9th March 2012, 16:22 | #9741 | Link | |
So, CUVID doesn't work with 295.73 on Windows 8? Last edited by aufkrawall; 9th March 2012 at 17:52. |
9th March 2012, 18:51 | #9745 | Link |
The renderer probably always does the same as with High Quality processing enabled.
9th March 2012, 19:53 | #9747 | Link | |
MadVR will now see an interlaced stream and should start it's internal interlacing. Nev, Can you explain the impact of the 3 options related to interlacing in Lav-video if I use MadVR ? What does "force deinterlace" do when using madVR ? The same question for "aggressive deinterlacing" and "tread as progessive" It's currently very unclear to me how these options go along with MadVR's internal logic and the Madvr options to change deinterlacing behavior. |
9th March 2012, 19:55 | #9748 | Link | |
You should rather ask madshi about those things. I know what they do, and you can easily see what they do with EVR, but what madVR does with the information the decoder provides, i don't know. For the record: - "Force Deinterlacing" sets interlace flags on all files and all frames, no matter what. - "Aggressive Deinterlacing" sets interlaced flags on all frames when the file itself is marked interlaced (from the stream header or such) - "Tread as Progressive" marks all frames as progressive, and never anything as interlaced.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 9th March 2012 at 19:57. |
9th March 2012, 20:32 | #9749 | Link |
Let me explain how things are from the view point of a video renderer. The renderer must deal with a wide number of decoders and they all behave differently. Some decoders always set interlaced flags, others never set interlaced flags, again others set them sometimes and sometimes not, depending on user configuration (and the user doesn't always know what he's doing), or depending on the weather or the configuration of the planets. There are typically 2 things that I've seen decoders do:
(1) Either the decoder sets the interlaced flags to 0. If that happens, madVR doesn't know if that is supposed to mean "this file is progressive", or if the decoder is not in the mood to share information, because 0 is also the non-initialized value used by all decoders which never properly fill in these values (like CoreAVC). (2) Or the decoder sets the flags to "AMINTERLACE_DisplayModeBobOrWeave". Again, this information is more or less useless, because by definition is means "the stream could be totally progressive, or totally interlaced, or a mixture of both". In other words, by setting "AMINTERLACE_DisplayModeBobOrWeave", the decoder pretty much says: "I've no idea whether this file is interlaced or progressive or whatever". Even though all of the above is quite bad, madVR *still* tries to behave identical to VMR/EVR, which means that if the interlace flags are set to 0, madVR will by default not activate deinterlacing, and if the flags are set to "AMINTERLACE_DisplayModeBobOrWeave", madVR will by default activate deinterlacing, but only after the first interlaced video frame is received. I don't consider this behaviour really alright, but since VMR/EVR are doing it this way, I'm trying to have madVR behave identical. There is one thing that makes madVR's behaviour different from VMR/EVR: While VMR/EVR always blindly trust the decoder (and thus will stumble when decoders don't set the flags correctly, or not at all), madVR gets itself access to the video bitstream to make its own analyzation of whether deinterlacing is needed or not. If the video bitstream clearly says whether deinterlacing is necessary or not, madVR will value this information higher than the rather non-specific flags described above. I believe this is a good thing, and I challenge anyone to argue otherwise. If LAV wants to force deinterlacing to on/off, it's easy enough to do that with madVR. There are interlace flags available for that, described by Microsoft, which madVR properly honors. "AMINTERLACE_DisplayModeBobOnly" asks for the whole video stream (every frame) to be deinterlaced, so that would be the correct flag to set to force the renderer to turn deinterlacing on. And "AMINTERLACE_DisplayModeWeaveOnly" asks for the whole video stream to not be deinterlaced, so that would be a good flag to set to force the renderer to turn deinterlacing off. If LAV used these flags, madVR would obey. madVR has supported these flags from the first version deinterlacing was introduced. |
9th March 2012, 22:04 | #9750 | Link |
Guessing whether a stream is interlaced or not will always produce errors. I've often seen progressive content with interlaced fades or overlays etc. It's never ending, especially for videos like music videos. In the end the only safe thing to do is deinterlace everything marked as interlaced. My TV tries to be clever and guess what is interlaced, and I regularly see it mess up.
10th March 2012, 01:41 | #9751 | Link | |
If all (or most, some, only LAV ) decoder(s) could output a standard set of flags that were specific (interlaced = yes, no, maybe) and that MadVR also understood it would be great! We could then set MadVR to deinterlace only the "Yes", both "Yes" and "Maybe", or force deinterlace everything. If you enabled deinterlacing in LAV I assume it would set the interlaced flag to "No" so the renderer doesn't re-deinterlace? |
10th March 2012, 02:15 | #9752 | Link |
I'm wondering if anyone's using an AMD 7750 yet to see if it improves DXVA copyback performance with madVR? I could never get it to work well even with the 5770 and I'm scraping to get the best bang for buck GCN card I can.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
10th March 2012, 05:10 | #9753 | Link |
question:
For a file that is being sequentially downloaded, lets say you have the first 10% of it. If you open it up, and try to play it, even if it finishes downloading before you hit the 10% mark, your video just freezes at the 10% mark. Can anything be done about this? |
10th March 2012, 07:43 | #9754 | Link | ||
I have a file which is marked as interlaced, however the frame-flag is missing on some frames. EVR will not deinterlace the frames where this is missing, madVR will. Even if the behaviour of deinterlacing the frames in this file is correct, extrapolating from that, any file which is mixed interlaced and progressive content, even the progressive frames will all be deinterlaced. There is also no other set of flags i could set, AMINTERLACE_DisplayModeBobOrWeave is the only flag that allows mixed interlaced and progressive content. Anyway, that seems to be the only case thats inconsistent. Quote:
Even though i don't agree with setting WeaveOnly for progressive (progressive is defined as the absence of flags), it seems to work.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 10th March 2012 at 08:06. |
10th March 2012, 08:41 | #9755 | Link | |||
What other flag combination would you suggest to indicate "progressive"? 0 would make sense, but unfortunately it's the same as "not initialized", so we can't really use that. |
10th March 2012, 08:41 | #9756 | Link |
I use Lav Filters for mp3 in PotPlayer and this file did not play. It froze with the album art and showed up as mjpg in file info. Plays fine in WMP.
http://www.mediafire.com/download.php?251j501nbv8vjxx PotPlayer 1.5.32338 x86 Lav Filters 0.48 1dc4df4 |
10th March 2012, 08:51 | #9757 | Link | ||
Fixed
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 10th March 2012 at 09:25. |
10th March 2012, 12:59 | #9758 | Link |
nevcairiel and madshi, this is nothing really to do with LAV Filters or MadVR but I figure you might know something about this:
In MKVMerge, is it preferable to set the Aspect Ratio or Display Width/Height? The combinations of LAV + EVR and LAV + MadVR both seem to work fine with either option but I'm just thinking about maximum portability of MKV files on other machines with other filters, decoders and renderers.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
10th March 2012, 13:40 | #9759 | Link |
MKV only has the Display Width/Height fields internally, so whatever you set, it'll end up in those fields.
If you want portability, i would recommend to make sure that the Aspect Ratio is also properly set in the video headers, at least H264, VC1 and MPEG2 have fields for that. A lot of players ignore the container values.
10th March 2012, 13:54 | #9760 | Link |
50p video and x-copped movies
Hi there !!!
I got the following two problems with the "LAV Video Decoder": 1.) When playing HD movies in MPC-HC, that have been x-cropped (e. g. from 1920 to 1808), it results in a stuttering playback with asynchronous audio. However, when movies are y-cropped everything's fine. 2.) 50p Full-HD video from a "Panasonic HDC-SD909" camcorder is played back at only about 30-32 FPS. Hopefully someone's got an idea of how to fix these problems, because until now I always have to reencode the two problematic formats to 1.) 1920x1080 and 2.) 720p @ 50 FPS to play them back flawlessly. Motherboard: Zotac ION ITX D Chipset: NVidia ION (video decoder is set to use "Nvidia Cuvid") CPU: Intel Atom N330 Dual Core @ 1,6 GHz Player: MPC-HC Splitter: Haali Media Splitter Renderer: VMR-7 OS: Windows XP Professional (SP3) Greetz, The SphereX |
