Old 15th April 2009, 19:27   #801  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Calmart, you really shock me One frame video and flipped video...
Let me do some check with a "1 frame" video sample like yours. About flipped video, you should ask in AviSynth section, because AVStoDVD does not add any instruction like that.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 17th April 2009, 20:10   #802  |  Link
MikeyBK
MikeyBK's Avatar
MrC,
perhaps I'm configuring AVStoDVD incorrectly for the audio encoding, but it seems to be choking while Aften is needed to encode the audio. The source is an m2ts of the In the Name of the King movie. I've tried three different times..using the original m2ts from the Bluray with DTS-HD audio, that m2ts remuxed with TSMuxer whilst downconverting that DTS-Master to DTS, and also a BD-Rebuilder output which was a BD-9 with 640 kbps AC3 audio. All three errored in Aften stating something about error allocating buffer? @ frame 0??
I should've saved a screenshot of the Aften command window, but thought it would show up in the AVStoDVD log, which it didn't...
Below is the latest log, not sure if you know what may be going wrong or what I may be misconfiguring.
I remember you mentioning to me how AVStoDVD is superior to ConvertXtoDVD which I normally use, and on this 2 hour 45 minute film I thought I'd give it a full encoding attempt.
The m2v produced by HCEnc does look far better than the ConvertX output... just if I can get AVStoDVD to get Aften to to worlk on the audio??
The version of Aften in BD-Rebuilder works fine on the m2ts fles regardless of which audio format as a source.
<4/17/2009 2:50:50 AM>
START PROCESS
DVD SETTINGS
DVD Titles number: 1
DVD Video Standard: NTSC
DVD Chapters Interval: 5 min
DVD Menu: Static DVD Menu
DVD Size: 4435/4435 MB (100%)
DVD Output Setup: DVD Folder
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Save Log file: Yes
Output Folder: C:\Documents and Settings\MBK SYS\My Documents\My Videos\test
TITLE 1 SOURCE FILES
Video: J:\FULL_BluRay\IN_NAME_OF_KING\BDMV\STREAM\00013.m2ts
Info: AVC - 0 kbps - 1920x1080 - DAR 1.778 - 23.976 fps - PPF - 2:42:10 hours - 233543 frames
Audio: J:\FULL_BluRay\IN_NAME_OF_KING\BDMV\STREAM\00013.m2ts
Info: DTS-HD - 0 kbps - VBR - 48000Hz - 6ch - 2:42:20 hours
Subs:
[MediaInfoLib - v0.7.10]
AVISYNTH SCRIPT
Import("C:\Documents and Settings\MBK SYS\My Documents\Downloaded Files\AVStoDVD_214_NoInstall\Lib\A2DSource.avsi")
Video = A2DVideoSource("J:\FULL_BluRay\IN_NAME_OF_KING\BDMV\STREAM\00013.m2ts", CacheFolder = "C:\DOCUME~1\MBKSYS~1\LOCALS~1\Temp")
Video = Video.ConvertToYV12
#Using DGPulldown to upsize FPS
Video = Video.Lanczos4Resize(720,480)
Audio = GetChannel(A2DAudioSource("J:\FULL_BluRay\IN_NAME_OF_KING\BDMV\STREAM\00013.m2ts", CacheFolder = "C:\DOCUME~1\MBKSYS~1\LOCALS~1\Temp"), 1, 3, 2, 5, 6, 4)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 4068.2 MB
HCenc Parameters: -ini "C:\DOCUME~1\MBKSYS~1\LOCALS~1\Temp\00013_0_Title_01.HCenc.ini"
HCenc ini file:
*INFILE C:\DOCUME~1\MBKSYS~1\LOCALS~1\Temp\00013_0_Title_01.avs
*AVSRELOAD
*OUTFILE C:\Documents and Settings\MBK SYS\My Documents\My Videos\test\00013_0_Title_01.m2v
*LOGFILE C:\DOCUME~1\MBKSYS~1\LOCALS~1\Temp\00013_0_Title_01.HCenc.log
*MAXBITRATE 9000
*BITRATE 3507
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 40
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<4/17/2009 6:32:34 AM>
END VIDEO ENCODING OPERATIONS
Created File: C:\Documents and Settings\MBK SYS\My Documents\My Videos\test\00013_0_Title_01.m2v (4073.4 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3567 kbps - 720x480 - DAR 1.778 - 23.976 fps - PPF - 2:42:10 hours - 233293 frames
<4/17/2009 6:42:02 AM>
END PULLDOWN OPERATIONS
DGPulldown executed on File: C:\Documents and Settings\MBK SYS\My Documents\My Videos\test\00013_0_Title_01.m2v (4073.4 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3564 kbps - 720x480 - DAR 1.778 - 29.97 fps - PPF - 2:42:19 hours - 291906 frames
START AUDIO ENCODING OPERATIONS
Wavi (WAV) Parameters: "C:\DOCUME~1\MBKSYS~1\LOCALS~1\Temp\00013_0_Title_01.avs" "C:\DOCUME~1\MBKSYS~1\LOCALS~1\Temp\00013_0_Title_01.wav"
Aften (AC3) Parameters: -b 192 "C:\DOCUME~1\MBKSYS~1\LOCALS~1\Temp\00013_0_Title_01.wav" "C:\Documents and Settings\MBK SYS\My Documents\My Videos\test\00013_0_Title_01.ac3"
MBK
MikeyBK is offline   Reply With Quote
Old 17th April 2009, 22:11   #803  |  Link
gizzin
Has anyone noticed any stuttering during the first 5mins when re-encoding mkvs to dvd? Its a very slight stuttering but its really noticeable when the camera is moving.
gizzin is offline   Reply With Quote
Old 18th April 2009, 14:29   #804  |  Link
MikeyBK
MikeyBK's Avatar
Originally Posted by MikeyBK View Post
MrC,
START PROCESS
DVD SETTINGS
Save Log file: Yes
Subs:
AVISYNTH SCRIPT
HCenc ini file:
*AVSRELOAD
*MAXBITRATE 9000
*BITRATE 3507
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 40
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
No worries...... I just used the AVStoDVD/HCEnc generated m2v, muxed it with the AC3, and then used DVDStyler to produce a DVD manually.... turned out incredible...
thanks anyways but it appears that I won't need your help afterall to make a nice DVD version of this long BD movie 'In the Name of the King'.... ConvertXtoDVD does a fine job on shorter movies....
Would have been nice if AVStoDVD worked for me all the way thru though, because it would be a lot easier to use...
maybe I'll give it another try down the line, but it really sucks when it runs for 4 hours using HCEnc then chokes with aften...
MBK
Old 18th April 2009, 18:00   #805  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@MikeyBK
Be careful when muxing the AC3 output from BD: you said that its bitrate is 640 kbps, which is not DVD-compliant (max is 448 kbps). For max compliance you should re-encode audio @ 448 kbps.
Before starting an AVStoDVD project, mainly if it could be last for a long time, it is always better to run the Preview Clip section. For example, if you have not correctly configured your directshow audio mixer (i.e. ffdshow), then an AviSynth error message will be prompted. That could be a reason of Aften crashing in AVStoDVD.
Bye
MrC
AVStoDVD Homepage
Old 18th April 2009, 22:38   #806  |  Link
MikeyBK
MikeyBK's Avatar
Originally Posted by MrC View Post
@MikeyBK
Bye
Thanks for the info MrC...
I'm currently now trying it with 448 kbps AC3 in that m2ts... will let you know if that was it.
As for the audio mixer in FFDSHOW, it is set how it came as default. Do I need to configure it differently for aften to work with AVStoDVD?
Aften in BD-RB doesn't seem to have any issues with any of the audios for me?
MBK
Old 19th April 2009, 01:54   #807  |  Link
MikeyBK
MikeyBK's Avatar
@MikeyBK
Kudos to you MrC! You pinpointed the problem pretty well. It ran perfectly once I had the AC3 audio encoded to 448 kbps in the input m2ts file.
And the results are absolutely fantabulous..:thumbsup: Incredible PQ.
Thanks for a great app.... will recommend it to all...
MBK
Old 19th April 2009, 10:15   #808  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Nice to hear you fix it!
About ffdshow audio mixer, best setting (I do not remember if it is the default setting) is "same as input". So you can forget to switch between 1.0, 2.0 and 5.1.
Bye
MrC
AVStoDVD Homepage
Old 25th April 2009, 11:00   #809  |  Link
carlmart
Carlos Martinez
I am trying to process an m2v file and make it smaller through AVStoDVD, and I am getting an upside down image.
This is not the first time I get this upside image with this program. On other times it did show an upside image when previewing title output, but the final output was fine.
This time is the opposite: the preview looks fine, but the output is upside down.
The log file is this:
<25/04/2009 0:03:59>
START PROCESS
DVD SETTINGS
DVD Size: 4143/4435 MB (93%)
DVD Output Setup: MPEG2 Streams
Save Log file: Yes
Output Folder: C:\tmp
Video: D:\---\---.m2v
Info: MPEG-2 Video - 5584 kbps - 720x480 - DAR 1,778 - 29,97 fps - PPF - 1:58:11 hours - 212543 frames
Audio:
Info:
Subs:
[MediaInfoLib - v0.7.8]
AVISYNTH SCRIPT
Import("C:\video\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("D:\---\---.m2v", CacheFolder = "C:\DOCUME~1\cem\CONFIG~1\Temp")
Return Video
Target Video FileSize: 4142,6 MB
HCenc Parameters: -ini "C:\DOCUME~1\cem\CONFIG~1\Temp\The Replacements.demuxed_1_Title_01.HCenc.ini"
HCenc ini file:
*INFILE C:\DOCUME~1\cem\CONFIG~1\Temp\---.demuxed_1_Title_01.avs
*AVSRELOAD
*OUTFILE C:\tmp\---.demuxed_1_Title_01.m2v
*LOGFILE C:\DOCUME~1\cem\CONFIG~1\Temp\---.demuxed_1_Title_01.HCenc.log
*MAXBITRATE 9000
*BITRATE 4900
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<25/04/2009 1:24:07>
Created File: C:\tmp\---.demuxed_1_Title_01.m2v (4148,3 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 4987 kbps - 720x480 - DAR 1,778 - 29,97 fps - PPF - 1:58:11 hours - 212544 frames
Log file created by AVStoDVD Release 2.1.3
What can I do?
carlmart is offline   Reply With Quote
Old 25th April 2009, 13:56   #810  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@calmart
1. Download and install 2.1.4 release
2. Force DirectShowSource instead of A2DSource. Go to 'Settings'/'Encoding'/'AVS Source Filter'
Let me know
Bye
MrC
AVStoDVD Homepage
Old 25th April 2009, 18:50   #811  |  Link
carlmart
Carlos Martinez
Sorry, I thought that's the version I was using.
OK. Did that. Got the same inverted image.
Old 25th April 2009, 21:51   #812  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
IMO there is some kind of codec misconfiguration. I suggest you to uninstall *every* video codec and splitter you have installed and try only with a stable ffdshow release.
If you get again the error, then send me (avstodvd@gmail.com) a short sample of your video file.
Did you search into Doom9 forum for a similar issue?
Bye
MrC
AVStoDVD Homepage
Old 25th April 2009, 22:47   #813  |  Link
carlmart
Carlos Martinez
Before going into a deep uninstallation, it would be better to get of list of "safe" codecs and what should be installed. Is there a place we can get that?
That's fine, but it might be better to upload it somewhere, or it may take days to send
Just now, only a little bit. But it's been happening now and then for some time. That's why I did spend some time lately doing things though avisynth directly.
Old 25th April 2009, 23:16   #814  |  Link
MysticE
Bye
You might want to try this little app for some clues.
http://paul.glagla.free.fr/filmerit_en.htm
MysticE is offline   Reply With Quote
Old 26th April 2009, 14:18   #815  |  Link
Brazil2
I have installed Avisynth 2.58 and also the DirectShowSource_2587 update. A simple Version AVS script is working fine and is showing the correct version number in WMP.
I have downloaded AVStoDVD_214_NoInstall.7z and unpacked it in a dedicated folder. But when I run it it keeps on saying that Avisynth is not found.
I have reinstalled Avisynth and also the DirectShowSource update but that didn't help, AVStoDVD still can't find Avisynth. But Version.avs is still working fine.
Windows XP 32 bits
Avisynth is in C:\Program Files\Avisynth
AVStoDVD is in E:\Test\Video\AVStoDVD
Any ideas why AVStoDVD can't find Avisynth ?
Brazil2 is offline   Reply With Quote
Old 26th April 2009, 15:21   #816  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@calmart
for broken codecs, follow MysticE suggestion ()
for uploading large files, you can use mediafire.com
@Brazil2
AVStoDVD checks if in the win registry the key "HKEY_LOCAL_MACHINE\SOFTWARE\AviSynth" is present and if it contains the string "AviSynth". Could you please check it manually and report back?
BTW you can skip software integrity control routine by disabling AVStoDVD spash screen ('Settings'/'Misc')
Bye
MrC
AVStoDVD Homepage
Old 26th April 2009, 16:19   #817  |  Link
carlmart
Carlos Martinez
@calmart
I did go with Filmmerit and ordered it to repair the problematic files one by one.
There was only one I couldn't repair or find the dll of, not even looking for it on the web. It should be video compressor codec called cmiccodc.dll
But I went a different way with that film, using HCgui and avisynth.
Thanks anyway.
Old 26th April 2009, 16:21   #818  |  Link
Brazil2
The key exists but it's empty. There is only a Default value which is empty as well.
Please you could tell me how this registry key is exactly supposed to be ? Export this registry key and post it as a Code part maybe ?
But that doesn't help because Avisynth still appears as not found in the software list.
Old 26th April 2009, 18:19   #819  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Brazil2
On a correct AviSynth installation, key "HKEY_LOCAL_MACHINE\SOFTWARE\AviSynth" should have a default value like this: "C:\Program files\AviSynth 2.5" (this is what AVStoDVD checks) and a "plugindir2_5" value like this: "C:\Program files\AviSynth 2.5\plugins"
Even if you get the warning that AviSynth is not found, you can ignore it and continue using AVStoDVD
Bye
MrC
AVStoDVD Homepage
Old 26th April 2009, 20:27   #820  |  Link
Brazil2
OK, it's now working fine after adding these keys to the registry.
I don't know why they weren't there, maybe because I have changed the default installation folder from "AviSynth 2.5" to "AviSynth" ? It might be a bug in the Avisynth installer.
Anyway thanks for the info
[IMG] code is Off
