Old 15th December 2012, 20:41   #16281  |  Link
jdobbs
Originally Posted by gkn View Post
You know, that is really unnecessary.
It is necessary, I now have two additional pages of long-winded diatribe clogging up an already long thread that is meant to be used for simple bug reports -- I gave you an answer that you just don't want to accept. I realize you want to be right. Everybody does. But at some point you have to just accept the facts as they are and move on...
Website: www.jdobbs.net
Old 16th December 2012, 00:31   #16282  |  Link
Ch3vr0n
ey, it's your thread jdobbs. I'd split the non-bug related "crap"
Ch3vr0n is offline   Reply With Quote
Old 16th December 2012, 01:43   #16283  |  Link
jdobbs
BD Rebuilder v0.42.06 (beta)
I have updated the first thread of this post with links to a new version of BD-RB (v0.42.06). Changes for this release:
- Added information to the video import routine
  so it would properly handle AVI files with the
  "DX50" fourcc value.
- Updated video file imports so that SRT streams
  contained in MKV files will be included in the
  pseudo source muxing.
- Corrected an error in which forced subtitles
  were not being carried over into ALTERNATE
  movie-only DVD output.
- Created a hidden option OUTPUT_FOLDER that can
  be used to redirect the final output build to a
  location other than the working folder. See the
  file HIDDENOPTS.TXT for usage details.
- Updated BD-RB and INSPECT to accept an newer
  version of FFDSHOW (r4422) as "correct".
- Updated the included version of X264.EXE to the
  latest release (r2230).
- Updated the included version of X264-64.EXE to
  the latest release (r2230).
- Other minor corrections and cosmetic fixes.
Old 16th December 2012, 02:00   #16284  |  Link
Ch3vr0n
sweet. Thanks for the output option. While it's no navigatable folder like the source or working path. Its a reroute for the final output. It'll work just the same. Thx alot
Old 16th December 2012, 02:01   #16285  |  Link
Nico8583
Thanks for this release, I'll test tomorrow :-)
Do you include a correction for multi angle ?
Edit : do we could upgrade to the new version of FFDShow ?
Nico8583 is offline   Reply With Quote
Old 16th December 2012, 02:15   #16286  |  Link
jdobbs
No changes made for multi-angle selection. That will have to wait until the next release. I just wanted to get this out before the holidays -- and I have another project that has to take priority for the next couple of weeks.
Old 16th December 2012, 02:28   #16287  |  Link
Ch3vr0n
Since the ffdshow link got updated to 4422 pretty safe to assume you can update. I did :-)
Verstuurd van mijn HTC Sensation XE with Beats Audio Z715e met Tapatalk
Old 16th December 2012, 02:31   #16288  |  Link
jdobbs
I've been using that one for a few months now with no issues.
Old 16th December 2012, 02:37   #16289  |  Link
omegaman7
omegaman7's Avatar
I used to use Ripbot264 for certain abilities. Which requires a newer version of FFDshow. But since Bd Rebuilder has allowed output to Dvd, as well as a wonderful import function, I haven't seen the need. The newer version worked just fine with Bd Rebuilder. If I had had any issues, I obviously would have rolled back to the trusted version on page 1. BEFORE posting a bug report
Only one rooster, need be in the hen house...
omegaman7 is offline   Reply With Quote
Old 16th December 2012, 02:39   #16290  |  Link
jdobbs
That's exactly how I'd lke it to work. I don't want to forbid using a newer version -- but I can't respond to bug reports unless a recommended is used.
Old 16th December 2012, 02:50   #16291  |  Link
jdobbs
My biggest mistake with DVD Rebuilder was making it too complicated by adding everything that was asked and crowding up the user interface & menus. So I decided that I'd take a different approach with BD Rebuilder. I won't ignore feature requests, but if I think they're not necessarily something that would benefit everyone or aren't major improvements -- they will be implemented in a less instrusive way, as a hidden option.
Old 16th December 2012, 05:25   #16292  |  Link
soneca
Thanks for the new version!
soneca is offline   Reply With Quote
Old 16th December 2012, 14:10   #16293  |  Link
wakko709
[12/15/12] BD Rebuilder v0.42.04 (beta)
[16:02:28] Source:  DARK_SHADOWS
  - Input BD size: 23.82 GB
  - Approximate total content: [02:18:35.390]
  - Target BD size: 22.95 GB
  - Windows Version: 6.1 [7600]
  - Auto Quality: Good (Very Fast), ABR
  - Decoding/Frame serving: DirectShow
  - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
- Resuming from previously started job.
[16:02:31] PHASE ONE, Encoding
 - [16:02:31] Processing: VID_00058 (8 of 8)
 - [16:02:31] Extracting A/V streams [VID_00058]
[16:02:57]PHASE ONE aborted by user request
[16:03:00] Source:  DARK_SHADOWS
[16:03:03] PHASE ONE, Encoding
 - [16:03:03] Processing: VID_00015 (1 of 8)
 - [16:03:03] Extracting A/V streams [VID_00015]
 - [16:07:16] Reencoding video [VID_00015]
   - Rate/Length: 23.976fps, 8,159 frames
   - Bitrate: 3,751 Kbs
 - [16:07:16] Reencoding: VID_00015, Pass 1 of 1
 - [16:10:31] Video Encode complete
 - [16:10:31] Processing audio tracks
 - [16:10:31] Multiplexing M2TS
 - [16:10:42] Processing: VID_00031 (2 of 8)
 - [16:10:42] Extracting A/V streams [VID_00031]
 - [16:14:38] Reencoding video [VID_00031]
   - Rate/Length: 23.976fps, 2,689 frames
   - Bitrate: 11,083 Kbs
 - [16:14:38] Reencoding: VID_00031, Pass 1 of 1
 - [16:19:10] Video Encode complete
 - [16:19:10] Processing audio tracks
   - Track 4352 (spa): Keeping original audio
 - [16:19:10] Multiplexing M2TS
 - [16:19:20] Processing: VID_00036 (3 of 8)
 - [16:19:20] Extracting A/V streams [VID_00036]
 - [16:22:13] Reencoding video [VID_00036]
   - Rate/Length: 23.976fps, 2,627 frames
   - Bitrate: 9,259 Kbs
 - [16:22:13] Reencoding: VID_00036, Pass 1 of 1
 - [16:26:06] Video Encode complete
 - [16:26:06] Processing audio tracks
 - [16:26:06] Multiplexing M2TS
 - [16:26:16] Processing: VID_00054 (4 of 8)
 - [16:26:16] Extracting A/V streams [VID_00054]
 - [16:31:32] Reencoding video [VID_00054]
   - Rate/Length: 23.976fps, 3,601 frames
   - Bitrate: 9,203 Kbs
 - [16:31:32] Reencoding: VID_00054, Pass 1 of 1
 - [16:37:13] Video Encode complete
 - [16:37:13] Processing audio tracks
 - [16:37:13] Multiplexing M2TS
 - [16:37:24] Processing: VID_00055 (5 of 8)
 - [16:37:24] Extracting A/V streams [VID_00055]
 - [16:41:46] Reencoding video [VID_00055]
   - Rate/Length: 23.976fps, 3,697 frames
   - Bitrate: 9,254 Kbs
 - [16:41:46] Reencoding: VID_00055, Pass 1 of 1
 - [16:57:54] Video Encode complete
 - [16:57:54] Processing audio tracks
 - [16:57:54] Multiplexing M2TS
 - [16:58:14] Processing: VID_00056 (6 of 8)
 - [16:58:14] Extracting A/V streams [VID_00056]
 - [17:03:02] Reencoding video [VID_00056]
   - Rate/Length: 23.976fps, 3,366 frames
   - Bitrate: 10,986 Kbs
 - [17:03:02] Reencoding: VID_00056, Pass 1 of 1
 - [17:07:42] Video Encode complete
 - [17:07:42] Processing audio tracks
 - [17:07:42] Multiplexing M2TS
 - [17:07:49] Processing: VID_00057 (7 of 8)
 - [17:07:49] Extracting A/V streams [VID_00057]
 - [17:11:12] Reencoding video [VID_00057]
   - Rate/Length: 23.976fps, 3,409 frames
   - Bitrate: 8,941 Kbs
 - [17:11:12] Reencoding: VID_00057, Pass 1 of 1
 - [22:28:05] Video Encode complete
 - [22:28:05] Processing audio tracks
 - [22:28:05] Multiplexing M2TS
 - [22:28:29] Processing: VID_00058 (8 of 8)
 - [22:28:29] Extracting A/V streams [VID_00058]
 - [05:05:50] DoEncoding() 00052  1606
[05:06:35] - Failed to complete.
_____________________________
wakko709 is offline   Reply With Quote
Old 16th December 2012, 14:14   #16294  |  Link
wakko709
- AVISYNTH Version: [2.5.8.0], Ok
- HAALI Splitter: [1.9.42.1], Ok
- FFDSHOW: [3882], Ok
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Not Set correctly
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- AnyDVD settings check: Ok.
- BD Rebuilder v0.42.0.4, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Old 16th December 2012, 14:23   #16295  |  Link
gonca
@wakko709
I see that there is a 6 1/2 hours difference between the beginning of extraction and the error.
Try re-ripping the movie.
Are you working directly from the BD disc?
gonca is offline   Reply With Quote
Old 16th December 2012, 18:46   #16296  |  Link
lauguru
hello jdobbs
I worked perfectly in the previous version windows 8 and now with this beta, and installing the updated programs, I have this error
[12/16/12] BD Rebuilder v0.42.06 (beta)
[18:14:21] Source: Enemy At The Gates 2001 Blu-ray 1080p AVC
- Input BD size: 41,04 GB
- Approximate total content: [03:13:30.254]
- Target BD size: 24,33 GB
- Windows Version: 6.2 [9200]
- MOVIE and MENUS mode enabled
- Quality: Ultra High Quality (Extremely Slow), Two Pass
- Decoding/Frame serving: X264/LAVF [4-way]
[18:14:37] PHASE ONE, Encoding
- [18:14:37] Blanking: VID_00000 (1 of 77)
- [18:14:37] Processing: VID_00001 (2 of 77)
- [18:14:37] Extracting A/V streams [VID_00001]
- [18:28:57] Reencoding video [VID_00001]
- Rate/Length: 23,976fps, 188.592 frames
- Bitrate: 19.107 Kbs
- [18:28:57] Reencoding: VID_00001, Pass 1 of 2
- Encode failed. Aborting.
- BD-Rebuilder v0.42.06 (beta)
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: 1.9.42.1, Ok
- FFDSHOW: 4422, Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
*just replace X264.EXE X264-64.EXE file (r2230) files for the previous beta version v0.42.04 (Version r2216)and now it works. So the problem comes with the new version (r2230) of x264.exe
lauguru is offline   Reply With Quote
Old 16th December 2012, 19:36   #16297  |  Link
gg72
Unfortunately I have also problems (encode failed) with the new version. The same source worked perfectly with the previous version (with the same settings).
gg72 is offline   Reply With Quote
Old 16th December 2012, 20:44   #16298  |  Link
jdobbs
hello jdobbs
I can't imagine what could have been introduced in this release of X264 that might have caused it. You might want to right-click and look at the properties and make sure it isn't blocked.
I've been encoding successfully with r2230 since it was released in mid-November.
Old 16th December 2012, 20:48   #16299  |  Link
jdobbs
Provide some specifics about your system so we can see what might be causing the issue.
Old 16th December 2012, 21:27   #16300  |  Link
lauguru
Nothing, I find it impossible to work with this new version
