31st July 2010, 20:17 | #6201 | Link |
As my mother used to say, "Take your eyes in your hands and look!"
Talk about hiding in plain sight ;>} Thanks - But why CAN'T it be another "per-title" option? It only takes effect if such a track is discovered, just like the other default audio settings, doesn't it? |
31st July 2010, 20:20 | #6202 | Link |
Programmer (or just 教务长)
It certainly can, but most people want per-title options and not per-compilation.
There is an option in Subtitles&Audio to convert HD audio to AC3, which should give similar results to what you need. Dean |
31st July 2010, 21:11 | #6206 | Link |
Updater errors and suggestion
I don't know if the updater logs what it does somewhere, but it had issues with the first place that it tried to go to and failed with the next 4 mirrors.
For example: Trying next mirror... Downloading... URL: Mirror#2 HttpSendRequest error HttpQueryInfo: 12019 Error! (0) The HttpQuery error line only showed up with mirror #2. It seems to be downloading from mirror #5, as there are no errors, and nothing else to indicate that it is, or isn't, working. The suggestion: Don't put out a message that it is downloading unless it is really downloading, i.e., the connection was fully established and the file it is after is really being downloaded. In other words, something like: Trying next mirror... URL: Mirror#2 Downloading... Thanks. |
31st July 2010, 21:22 | #6207 | Link |
multiAVCHD no longer works
Here is the complete session log:
Initialising... Checking... Downloading... [14:56:38] Connecting... [14:56:40] Connect failed! [14:56:40] Connecting... [14:56:47] Connect failed! [14:56:47] Connecting... [14:56:49] Connect failed! Error! (500) Trying next mirror... Downloading... URL: Mirror#1 HttpSendRequest error Error! (0) Trying next mirror... Downloading... URL: Mirror#2 HttpSendRequest error HttpQueryInfo: 12019 Error! (0) Trying next mirror... Downloading... URL: Mirror#3 HttpSendRequest error Error! (0) Trying next mirror... Downloading... URL: Mirror#4 HttpSendRequest error Error! (0) Trying next mirror... Downloading... URL: Mirror#5 InternetReadFile failed for http://multiavchd.deanbg.com/multiAVCHD.exe Done! After the done, another updater GUI poped up with the following message: (RT) Application "C:\multiAVCHD\multiAVCHD.exe" cannot be executed - Line 148. Sure enough, multiAVCHD is broken. I'll have to install from a previous download and try the update again. Is there a way to make the updating process more robust so that the current installed version isn't corrupted? UPDATE: Tried it again. This time it started the download from mirror #2, But this time got the InternetReadFile failure on the RAR file. multiAVCHD.exe gone again. Third try resulted in the same failure at mirror #2. Going to go fetch the latest version manually. Last edited by MrVideo; 31st July 2010 at 21:50. Reason: Added info |
31st July 2010, 22:27 | #6212 | Link | |
Just a thought. |
31st July 2010, 22:32 | #6213 | Link | |
Now that you're aware of the file's (probable) existence, why don't you simply try what I suggested? |
31st July 2010, 22:45 | #6215 | Link | ||
Still doesn't mean that the automatic updating process can't be made more bulletproof. Last edited by MrVideo; 1st August 2010 at 01:07. |
1st August 2010, 03:37 | #6216 | Link |
My First Project
Ya, I know, I've been posting for a while, but haven't had the time to actually sit down and work on a project. Well, today I am.
I have the latest build (762). I encoded the H.264 file myself, creating a 1080p23.976 MKV wrapped program. The audio is AC3 - 2.0. ########## I just crashed mAVCHD getting it to use a chapter list text file. It complained about not being able to read all of the delimited text. It is a text file that was created by VideoReDo and is a simple file with one timecode entry per line. There are eight entries in the format hh:mm:ss:ff. With the frame being 00 through 23. Why does mAVCHD use 3-place decimals for the frame? That is not industry standard. Is there an option to tell mAVCHD to use the industry timecode standard? ########## Now I get to start the project over again. This time I will save the project before dealing with the chapter marks. Last edited by MrVideo; 1st August 2010 at 07:41. Reason: Removed pieces that I found the answers for |
1st August 2010, 08:09 | #6217 | Link |
I added HH:MM:SS:FR support - you'll get it in the next update.
multiUPDATE is updated to use different servers. multiAVCHD will automatically download and update multiUPDATE. Last edited by deank; 1st August 2010 at 08:35. |
1st August 2010, 09:19 | #6218 | Link |
deank - is there any chance you could add an option in fit all to reduce any HD audio to AC3 (as a 1-off setting for that kind of project)? I know theres an overall option for that but for most discs I'm not bothered. However, if I'm trying to fit an MKV on a DVD-5 I do often want to reduce the audio size to get more video bitrate.
Edit: Is fit all even taking the reduce audio setting into account? With it enabled, the bitrate appears to be no different? The suggested DVD5 setting in transcode is much higher than the fit-all suggested bitrate (and the AR appears to be off too!) http://i29.tinypic.com/xd8k5s.jpg Last edited by rendez2k; 1st August 2010 at 09:36. |
1st August 2010, 09:41 | #6219 | Link |
When dealing with one title only I'd suggest that you use "Bitrate suggestions" option in [transcode] window. There you get quite accurate bitrate values, taking audio conversion into account.
About the AR: use compliant files. If not - open [transcode] and make sure all is set properly. multiAVCHD can't magically always do everything for everyone and every video file - it is not a one-click-application after all. Last edited by deank; 1st August 2010 at 10:18. |
1st August 2010, 13:18 | #6220 | Link | |
