14th April 2015, 03:06 | #28922 | Link |
14th April 2015, 03:10 | #28923 | Link |
Troubleshooter
Did you right-click on install.bat and choose "Run as Administrator" when you ran it?
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. |
14th April 2015, 04:38 | #28924 | Link | |
x64 mpc-hc v1.7.8.152 + LAVFilters v0.64.0-51 + madVR v0.87.21 + Nvidia 350.12 + win 8.1 pro + GTX 970 working with windowed fullscreen. now reclock 1.8.8.4 not support x64. how to enable reclock on x64?? Last edited by khanmein; 14th April 2015 at 04:56. |
14th April 2015, 05:24 | #28925 | Link | ||
You can't. Last edited by ryrynz; 14th April 2015 at 05:28. |
14th April 2015, 09:54 | #28930 | Link | ||
The real question is, why do you mimic fullscreen playback by using windowed playback with borders? If you would either use real fullscreen or even fullscreen exclusive and your actual monitor has 1920x1080 resolution, then you wouldn't have to downscale. Quote:
14th April 2015, 11:47 | #28931 | Link |
Is there any new guides for 64 bit setup? It is nice to see this come, thankz for all u do. I have been using MPC-HC, haali, MadVR, lav video and ac3 audio. Direction, link to a 64 bit setup guide would be appreciated.
Regards |
14th April 2015, 12:03 | #28932 | Link | |
Madshi, I'm seeing some dithering on pure blacks when the trade quality option 'use DXVA chroma upscaling' is enabled when doing native DXVA decoding on my HD4000
giving some pixels what would be with the other chroma upscalers, 0,0,0 a value of 0,0,1. Might I suggest maybe that those use DXVA chroma options are not enabled by default? Because at least on Intel graphics the chroma upscaling is god awful nearest neighbor and the visual difference is night and day. Any chance of putting (not recommended) beside the nearest neighbor GPU setting BTW? Just so people stay clear of it if they don't know what they're doing? I do wonder if really that's even useful aside from some sort of testing. Also using nearest neighbor doesn't result in the black dithering color change even though it likely is the same sort of process. Quote:
Download MPC-HC x64, Download MadVR. Install both & enjoy. PS ditch Haali. Last edited by ryrynz; 14th April 2015 at 12:07. |
14th April 2015, 12:52 | #28934 | Link |
@Shayne
I've made a complete reinstall of MPC-HC, madVR and XYSubFilter in 64bit yesterday. Here some tips to help you : - Before deleting the previous version of madVR, be sure to backup the settings.bin and restore it in the new version ; - MPC-HC settings are stored in the registry and shared between the 32 and 64bit version, so no problem here. However, LAVFilters settings are not saved with MPC-HC. Make a backup of your LAVFilters settings.
iiyama prolite xb2483hsu 1080p60 Gamma=2.25 - Intel Core i3-2100 3.10GHz - AMD Radeon HD 6850, RGB 4:4:4 Full range - MPC-HC + XYSubFilter + madVR Last edited by Vyral; 14th April 2015 at 16:23. |
14th April 2015, 16:28 | #28936 | Link | |
mpc-hc(just turned 64bit)
14th April 2015, 17:47 | #28937 | Link |
Me too, W8.1, single R9 290X and latest stable driver. Also luma upscaling with NNEDI 3 seems to make the screen a little darker in exclusive mode. I'll try the 15.3 beta driver tomorrow to see whether it's gone or not
14th April 2015, 20:47 | #28939 | Link |
Currently using NVIDIA GTX690 with 350.12 WHQL driver. The NNEDI3 artifact issue seems to be fixed for 64-bit madVR. Did not test it yet with 32-bit.
Also I have some questions:
14th April 2015, 22:32 | #28940 | Link |
Oh, looks like this issue (http://bugs.madshi.net/view.php?id=250) is fixed in 350.12 WHQL. GTX 760, madVR x64.
