Old 22nd August 2006, 16:39   #21  |  Link
johner23
I had one doubt about my files after drm'ing: when I free all of them, I will get generally WMA and WMV files as result.
Well, but if I wanna convert those files in other formats, just like MP3 or AVI (xvid, divx, etc) which programs do you suggest, to have the best quality possible during these convestion between formats?
johner23 is offline
Old 23rd August 2006, 23:40   #22  |  Link
dager
I'm having trouble - it will unDRM, but then it can't be used in any editing programs to change it to MP4 format.
dager is offline
Old 24th August 2006, 05:09   #23  |  Link
WalterK
WalterK's Avatar
see the guides on the forums or doom9 site or www.videohelp.com for converting.
WalterK is offline
Old 25th August 2006, 17:04   #24  |  Link
GoodOmens
Might as well get it to as many sites as possible before microsoft attacks :-p
http://www.filefactory.com/file/c18e1d/
http://d.turboupload.com/d/917535/FairUse4WM.zip.html
http://www.uploading.com/?get=CQLBKEA6
http://www.sendmefile.com/00457915
GoodOmens is offline
Old 25th August 2006, 23:36   #25  |  Link
johner23
These tool are a great piece of proggy and many people are using it around the world.
That's nice... but... Micro$oft and maybe other companies soon will notice / realize the program fame and will do some patching engine security to break the FairUse4WM success.
---> http://www.engadget.com/2006/08/25/f...ows-media-drm/
---> http://www.afterdawn.com/news/archive/7875.cfm
---> http://www.all-streaming-media.com/f...splay.php?f=25
---> http://forum.cdfreaks.com/showthread...81#post1527541
---> http://forum.cdfreaks.com/showthread...4&page=1&pp=25
Please, developers: always be updated ( if it's possible ) against newer DRM craps, ok?
Very, very nice tool.
If any people who know programming and how to deal with such DRM protection files wanna help, it'll be very nice for the whole community.
Good job, guys!!
devil (johner)
johner23 is offline
Old 26th August 2006, 04:59   #26  |  Link
Panda
maybe I am stupid...
Ok, I am new to DRM (but I am smart enough to know it sux...)
but does FairUse4WM work on audio files?
Panda is offline
Old 26th August 2006, 05:20   #27  |  Link
unskinnyboy
unskinnyboy's Avatar
If you had taken the time to read the whole thread, you would have seen that most people *are* using FairUse4WM on their DRM'd audio files.
Most importantly, the golden rule: Thou shalt try before thou asks.
unskinnyboy is offline
Old 26th August 2006, 07:26   #28  |  Link
Xenomorph
while this has worked on most of my DRM'd WMA files, there are some that the program doesnt seem to notice the Key. it opens WMP, plays the file, but never closes.
when i manually close WMP, the program gives me this error:
Unhandled situation -9000 while Creating Windows Media instance.
any ideas? i have the license for the file, and WMP can play it just fine. because of issues i've had to deal with after doing a clean install of Windows, i dont want to mess with its DRM any more.
Xenomorph is offline
Old 26th August 2006, 20:06   #29  |  Link
gtanning
FairUse4WM
Thank you so much for this program. It has worked flawlessly for me so far.
I do appreciate FairUse4WM very much.
G. T.
gtanning is offline
Old 26th August 2006, 20:31   #30  |  Link
Panda
I did try.
At first I had the Blackbox.DLL error. So I went to the posted URL, and it did not give me the button to upgrade. So I tried one of the Demo files from EZDRM.com - They would not download. Then I realised I was using Firefox ( I knew I was using it, I just forgot that MS does not like it...) So I went back to the URL with Innernet Exploiter and did the update. Then I got an Error:
Panic! At The Disco - I Write Sins Not Tragedies.WMA UNABLE TO DECRYPT: Size Error: 5217873102 cannot be truncated to 922905806.
So then I went to EZDRM and downloaded one of the "Free DRM" vidoes - FairUse worked very well at that.
I tried the test audio file again and got the same error again.
Before posting all that, I wanted to make sure I was not trying a video only proggie for audio DRM...
I did say I was new to DRM
Panda is offline
Old 27th August 2006, 15:54   #31  |  Link
mayang
Totally Newbies
mayang's Avatar
Active Discussion
More active discussion can be found below:
Link 1
Link 2
Link 3
mayang is offline
Old 27th August 2006, 19:27   #32  |  Link
helloz
I have the version: 10.00.00.4036 SP2 Spanish and found correctly
Thx all! (coders, developers...)
helloz is offline
Old 28th August 2006, 08:31   #33  |  Link
viodentia
Bug reports
Just to drop in to say that I am aware of the following issues
1. DRMv1 support is more common than I believed. This is being addressed. I believe this to be at the root of some "odd" behavior
2. Panda's problem involves extra data appended at the end of some WMA files. Truncating these files to the length in the File Properties Object should fix the problem. If anyone can find what this data is used for, if anything, it'd help. Thanks for the find, Panda.
Thank you all for your feedback.
viodentia is offline
Old 28th August 2006, 14:20   #34  |  Link
johner23
Once FairUse4WM have work so many times, it's easier for people to relate bugs and help for later program's improvement.
More than that: once people could have solve that DRM restrictive environment, other programers can study and create similar engines that are able to deal with such "protections".
Just like happen with dvd's in the past: once Macrovision/CSS were removed by DVD-Jon and other people, these make possible some other programers be able do the same and many softwares were created after that.
I just wish many other people have time and talent/knowledge to improve more and more FairUse4WM and /or create similar tools that can do the same: un-drming skills.
PS: any FairUse4WM update or improvement, let us know.
Thanks, folks.
johner23 is offline
Old 28th August 2006, 15:21   #35  |  Link
Web Junkie
It's suddenly stopped working for me?
All my licenses are working as I can play my protected DRM video files, individulized my player and all I get is:
Windows Error 80030002 while DRM_HDS_OpenStore
This is on every file that I now try, but before it worked? What is the problem here, anyone know?
*UPDATE*
Solved the problem! Installed WMP10 and it still complained with same message as above, but after deleting the DRMSTORE.HDS file and re-acquiring my licenses again everything went like clockwork
Web Junkie is offline
Old 28th August 2006, 15:37   #36  |  Link
viodentia
DRM_HDS_OpenStore is part of the DRM License library that FairUse4WM uses to pull licenses from drmstore.hds
The error 80030002 means that it can't be opened, either because another program has it exclusively locked, or that it doesn't exist.
Please send me a directory listing of your "All Users"\"DRM" directory (use "dir /a" since the files are usually hidden)
Old 28th August 2006, 17:43   #37  |  Link
johner23
Some other places to discuss about DRM and similar things.
---> http://www.wmptalk.com/index.php
---> http://all-streaming-media.com/forum...read.php?t=211
---> http://hymn-project.org/forums/index...5f0b0a27d3619f
Thanks
johner23 is offline
Old 28th August 2006, 17:49   #38  |  Link
Web Junkie
I fixed the problem, see the update in post #35!
The file was already present and not locked. Used a tool called Unlocker 1.8.4 to see if the file was locked and it wasn't, so no reason for Fairuse to not read it, unless of course it was corrupt somehow?
Old 28th August 2006, 23:04   #39  |  Link
polychrome
Why do i get error 9000 ...
When I use the tool I get a messagebox with the title "Unable to recover private key" and message text "Unhandled situation -9000 while Creating Windows Media instance."
The tool starts, I select a demo file downloaded from ezdrm.com, WMP starts, the video plays, the video ends, I close WMP and the messagebox appears. repeated trials show that the messagebox doesn't appear until WMP is closed.
WMP version 10.00.00.4306
Windows XP Pro SP2
polychrome is offline
Old 29th August 2006, 02:26   #40  |  Link
viodentia
-9000
The error -9000 is a generic catch-all that just means that Wmplayer exitted before the program could find the keys in memory.
Verify that your system is individualized, and please post the version information (right-click) from "indivbox.key" in "All Users"\DRM directory.
