2nd February 2012, 13:21 | #8742 | Link | |
2nd February 2012, 13:33 | #8743 | Link | |
The main performance difference has already been fixed by adjusting the settings i use. I'm not sure there still is a difference, none that i could measure anyway.
2nd February 2012, 13:49 | #8744 | Link | |
2nd February 2012, 13:52 | #8745 | Link | |
If someone wants to work on that plugin (or something comparable) and needs some information how to interface with LAV, i'll be glad to provide it, but i will not work on it myself.
2nd February 2012, 14:14 | #8746 | Link |
hello everyone, i used LAV Filter 0.45 with MPC-HC (30-01-2012) recently with my Hybrid Vaio VPCCA16FG
this is my specs i7 2620M 8GB RAM Crucial AMD Radeon 6630M (Intel HD 3000) it's wierd that i can get video with Intel [power saving mode], but i can't get video with the AMD [high performance] ( audio and subtitle were fine though ) i used the settings here http://www.elysiumsubs.com/docs/mpc-hc-guide nothing changed. if i used madVR i can get the video with AMD what can i do to fix this? thanks before |
2nd February 2012, 17:14 | #8747 | Link |
Nev,
Could you please add SNOW to the supported decoders ? It's supported by ffmpeg, so it should not be too much work. With LAV I got : Code:
LAV Splitter Source::Video Media Type 0: -------------------------- Video: SNOW 848x480 23.976fps AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: Unknown GUID Name {574F4E53-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 0 bTemporalCompression: 1 lSampleSize: 1 cbFormat: 88 Code:
Input #0, matroska,webm, from 'K:\film\new_2012-01\13_snow.mkv': Metadata: ENCODER : Lavf53.24.0 Duration: 00:00:12.73, start: 0.000000, bitrate: 984 kb/s Stream #0:0: Video: snow, yuv420p, 848x480, SAR 1:1 DAR 53:30, 23.98 fps, 23.98 tbr, 1k tbn, 1k tbc (default) Stream #0:1(jpn): Audio: aac, 48000 Hz, stereo, s16 (default) 24.50 A-V: 12.735 fd= 22 aq= 0KB vq= 50KB sq= 0B f=1/1 f=0/0 |
2nd February 2012, 17:25 | #8748 | Link | |
Done, also added FFV1 because someone asked for that some time ago.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 2nd February 2012 at 17:40. |
2nd February 2012, 23:04 | #8751 | Link |
No Audio
I can't get sound from Swedish - Girl with the Dragon Tattoo BD movie using MPC-HC and LAV Audio Decoder set to bit stream. This movie has been saved using DVDFab main movie. I have no other problems playing all other BD, folder or MKV. Going to Filters I do not see Lav Audio at all. No options for audio or subs. No other Audio decoder.
This plays with TMT5 just fine. I get subs and both audio tracks. Thanks. |
3rd February 2012, 00:33 | #8752 | Link |
Btw did someone experienced that Cyberlinks VC-1 Decoder doesn't connect with every VC-1 .mkv but denies connection with certain .mkvs and lav splitter ?
I wonder whats going on as those .mkv connect fine with Arcsofts (but Decoding is very bad timestamp issues in general with .mlv) or Microsofts Decoder it works much better with Cyberlinks or Microsofts Decoder and Cyberlinks even allows Super fast seek Its not a Profile issue as some have the same Profile and one connects the other doesn't very strange behavior @Nev Not sure about this http://www.mediafire.com/?y4czq3rkmcns19l vlc = fail mirillis = ok mplayer2 = ok mplayer = ok avplay = not sure ffplay = not sure powerdvd = fail lav splitter + lav video = fail haali = fail mpc-hc = fail av splitter = fail lav splitter + cyberlink = fail lav splitter + arcsoft = ok Arcsoft rarely likes to work with anyone (see VC-1 mkvs that Cyberlink doesn't accept and Arcsoft plays but wrong) this is one rare sample where it does work fine with the others and the others fail :P
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 3rd February 2012 at 03:50. |
3rd February 2012, 07:56 | #8753 | Link | |
Your change in MT settings did fix part of the difference I observed but I'm still seeing a slight difference in LAV Filters in favor of 0.22 if I use it to replace QuickSync 0.24. In FFDShow 4234 which features Rev18 (0.22) of QuickSync, I get average performance with my anime intro file. Replacing 0.24 in the latest version of LAV Filters with 0.22 gives me consistently 10% performance increase over 0.24 which doesn't stack up vs my FFDShow results. I'll include the intro sample here and if it interests you or Eric as to why this is happening you can look into it. These are my bench results with this file, all tests run 5 times and averaged. FFDShow 4234 QuickSync Rev18 (0.22) 550FPS FFDShow 4238 QuickSync Rev20 (0.23) 550FPS FFDShow 4294 QuickSync Rev30 (0.24) 2050FPS LAV Filters 0.45 QuickSync 0.24 2040FPS LAV Filters 0.45 QuickSync 0.22 2300FPS http://www.mediafire.com/?iak3fxc4pdc2rir Thanks Nev. |
3rd February 2012, 07:58 | #8754 | Link |
Like i said before, those numbers are too high to be real FPS values. 550fps might be valid for a SD file, however 2300 is most likely a measuring error because of too short files.
Pick a file thats much longer, maybe 10 minutes or so. Sure, benchmarking might take a while longer, but the result will be much more accurate and in line with other performance results. Also, if you're really complaining about 2050 vs 2300 fps, i'll dismiss this as well. Find a HD file that shows a performance different.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 3rd February 2012 at 08:22. |
3rd February 2012, 10:15 | #8756 | Link |
You win 0.22 and 0.24 give similar results.
I tested with a 20 minute H.264 848x480 episode and compared some. With Xhmikosr's builds I get around 315 FPS =/ With release 0.45 I get 980 FPS FFDShow 4292 (Rev 30) 690 FPS =| Also tried latest nightly and again 315 FPS. Some strange results. I run into an error in MPC after registering all three filters in the nightlies that the video cannot be rendered, LAV installed from an installer works fine (Xhmikosr and release builds) what's happening there? Graphedit works with it fine except slowly. |
3rd February 2012, 10:18 | #8757 | Link |
Xhmikosr builds don't include the Intel decoder, last i checked (so it might be software decoding at work there), or it might be an older version.
In general, i only give support for my own builds, i cannot control if anyone just messed up their build (which happened quite a bit in the past) I can provide a recent git build when i get home from work.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 3rd February 2012 at 10:22. |
3rd February 2012, 10:27 | #8758 | Link |
Yeah I can understand the support for your builds only. I keep the Intel decoder in the directory so perhaps the nightlies aren't linking to it or something. I'll take you up on your gracious offer of the git build, thanks
3rd February 2012, 14:49 | #8759 | Link |
QuickSync Decoder author
Version 0.25 beta is out with the following changes:
* Fixed handling of CCV1 streams (Haali splitter custom fourCC). * Support for H264 AVI files. * Optimized memory copy further. Removed ASM code. Code now uses intrinsic for both 32 and 64 bit as intrinsic code reached 32 bit efficiency. * Code cosmetics. * FFDShow rev4295 Download from SourceForge home page
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
3rd February 2012, 14:51 | #8760 | Link |
Great thanks, i'll update the binary i ship
