29th April 2007, 00:45 | #604 | Link |
1st script
LoadPlugin("F:\encode.filters.take1\MaskTools.dll") LoadPlugin("F:\encode.filters.take1\TIVTC.dll") LoadPlugin("F:\encode.filters.take1\TDeint.dll") LoadPlugin("F:\encode.filters.take1\DegrainMedian.dll") LoadPlugin("F:\encode.filters.take1\ColorMatrix.dll") LoadPlugin("F:\encode.filters.take1\TomsMoComp.dll") LoadPlugin("F:\encode.filters.take1\RemoveGrainSSE2.dll") LoadPlugin("F:\encode.filters.take1\DGDecode.dll") #see saw BEGIN LoadPlugin("F:\encode.filters.take1\SeeSaw\MaskTools-v1.5.8\MaskTools.dll") LoadPlugin("F:\encode.filters.take1\SeeSaw\DenoiseSharpen.dll") LoadPlugin("F:\encode.filters.take1\SeeSaw\RepairSSE2.dll") LoadPlugin("F:\encode.filters.take1\SeeSaw\RSharpenSSE2.dll") #see saw END Import("F:\encode.filters.take1\LimitedSharpenFaster.avsi") Import("F:\encode.filters.take1\Soothe.avsi") Import("F:\encode.filters.take1\SeeSaw\SeeSaw_2006.01.02\SeeSaw.avs") # SOURCE MPEG2Source("E:\Kelly Clarkson-Behind These Hazel Eyes (MV) 1080i-CtrlHD.d2v") # IVTC TIVTC tfm().tdecimate() TDeint( mode = 2 ).DeGrainMedian( mode = 1, interlaced = false ).DeGrainMedian( mode = 0, interlaced = false ) ColorMatrix( ) LanczosResize( 1280, 720 ) LimitedSharpenFaster( dest_x = last.width, dest_y = last.height, Smode = 3, strength = 250, radius = 2, Lmode = 1, wide = false, overshoot = 1 ) The Result with lsf() What can I do to make it more sharper? I've tried applying lsf().lsf() but the result is fuzzy Last edited by esix; 29th April 2007 at 07:47. |
2nd May 2007, 12:15 | #605 | Link |
What's up? Your source comes along as High Definition, which is advertised as "crystal clear", "real as life", and whatnotever ... so it's already in the best possible quality! Why do you want to sharpen up such a brilliant source?
Well ... Turning such fuzzy sources into "beautifully sharp" ones is difficult. And requires a lot of fiddling-around. And sometimes it just won't. Chaining multiple instances of LimitedSharped is one possibility to try. If doing so, try to: - start with UnsharpMasking (Smode=1) /w some bigger radius - follow with UnsharpMasking /w smaller radius - end up with 3x3-kernel sharpening (Smode=2/3/4) - - for all instances: - - do use the "soft=xx" parameter (!) , and/or reduce the strength for each instance Basic example: source LSF(ss_x=1.0, Smode=1, Lmode=3, radius=4, strength=160, soft=100) LSF(ss_x=1.0, Smode=1, Lmode=1, radius=2, strength=96, soft=75) LSF(ss_x=1.5, Smode=3, Lmode=1 strength=150, soft=75) LSF(ss_x=1.0, Smode=3, Lmode=1 strength=51, soft=51) The values for strength/soft are from the guts and may be quite off, you have to tweak them around. Eventually, it's benefitial to add "edgmode=1" to some of the inner or later instances ... BTW, this kind of "multi-radius-sharpening" is what iiP() actually is doing, which could also be worth a try. No promise that this route of processing will work out. Fiddling is what is needed, and perhaps another way than this one would be better. Compare also this thread - Chainmax is fighting a similar case. Kind of, at least.
- We´re at the beginning of the end of mankind´s childhood - My little flickr gallery. (Yes indeed, I do have hobbies other than digital video!) Last edited by Didée; 2nd May 2007 at 13:03. |
12th June 2007, 00:38 | #607 | Link |
Go to the edit tab of the AviSynth Script Creator of MeGUI (or use a text editor) and then Import the LSF script and use it where you want. Or do you need to know how to use it?
Import("X:\Path\to\LSF script\LimitedSharpenFaster.avs") LimitedSharpenFaster()
x264 log explained || x264 deblocking how-to preset -> tune -> user set options -> fast first pass -> profile -> level Doom10 - Of course it's better, it's one more. |
10th July 2007, 03:55 | #608 | Link |
Another great program ( Didée), but I keep getting an error when I close the progam using any script containing LSF:
(program).exe Application Error - The Instruction at "0x39797a8" referenced memory at "0x011eb40". The memory could not be "read". (see attached jpg) If I take LSF out of my script - the problem disappears. It doesn't matter whether it's AsvP, VD, VDMod, HCenc or Media Player Classic. I always get the same error when closing the program. Didée or anyone else, please help. My vidoes just don't look as good without LSF. I tried seesaw & got a similar error (The Instruction at "0x10097a8" referenced memory at "0x018a3b08". The memory could not be "read".) I then unistalled & re-installed avisynth (latest ver.) along with all the external plugins, but that didn't fix the problem. FYI - I running XP home SP2 w/ an AMD Athlon X2 AM2 & 1GB of ram. Thanks Last edited by shadowhaze; 10th July 2007 at 03:57. Reason: attach jpg |
10th July 2007, 21:43 | #610 | Link | |
While I didn't delete the file, I did remove it out of the AviSynth folder altogether & put it in a plugin back up folder in my doc. What did you do exactly? How did you figure out it was aWarpSharp.dll? Should I uninstall/reinstall avisynth & the plugins again? At this point, I thinking of removing every plugin one by one (I've got alot) I keep testing. Thanks again for your help and let me know if you have any other ideas or if I missed this somehere in the thread or forum (I've got the same problem w/ seesaw). |
10th July 2007, 22:26 | #611 | Link |
Hmh. Do you load any "SSE3" DLLs (RemoveGrainSSE3.dll, RepairSSE3.dll), or have those merely present in the plugins folder? If so, remove those DLLs completely, and use the "SSE2" variants.
11th July 2007, 02:31 | #612 | Link | |
THANK YOU!!! Everything works perfectly now. I never would have figured that out. All of my RemoveGrain dlls were SSE3. I deleted all of them, downloaded v0.9 & 1.0 again, and inserted only SSE2 dlls I'm sure my processor can do SSE3 instructions (confirmed by CPU-Z) so I don't understand why that causes a problem, but right now I don't care. It works! Now I just have to work on using seesaw, compare to LSF, and spend the next few weeks converting all my avi files to DVD. |
14th July 2007, 01:00 | #613 | Link | |
From http://avisynth.org/mediawiki/LimitedSharpen
A litle explain what it does the Lmode?
Greece PAL User... |
14th July 2007, 07:18 | #615 | Link |
Inside the script there are only Lmode==1 and Lmode==3.
Also the script from the wiki (http://avisynth.org/mediawiki/LimitedSharpen) for the LSF (http://avisynth.org/mediawiki/upload...rpenFaster.avs) is wrong in lines 52 and 53. The wrong lines: xxs=m(8,ox*ss_x) yys=m(8,oy*ss_y) The right lines: xxs=round(ox*ss_x/8)*8 yys=round(oy*ss_y/8)*8
14th July 2007, 12:46 | #617 | Link |
Thank you foxyshadis for the reply, but the script (LSF) from the wiki give me error on line 52. I don't find m() function.
The script (LSF) from masktools-v2.0a30.zip run fine. Another thing that i notice, you use spline36resize not Lanczos but its ok for me.
14th July 2007, 12:49 | #618 | Link |
foxy: when using selfmade brownies like your modulo-function, you should also put them on the Wiki page (or include them in the script).
When an artless user just gets LSF & the needed plugins as stated, s/he is left up with a "there is no function named "m"" error ... and searching for "m()" might become an effort.
14th July 2007, 17:35 | #619 | Link | ||
From first page: (Thanks Didee)
On the wiki: Quote:
