13th August 2011, 02:45 | #7241 | Link | |
17th August 2011, 18:37 | #7243 | Link |
ps3z - did your file had to be recropped to 1920x1080?
I had the same issue with a couple of movies with the recropping hard burned the subtitle tracks to the movie for no appearant reason (the settings said not to, but it did anyway). The only way I found to overcome this was to demux the film, remux without any subtitle tracks (keep the subtitle tracks), then recrop, then use multiAVCHD and add the subtitles as external. As for my previouse problem - it's getting too complicated for me. I'll just wait for someone to figure out how to make tsMuxer work nicely with TrueHD tracks. For another issue - I have a vorbid track (commentaries) that I wish to add to a movie. tsMuxer doesn't recognize the track, but multiAVCHD does, as well as mkvmerge, mkvextract, etc. I made a blu ray disc, the track was there. BUT when multiAVCHD finished, the track didn't appear in the video. The original DTS sound plays fine, but the vorbit track simply isn't there. I tryed different settings, like using the ac3to tab and set it to turn non HD sound to ac3 640, but it didn't work. Is there a freeware that can turn the vorbid track to an ac3 track? Or any other way to overcome this, I guess? |
17th August 2011, 21:19 | #7244 | Link | |
@dror.sharon5
Hi! Quote:
18th August 2011, 20:12 | #7245 | Link | |
hello dror.sharon5 subtitles are not hardcoded or forced but its doing like that.like without reason.i couldnt find any solution.it does for sup files but not for srt files etc....
maybe sup maker program does itself,i have to type to developer. Greetings ps3z Quote:
25th August 2011, 07:12 | #7247 | Link |
Dean (and Adub),
Being helped tremendously by Adub's video screencast for multiAVCHD. Thanks a million! Two problems: 1) As soon as I click "NO" at the "Do you want to re-author?" popup, I'm getting a "Cannot open file" error (Line 55) instead of multiAVCHD starting its search of a BDMV directory for playlists. 2) There is no _LOG folder or file as described in your tutorial (...\_LOG\DATETIME-multiAVCHD.log). 3) Earlier today, before relaunching the program now, I had the playlists loading just fine from the same ISO, but there was no "remove" option once loaded. Both earlier and now, I'm loading this from a CloneDrive mounted ISO, where the ISO is located on an external drive. The only other tampering I've done is to offload the _TEMP folder to a separate volume from where multiAVCHD is stored, so as not to run out of room. (C is where the exe is installed, D is where _TEMP is, though the folder's empty.) Again, apart from the no "remove" option, there was no trouble doing this earlier. Let me know what to do next. I might just reinstall (sigh). Last edited by a.k.a.; 25th August 2011 at 07:15. |
25th August 2011, 10:59 | #7248 | Link |
I have a question about 3D.
Can we make Real3d output? i have tested, but the results are always 2D. I think it is not possible, but can someone confirm this for me? What i do is the following: I import a BDMV 3d map. I make none specific configuration, only a top menu. Then i output it to PS3. The movie works, but only 2D. |
26th August 2011, 09:48 | #7249 | Link |
I created a DVD image and everything worked fine. Since then, everytime I try to start the program it only starts minimized in the task bar and I can't get the program to open its normal window.
The program also doesn't crash because when I just press 'enter' after starting the program I'm asked to choose the file to be opened - it seems that I hit the 'add video files' button. Afterwards I still don't see the program windows although there is no error message. Can anybody please tell me how to get the program started (showing its window) again? |
26th August 2011, 23:40 | #7252 | Link |
@icegue
1) Did you remember to click "OK"? 2) If you NOW rightclick on the file and select "Properties", what does it NOW say next to "Run"? If it says "Normal Window", reboot your system and see if the program then sets up properly... |
31st August 2011, 13:15 | #7255 | Link |
How can I back up DVDs
How can I back up DVDs with multiAVCHD and put them on a BD? So far I have tried to make MKVs out of them and created a BD, but the 4/3 aspect ratio was gone and it was displayed at 16/9. I carfully did put only 4/3 files together but in vain.
Any good idea how I can create a BD with a correct display of 4/3 aspect ratio? |
1st September 2011, 16:44 | #7260 | Link |
I have a Windows 7 64-bit computer. I used MakeMKV to convert a BluRay disk to an MKV file, then split it into 7 files using mkvMergeGUI (so I could rearrange the order), then loaded all 7 files into multiAVCHD to make a new BluRay disk. A few seconds after pressing Start, multiAVCHD hung with an error message "tsMuxer.exe has stopped working. Windows will close the program and notify you if a solution is available." I had to close multiAVCHD and tsMuxer with Task Manager. Can anyone provide a solution? Here is the MediaInfo report on the first of the seven MKV files:
General Unique ID : 187423654740983734255791377375122371428 (0x8D007B9F05561843924BC2F901CF3364) Complete name : F:\BB MakeMKV\Concerto 1.mkv Format : Matroska Format version : Version 2 File size : 3.49 GiB Duration : 18mn 29s Overall bit rate : 27.1 Mbps Encoded date : UTC 2011-08-31 01:06:36 Writing application : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15 Writing library : libebml v1.2.1 + libmatroska v1.1.1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Muxing mode : Header stripping Codec ID : V_MPEG4/ISO/AVC Duration : 18mn 29s Bit rate mode : Variable Maximum bit rate : 28.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Language : English Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio #1 ID : 2 Format : PCM Codec ID : A_PCM/INT/LIT Duration : 18mn 29s Bit rate mode : Constant Channel(s) : 2 channels Sampling rate : 48.0 KHz Bit depth : 16 bits Title : 2/0 Language : German Audio #2 ID : 3 Format : PCM Codec ID : 00001000-0000-0100-8000-00AA00389B71 Codec ID/Hint : Microsoft Duration : 18mn 29s Bit rate mode : Constant Bit rate : 4 608 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 609 MiB (17%) Title : 3/2+1 Language : German Menu 00:00:00.000 : en:Chapter 00 00:00:47.047 : en:Chapter 01 00:04:36.409 : en:Chapter 02 00:07:42.395 : en:Chapter 03 00:11:35.094 : en:Chapter 04 |
