6th February 2005, 22:04 | #221 | Link |
MKVToolNix author
mkvtoolnix 1.0.2 released
Hey,
I have a new release of mkvtoolnix -- 1.0.2. This is not the long-awaited release with the tons of new features like support for AVC, MPEG-1/-2 etc. Neither does it contain all the bug fixes that the current development version contains. It is merely a release that works with today's releases of libebml and libmatroska. Nevertheless a few bug fixes are present as well. For those who want to build it (like the packages): please be aware that you need libebml 0.7.3 and libmatroska 0.7.5 which were released not an hour ago. You can grab their sources at http://dl.matroska.org/downloads/ The usual links to... ...the homepage: http://www.bunkus.org/videotools/mkvtoolnix/ ...the sources: http://www.bunkus.org/videotools/mkv...-1.0.2.tar.bz2 ...the Windows installer: http://www.bunkus.org/videotools/mkv....0.2-setup.exe Binary packages for other systems/distributions are available from the home page. Here's the ChangeLog since 1.0.1: ---------------------------------------------------------- 2005-02-06 Moritz Bunkus <moritz@bunkus.org> * Released v1.0.2. * all: bug fix: Fixed compilation with the upcoming new versions of libebml and libmatroska. 2005-01-22 Moritz Bunkus <moritz@bunkus.org> * mkvmerge: bug fix: mkvmerge did not accept XML chapter files created with older mkvtoolnix versions due to deprecated chapter elements. Such elements are now skipped. 2004-12-18 Moritz Bunkus <moritz@bunkus.org> * mmg: bug fix: Again the window handling. Hopefully this is better than the other attempts. 2004-12-15 Moritz Bunkus <moritz@bunkus.org> * mmg: bug fix: One was able to crash mmg by pressing 'ok' in the muxing dialog right after muxing finished, especially if the 'abort' button was hit before. This mostly happened on Linux. * mkvmerge: bug fix: Fixed negative audio displacement for a couple of formats. ---------------------------------------------------------- Have fun
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
10th February 2005, 12:44 | #224 | Link | |
10th February 2005, 12:49 | #225 | Link | ||
MKVToolNix author
10th February 2005, 12:56 | #226 | Link | |
note that mp4creator (and therefore mp4ui too) with asp will not set a ctts when you mux from .avi to .mp4 (what most people will do), if you mux from raw to .mp4 they do it yeah, thats mpeg4ip...
10th February 2005, 13:00 | #227 | Link | ||
MKVToolNix author
10th February 2005, 13:12 | #228 | Link | |||
but beaware to only open a copy of your files in mp4ui, as mp4ui has the "nice" feature to optimize (aka rewrite) the files whenever you open them automatically, i dont trust it Quote:
14th February 2005, 01:59 | #230 | Link |
I'm using mkvtoolnix 1.0.2 and I'm having a problem with chapters not showing up at all.
I load a chapter file in a *.txt format. mkvtoolnix opens and parses the chapters correctly, but when I mux everything together mediaplayer classic 6.4.8.2 (latest ver) doesn't see any chapters in my *.mkv file. When I mux chapters in VDub-mod everything works fine. However, I like your chapter editor more. I didn't seem to see anything in the last few pages that helped me. |
14th February 2005, 02:12 | #231 | Link |
the chaptereditor in mmg has nothing to do with the other settings for muxing. you have to save the chapters to a file first and then add them in the 'global'-tab as 'chapter file' and then mux normally. or you can first mux your file without chapters, and then add the chapters in the chaptereditor with "save to matroska file".
14th February 2005, 02:35 | #232 | Link | |
15th February 2005, 00:53 | #233 | Link |
Stumbled across a weird problem with ssa subtitles muxed in with mkvtoolnix 1.0.2 Whenever a line ends with a comma it wont show up at playback when muxed in via MKVtoolnix. They do show when I play them back via softsub thoough. Maybe a small bug?
15th February 2005, 11:36 | #234 | Link |
Bump for the speex support request a while back. Though you're obviously busy with other bits at the moment, I have a definate usage for this atm (director's comments track... not worth bloating a file over, but reasonable quality very low bitrate would make it worth backing up), and can see other usage (audio books -> mka etc).
rawr. Last edited by rawr; 15th February 2005 at 13:19. |
17th February 2005, 23:07 | #235 | Link | |
MKVToolNix author
17th February 2005, 23:13 | #236 | Link | |
MKVToolNix author
17th February 2005, 23:15 | #237 | Link | |
MKVToolNix author
19th February 2005, 15:37 | #238 | Link | |
MKVToolNix author
21st February 2005, 01:02 | #239 | Link |
Reclock framerate problem (RealVideo)
I just tried the latest Guliverkli Matroska Splitter and discovered a little problem playing back my trans-muxed RealVideo files. They all have the framerate set to 30.00 fps (RM is inherently VFR, and this might be the max FPS as read by mkvmerge in the RM header I presume).
However, the actual framerate is 23.976. With the previous version of Matroska Splitter, reclock does not detect the framerate and I can manually set it to 23.976. The "problem" with the newer splitter is that now Reclock gets 30.00 as the framerate, and it is not possible to change it back to 23.976 fps. The only solution I have found is to go back to the older splitter version. Could it perhaps be possible to allow changing the framerate in the MKV file with something like Matroska Properties, in the same way it can now change the display size...? Is it possible to "brute force" hex edit the MKV files? Alternatively, there does not seem to be an option in mkvmerge to set the framerate, if I were to re-mux all the files and set the framerate correctly..
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. |
