24th March 2004, 08:42 | #82 | Link |
Hi r6d2,
I have noticed a few occasions where "FACARDetectBorders" has determined that the left hand side of the frame is 2. However, I can see (in the preview window), picture information to the left of the vertical white line in pixels 0 & 1. This is no big deal (2 pixels), but I thought I'd let you know about it. Regards, Bob |
24th March 2004, 12:26 | #83 | Link | |
Graphite mod
If you experience top and bottom errors, you may want to play with the threshold parameter of "FACAR Detect Borders", but then again, width detection it is not really relevant to the output script.
MPEG4 quality with MPEG2? - Try the Poor Man's DVD. FACAR - As seen on TV! - The Complete Idiot's Guide to a good DVD Conversion. Time is money. Try D2Sroba for DVD2SVCD (FAQ) and save both. All electricity bills supported! Do you know how much overscan and which resolution your TV has? Find out if NTSC. Moderator: 1: one who arbitrates 2: one who presides over an assembly, meeting, or discussion 3: a substance (as graphite) used for slowing down neutrons in a nuclear reactor (Webster) |
25th April 2004, 23:40 | #84 | Link |
hi there have just had to reinstall dvd2svcd etc and noticed an error i didnt use to have in version 1067 as below ( i think i originally installed it to a subfolder of itself so was always using the previous version )
i dont know what "destinationtop" means e:\dvd2svcd\avisynth2.5 Plugins\Facar\FACAR.avs, line 136 have searched the FACAR.avs file and dont see any other reference to it other than line 136 could you please point me to what im sure is an obvious oversite by me thanks edit - knew it was an oversite the FACAR folder and a new avisynth.ini it merged with the original and now all sorted
i read - i dont understand - i try anyway - and get there in the end with the help of the DOOM9 forums Last edited by homerjay; 26th April 2004 at 22:04. |
12th June 2004, 01:06 | #85 | Link |
Posts: n/a
r6d2,
i don't use tweak. have a way to remove that filter from FACAR? i know that using the defaults in tweak don't change the image but(i think) that if the filter can be removed from the script maybe it can run faster...or is my mistake? it's a newby question of course but i have my doubts. in the FACAR readme explain about GammaCorrection. is used the built in dvd2avi or the levels from avisynth?...and why GammaCorretion is in 1.0 if the default is 0.0? i like to use "kiss" filter like that in d2s: undot() lanczosresize(.....) deen() using "kiss" in FACAR,where i put this filters using the same sequence like i posted? means undot before resize and deen after resize. thanks in advance! |
12th June 2004, 02:03 | #86 | Link | |||
Graphite mod
((Hue <> 0) [...]) ? Tweak(Hue, Saturation, Brightness, Contrast) : NOP() Quote:
It is likely that Debug mode won't work if you do this though, but in normal operation it should. Please report back if it doesn't.
12th June 2004, 05:40 | #88 | Link |
Posts: n/a
r6d2,
like you "preview", don't have differences in quality or time to encode using the " # " eliminating tweak from the script in my sample test ( ~ 01minutes:22seconds vob),...just the same with or without tweak(in default values,of course)! using Undot() in Preresize.avs and Deen() in Postresize.avs worked like a charm....and forgive my "old" question cos i read the FACAR readme "too fast" and without atention(sorry)before ask you and there is very clear about "<iii>. Additional filtering" and with details about kiss "filter".everything is clear in the readme. thank you very much r6d2, FACAR stills "turbo"! |
14th June 2004, 17:53 | #89 | Link |
I've been using FACAR for a couple of encodes and it seems to save me bitrate, but at the risk of sounding stupid, can I ask a couple of questions?
1) My understanding from reading the script is FACAR works out what area of the frame you won't see by examining the overscan. It then chops this portion off and adds a border to keep proper frame size. Correct? 2) If 1) is true, is the advantage on a full height movie coming only from chopping the unseen parts off (no visible borders)? 3) I was interested in seeing just how much of the frame is lost when viewing on TV, but FACAR shows what will be encoded post cropping and overlaying additional lost area to overscan so it's hard to judge what is missing. I've played with the script a little and come up with the following: Targetpre = AddBorders(1, 1, 1, 1).bilinearresize(DestinationWidth,DestinationHeight) # --(r6d2)-- Calculate BlocksToCrop based on Overscan parameters. # --(r6d2)-- Add the overscan overlay to the given clip in transparency mode # (Target clip must already be properly cropped, resized and bordered.) DebugTarget = ConvertToRGB32(Targetpre) # use RBG32 for Layer() [Additions / changes from original script in RED/ BLACK text shows relative position] Does this do what I want it to do; ie take the original clip and overlay a border showing everything that will be lost? Forgive me if it doesn't but I don't know much about Avisynth, but like understand the whole process |
14th June 2004, 18:33 | #90 | Link |
Graphite mod
Well, sort of. But it should be easier than that. What FACAR does is to take Overscan percentages as input parameters and crop out the unseen area, thus saving the BR that it would take to encode the whole original picture frame.
If you would like to see how much is being cropped, use Debug mode (set it to 3, for example) and an overlay margin in blue will be shown along with the cropped picture. Currently there is no way to see how much will be cropped together with the original (uncropped) picture, but it sounds like a good idea. I cannot test you your modifications now but I'll look at them later to see if they add the desired effect.
14th June 2004, 23:12 | #92 | Link |
Posts: n/a
r6d2,please,take a look in this pictures:
http://img12.imageshack.us/img12/675...doverscan1.jpg http://img18.imageshack.us/img18/384...doverscan3.jpg see that the first picture using fitcd overscan1,show the same as the second picture form fitcd overscan3...same details within the borders without loose parts of the scenes(pictures) now see that using Facar: http://img12.imageshack.us/img12/9291/facar1.jpg see that i'm loosing part of the picture within the borders(the chickens on the left and in the right are loose).what can i do to get the same as from fitcd overscan3 in Facar without loose part of the picture within the borders? thanks in advance! |
15th June 2004, 02:37 | #93 | Link | |
Graphite mod
FACAR is useful if you want to encode in "As seen on TV" mode.
15th June 2004, 03:28 | #94 | Link |
Posts: n/a
is true .
and see my point of view r6d2. what i gain in the right/left using fitcd overscan(1,2 or 3)i loose in the top bottom. compare the size of the top bottom of Facar...have less black bordes and with fitcd overscan have more in top bottom. means that with overscan i don't get real gain and the right/left from Facar the tv(4:3) don't show....resuming my "explanation": fitcd overscan ---> less black borders in right/left(that are invisible in tv,then are irrelevants) from fitcd overscan and true loose in top/bottom(too big black borders) you loose more in top/bottom than gain in left/right. FACAR ---> less black borders in top/bottom with facar(the real gain)and "invisibles" left/right borders in tv! ps: in the end what someone can think or feel as "loose" using Facar is the "true gain"! that pictures are some more prooves,only need atention in all details! i was clear? big thanks! edited> r6d2, my good conclusion and personal taste about your great job is posted in the last post of that page and in the first 2 posts in the next page (more will be posted later): http://kvcd.net/forum/viewtopic.php?...er=asc&start=0 |
23rd June 2006, 14:39 | #95 | Link |
New Resizers added
Anyone still using FACAR? I certainly do for my AVI2DVD conversions. Very convenient for cropping off station logos and playing with different filters and resizers.
AviSynth 2.56 introduced two new resizers: GaussResize and SplineResize. A sharper version of LanczosResize (called Lanczos4Resize) is also included. So I decided to modify FACAR to support Lanczos4Resize and Spline36Resize. If anyone is interested, you can download the modded version at http://scifi.pages.at/manolito/FACAR...ate_1.06.8.zip ResizeMethod=6 is Lanczos4Resize, ResizeMode=7 is Spline36Resize. The debug modes for previewing the different resizers are also modified to display 6 resizers now instead of 4. Cheers manolito Last edited by manolito; 23rd June 2006 at 14:43. |
3rd July 2006, 20:38 | #96 | Link |
im still using it for the very same purpose
is there any significant improvement ?
i read - i dont understand - i try anyway - and get there in the end with the help of the DOOM9 forums |
10th July 2006, 22:33 | #97 | Link | |
Cheers manolito |
