Old 11th April 2016, 04:16   #2041  |  Link
Elegant
Originally Posted by LigH View Post
Does anyone provide binaries of plugins ported by VFR-maniac, but only linked as source repos on the plugins list (FFT3DFilter, ReduceFlicker, TNLMeans without OpenCL)?
I've been searching for this as well; it shouldn't be that bad to do it by hand though.
Elegant is offline   Reply With Quote
Old 11th April 2016, 23:14   #2042  |  Link
l33tmeatwad
l33tmeatwad's Avatar
Ask and ye shall receive:
FFT3DFilter
ReduceFlicker
TNLMeans
I only tested the x64 versions of each...
l33tmeatwad is offline   Reply With Quote
Old 11th April 2016, 23:23   #2043  |  Link
LigH
LigH's Avatar
A bunch of to you...
New German Gleitz board
Old 12th April 2016, 17:48   #2044  |  Link
littlepox
There is a bug in using Expr:
import vapoursynth as vs
import sys
core = vs.get_core()
core.max_cache_size=1000
a = "anysource.mkv"
src8 = core.lsmas.LWLibavSource(a,threads=1)
res = core.std.Expr(src8, ["128 x - 1 < 128 128 ?",""])
res.set_output()
the vapoursynth.dll shall crash.
However, once can just avoid it by using "x - 128 -1 > 128 128 ?"
Waiting for replies, thanks.
littlepox is offline   Reply With Quote
Old 12th April 2016, 19:48   #2045  |  Link
jackoneill
unsigned int
jackoneill's Avatar
import sys
a = "anysource.mkv"
res.set_output()
Fixed now. It affects expressions that use the ternary operator, where its first operand is an expression that begins with a constant.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 13th April 2016, 04:15   #2046  |  Link
littlepox
Thanks dude. So efficient.
Old 16th April 2016, 07:29   #2047  |  Link
BakaProxy
Just a thought I had recently but is it actually possible to use vpy within c++ without having to call python scripts snd whatnot. I'm talking about calling vpy functions and plugins from within the cpp project.
For example I have a cpp project that generates an image and I want to resize that image without fully making my own resize function, could I then call vpy's internal resize function to do the work or even call the nnedi3 plugin?
BakaProxy is offline   Reply With Quote
Old 16th April 2016, 09:02   #2048  |  Link
feisty2
I'm Siri
feisty2's Avatar
see
https://github.com/dubhater/vapoursy...141e8f874a1f87
feisty2 is offline   Reply With Quote
Old 16th April 2016, 09:05   #2049  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Yes, it's possible. You can build a filter graph in C/C++. Here is an example that happens to invoke the internal resizer: https://github.com/vapoursynth/vapou...svapour.c#L504 . For your particular case, you'll also need to implement a VapourSynth source filter in your application.
If it's only the internal resizer you want, you should use zimg directly. It has C and C++ APIs.
Old 18th April 2016, 18:16   #2050  |  Link
sofakng
Has anybody been able to cross-compile VapourSynth using Linux?
I'm trying to use MXE (M Cross Environment; mingw32-w64 toolchain builder) and it compiles mpv without any problems, but VapourSynth requires Python 3.4 and I'm stumped on how to properly compile the VapourSynth DLL...
sofakng is offline   Reply With Quote
Old 18th April 2016, 20:00   #2051  |  Link
jackoneill
unsigned int
jackoneill's Avatar
It has been done. There are some hoops to jump through.
Note that cross-compiling a 32 bit libvapoursynth produces a broken DLL. I didn't investigate, but I think it has to do with function decorations somehow.
You could try to cross-compile Python, but I found it easier to use the official win64 installer in Wine (even if it took a few hours to find the magic switch that made msiexec work).
So, assuming you will use the official Python installer, the configure command will look something like this:
./configure --host=x86_64-w64-mingw32 --disable-python-module --disable-plugins PYTHON3_CFLAGS='/path/to/Python3.h' PYTHON3_LIBS='-L/path/to/libpython3.dll -lpython3'
--disable-python-module because Python modules have to be compiled with the same compiler as libpython, so you'll have to use the Python module provided in the official VapourSynth installer.
--disable-plugins because I assume you won't need those.
PYTHON3_CFLAGS needs to be passed to please the configure script. Point it to the Python installation's "include" folder.
PYTHON3_LIBS is also needed to please the configure script. Point it to the Python installation's "DLLs" folder. Inside, you will need to rename Python3.dll to libpython3.dll because otherwise libtool refuses to acknowledge its existence. This means you'll also need to rename Python3.dll on the Windows machine where this thing will run.
Most unfortunately, you will receive a libvapoursynth-script-0.dll instead of vsscript.dll.
Don't use GCC 5.3.0 for this because its libstdc++ has a bug that makes wstring_convert unusable. This is a problem for VapourSynth. GCC 5.1.0 is okay.
If it's for mpv, I think you'll find it much easier to convince mpv's build system to use the vsscript.dll provided in the official VapourSynth installer, or the portable archive.
Old 18th April 2016, 20:55   #2052  |  Link
sofakng
Thanks a lot for the help. I ended up using dlltool to generate the lib files (for vapoursynth.dll and vsscript.dll) and I was able to get mpv compiled with vapoursynth supported. I still need to try it on my actual win32 machine so who knows if it will work but at least it compiled
Old 19th April 2016, 02:22   #2053  |  Link
sofakng
Sorry, but one more question.
Is there an installer for the 64-bit version of VapourSynth? It looks like VapourSynth-R32.exe only installs the 32-bit version.
Old 29th April 2016, 07:11   #2054  |  Link
speedyrazor
Hi, I am getting "VSPipe.exe has stopped working" when trying to process Quicktime Prores 4444 files. Here is the script:
core = vs.get_core(threads=4)
ret = core.lsmas.LibavSMASHSource(source=r"Prores_4444_HD_Test.mov")
ret = core.fmtc.resample (clip=ret, w=480, h=384, css="444", kernel="spline36")
ret = core.fmtc.matrix (clip=ret, mats="709", matd="601")
ret = core.fmtc.resample (clip=ret, css="420")
ret = core.fmtc.bitdepth (clip=ret, bits=10)
retFinal = ret
retFinal.set_output()
I am on the latest version of Vapoursynth (R32) and the latest version of LSMASHSource (r877). Here is the crash report:
Problem signature:
  Problem Event Name:	APPCRASH
  Application Name:	VSPipe.exe
  Application Version:	0.0.0.0
  Application Timestamp:	5707beaa
  Fault Module Name:	vslsmashsource.dll
  Fault Module Version:	0.0.0.0
  Fault Module Timestamp:	00000000
  Exception Code:	c0000005
  Exception Offset:	0000000000001c80
  OS Version:	6.2.9200.2.0.0.272.7
  Locale ID:	2057
  Additional Information 1:	a279
  Additional Information 2:	a279be6c627875dc7e1b7d38560dd807
  Additional Information 3:	750b
  Additional Information 4:	750b3a6db190a3b8cb8b4f7bce54513d
Am I doing something wrong, or is this a bug?
Kind regards.
speedyrazor is offline   Reply With Quote
Old 29th April 2016, 13:55   #2055  |  Link
stax76
stax76's Avatar
I've downloaded a YUV444P10 sample and got an VS error telling YUV444P10 is not supported by VFW module, could it be supported? I get this error not only with StaxRip and VirtualDub but also with MPC-BE which I thought does not use VFW.
Sample is from here:
https://www.arri.com/camera/amira/le...ample_footage/
Count                     : 334
Count of stream of this kind: 1
Kind of stream            : Video
Stream identifier         : 0
StreamOrder               : 0
Format                    : ProRes
Commercial name           : ProRes
Format version            : Version 1
Format profile            : 4444
Codec ID                  : ap4h
Codec ID/Url              : http://www.apple.com/quicktime/download/standalone.html
Codec                     : ap4h
Codec                     : ap4h
Codec/CC                  : ap4h
Duration                  : 10240
Duration                  : 10s 240ms
Duration                  : 00:00:10.240
Duration                  : 00:00:10:06
Duration                  : 00:00:10.240 (00:00:10:06)
Bit rate mode             : VBR
Bit rate mode             : Variable
Bit rate                  : 286246400
Bit rate                  : 286 Mbps
Width                     : 1920
Width                     : 1 920 pixels
Clean aperture width      : 1920
Clean aperture width      : 1 920 pixels
Height                    : 1080
Height                    : 1 080 pixels
Clean aperture height     : 1080
Clean aperture height     : 1 080 pixels
Pixel aspect ratio        : 1.000
Clean aperture pixel aspect ratio: 1.000
Display aspect ratio      : 1.778
Display aspect ratio      : 16:9
Clean aperture display aspect ratio: 1.778
Clean aperture display aspect ratio: 16:9
Rotation                  : 0.000
Frame rate mode           : CFR
Frame rate mode           : Constant
Frame rate                : 25.000
Frame rate                : 25.000 fps
Frame count               : 256
Chroma subsampling        : 4:4:4
Scan type                 : Progressive
Bits/(Pixel*Frame)        : 5.522
Delay                     : 10280
Delay                     : 10s 280ms
Delay                     : 10s 280ms
Delay                     : 10s 280ms
Delay                     : 00:00:10.280
Delay_Settings            : DropFrame=No / 24HourMax=Yes / IsVisual=No
Delay_DropFrame           : No
Delay, origin             : Container
Stream size               : 366395392
Stream size               : 349 MiB (97%)
Stream size               : 349.4 MiB
Proportion of this stream : 0.96949
Writing library           : Arnold & Richter Cine Technik
Language                  : en
Language                  : English
Language                  : English
Language                  : en
Language                  : eng
Language                  : en
Encoded date              : UTC 2014-07-02 09:44:35
Tagged date               : UTC 2014-07-02 09:44:45
colour_description_present: Yes
Color primaries           : BT.709
Transfer characteristics  : BT.709
Matrix coefficients       : BT.709
colour_description_present_Original: Yes
matrix_coefficients_Original: RGB
Old 29th April 2016, 14:03   #2056  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
The problem is that there is no fourcc to represent it that I know of. The closest are ms p010 or whatever it was called and v210 which are both 10bit but subsampled. Find me a fourcc that's actually supported in applications and I'll consider adding it.
Myrsloik is offline   Reply With Quote
Old 29th April 2016, 14:17   #2057  |  Link
stax76
stax76's Avatar
Who might help here, maybe the author of MediaInfo or VirtualDub?
Old 29th April 2016, 14:21   #2058  |  Link
stax76
stax76's Avatar
found something:
http://wiki.multimedia.cx/index.php?title=Apple_ProRes
Old 29th April 2016, 14:35   #2059  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by stax76 View Post
No, must be uncompressed formats obviously.
Old 29th April 2016, 15:05   #2060  |  Link
poisondeathray
YUV 444 10bit packed is known as "Y410", but it's not supported in ffmpeg as a pixel format .
https://msdn.microsoft.com/en-us/lib...px#_444formats
https://en.wikipedia.org/wiki/FFmpeg#Pixel_formats
It's also known as "v410" (analgous to "v210" for 10bit422) but 10bit444
https://www.mplayerhq.hu/DOCS/codecs-status.html
speed, vaporware, vapoursynth
