Old 5th June 2011, 20:32   #641  |  Link
Sirber
retired developer
Sirber's Avatar
Originally Posted by nanyatimz View Post
Siber-san, hmm I am experiencing error on encoding mkv codec from animetake(original sources around 300mb etc etc) when I encode it, some ffmpeg.exe error appears.. so how to solve this?
you could try updating ffmpeg:
http://ffmpeg.zeranoe.com/builds/ under "32-bit Builds (Shared)"
then extract it to: C:\Program Files (x86)\Bencos\ffmpeg_win32
Detritus Software
Sirber is offline   Reply With Quote
Old 5th June 2011, 22:44   #642  |  Link
nanyatimz
Thanks for the fast response sirber-san..
nanyatimz is offline   Reply With Quote
Old 5th June 2011, 22:56   #643  |  Link
nanyatimz
?? Hmm. still got an error even I did download the latest ffmpeg.. extracted it at bencos folder but still error..
Old 6th June 2011, 01:51   #644  |  Link
Sirber
retired developer
Sirber's Avatar
mmmm sorry man, nothing I can do. You could go to an older version of bencos. Newer ffmpeg versions seems to have troubles with malformed h264 stream.
Detritus Software
Old 6th June 2011, 16:26   #645  |  Link
Sirber
retired developer
Sirber's Avatar
new release: http://www.detritus.qc.ca/cms/?p=110
Detritus Software
Old 7th June 2011, 17:31   #646  |  Link
Alex_080
User of X264
i got same error with this new version.....it unable to encode *.mkv files(ffmpeg error)...but it can encode other video file like *.avi, *.flv but it shows audio error :No valid SBR configuration found
Alex_080 is offline   Reply With Quote
Old 7th June 2011, 17:35   #647  |  Link
Sirber
retired developer
Sirber's Avatar
your mkv has a h264 stream?
for audio what was your configuration (asked codec, bitrate) and the source (codec, bitrate)?
Detritus Software
Old 16th June 2011, 17:53   #648  |  Link
Mr901
Jerome in da house...
any way to add a text watermark with this program ?
cuz stax is giving me issues right now but this does the job, like so
applyrange(0,250,"Subtitle","my watermark here",5,5,0,99999,"Century",20)
Mr901 is offline   Reply With Quote
Old 16th June 2011, 18:04   #649  |  Link
Sirber
retired developer
Sirber's Avatar
Nope, bencos isn't using AVISynth. The source is fed to ffmpeg directly.
Detritus Software
Old 16th June 2011, 18:05   #650  |  Link
Mr901
Oh okay thanks.
Old 22nd August 2011, 03:19   #651  |  Link
MajorX
i got this error pls help,
C:\Program Files\Bencos\sox/sox.exe -S -V "C:\DOCUME~1\MAX\LOCALS~1\Temp/bencos/audio.wav" "C:\DOCUME~1\MAX\LOCALS~1\Temp/bencos/audio_sox.wav" remix -m 1v0.3254,3v0.2301,5v0.2818,6v0.1627 2v0.3254,3v0.2301,5v-0.1627,6v-0.2818 norm
C:\Program Files\Bencos\sox/sox.exe: SoX v14.3.1
C:\Program Files\Bencos\sox/sox.exe INFO formats: detected file format type `wav'
Input File : 'C:\DOCUME~1\MAX\LOCALS~1\Temp/bencos/audio.wav'
Channels : 2
Sample Rate : 48000
Precision : 16-bit
Duration : 00:00:50.18 = 2408448 samples ~ 3763.2 CDDA sectors
File Size : 9.63M
Bit Rate : 1.54M
Sample Encoding: 16-bit Signed Integer PCM
Endian Type : little
Reverse Nibbles: no
Reverse Bits : no
C:\Program Files\Bencos\sox/sox.exe INFO sox: Overwriting `C:\DOCUME~1\MAX\LOCALS~1\Temp/bencos/audio_sox.wav'
Output File : 'C:\DOCUME~1\MAX\LOCALS~1\Temp/bencos/audio_sox.wav'
Channels : 2
Sample Rate : 48000
Precision : 16-bit
Reverse Nibbles: no
Reverse Bits : no
Comment : 'Processed by SoX'
C:\Program Files\Bencos\sox/sox.exe FAIL remix: too few input channels
MajorX is offline   Reply With Quote
Old 22nd August 2011, 04:06   #652  |  Link
Sirber
retired developer
Sirber's Avatar
looks like bencos thinks your source is 6 channel, while sox thinks it's 2.
please post your issue here:http://code.google.com/p/bencos/issues/entry
as well as the infos of your source.
Detritus Software
Old 22nd August 2011, 08:18   #653  |  Link
MajorX
posted.
pls can add an option to use custom settings for encoding?
Old 22nd August 2011, 13:28   #654  |  Link
Sirber
retired developer
Sirber's Avatar
posted.
same link, create a new "feature request"
Detritus Software
Old 22nd August 2011, 18:17   #655  |  Link
MajorX
request added. Is this version of BENCOS GUI support multi threaded?
Old 22nd August 2011, 18:23   #656  |  Link
Sirber
retired developer
Sirber's Avatar
request added. Is this version of BENCOS support multi threaded encoding?
Well, ffmpeg does.
Detritus Software
Old 23rd August 2011, 03:33   #657  |  Link
MajorX
when i m encoding with 2-pass the 1st pass runs too slow than the 2nd pass...why? i use Medium present.
Old 29th August 2011, 23:04   #658  |  Link
Sirber
retired developer
Sirber's Avatar
mmm I'll verify the 1pass settings
http://code.google.com/p/bencos/issues/detail?id=44
Detritus Software
Old 30th August 2011, 02:58   #659  |  Link
Sirber
retired developer
Sirber's Avatar
I'm currently upgrading the GUI/encoder to be multi-threaded, so I might not fix bugs or update bencos for a little while.
http://code.google.com/p/bencos/sour...k/uencoder.pas
Detritus Software
Old 30th August 2011, 12:42   #660  |  Link
ckmox
nice and hope you succeed in it so that i can rest my little program named cyko
and btw if your taking up request once you finish multi-threading bencos then i suggest CRF encoding to be added and FLAC audio encoding with SoX
i know freepascal TProcess does not accept piping but here is a command line im using to encode FLAC audio to vorbis and downmix the channel to mono
sox input.flac -t wav -c 1 - | ffmpeg -i - -acodec libvorbis -aq -1.0 -y output.ogg
and also can you give an option to always encode audio to mono and quality base instead of bitrate? because the lower the audio channels the lower the file size you can get especially when your using quality base audio encoding
ckmox is offline   Reply With Quote
aac, bencos, gui, webm, x264
