 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.244 Stream size : 7.16 GiB (73%) Writing library : x264 core 122 r2184 5c85e0a Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=8975 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No Audio #1 ID : 2 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 1h 57mn Bit rate mode : Constant Bit rate : 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Stream size : 1.24 GiB (13%) Title : French DTS 1509Kbps Language : French Default : Yes Forced : No Audio #2 ID : 3 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 1h 57mn Bit rate mode : Constant Bit rate : 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Stream size : 1.24 GiB (13%) Title : English DTS 1509Kbps Language : English Default : Yes Forced : No Text #1 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : French Forced Language : French Default : Yes Forced : Yes Text #2 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : French Language : French Default : No Forced : No Menu 00:00:00.000 : en:00:00:00.000 00:07:03.298 : en:00:07:03.298 00:14:09.348 : en:00:14:09.348 00:24:31.303 : en:00:24:31.303 00:29:14.461 : en:00:29:14.461 00:35:25.999 : en:00:35:25.999 00:43:26.103 : en:00:43:26.103 00:50:53.092 : en:00:50:53.092 00:59:00.871 : en:00:59:00.871 01:04:02.547 : en:01:04:02.547 01:11:27.909 : en:01:11:27.909 01:17:54.837 : en:01:17:54.837 01:24:12.089 : en:01:24:12.089 01:33:29.771 : en:01:33:29.771 01:41:06.811 : en:01:41:06.811 01:49:18.719 : en:01:49:18.719 MediaInfo 0.7.51 (installed in windows).
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
23rd May 2012, 01:25 | #11240 | Link | |
Well while VOB id breaks down the whole DVD into ep, Ripbot doesn't like the files. Setting it to ifo mode creates one file at a time, but ripbot seems to work with it. Bit of a pain since you have to rip each ep manually. As for a sample, I'm a little lost. Don't know how to send a sample as the vobs are over a gig a piece and chopping them just starts getting complicated. |
