Old 25th November 2009, 07:13   #9581  |  Link
AnryV
Originally Posted by Thunderbolt8 View Post
afaik its a bug of the arcsoft decoder, we've already had this example that it cannot handle dts-hd ma 1.0 files
What about Sonic decoder?
AnryV is offline
Old 25th November 2009, 07:20   #9582  |  Link
asc28
Is there any way to recalculate and add back dialog normalization to AC3 tracks, after eac3to has stripped them?
[edit] realized that many studios use an arbitrary figure, so might not be able to recalculate. But how about using a ReplayGain like technique to find the optimal dB to be added and then adding it to an already encoded AC3 track?
Also, I know this has been asked a couple times before, but no one seems to know how exactly to go about reinserting dialnorm metadata without re-encoding.
asc28 is offline
Old 25th November 2009, 09:59   #9583  |  Link
Esurnir
I'm going to sound dumb, but which product from arcsoft still include the DTS-HD filter decoder? Does TotalMedia Theater 3 work ? Any special editions? (platinum?)
Esurnir is offline
Old 25th November 2009, 19:30   #9584  |  Link
Thunderbolt8
dont know to be frank.
Thunderbolt8 is offline
Old 27th November 2009, 05:44   #9585  |  Link
IanD
I've been converting a DTS HD MA and DD2.0 soundtrack to wav with Eac3to, using -core and -down2 for the first, in order to align them.
However neither of the resulting wav files are directly readable by Goldwave, Cooledit or CDwave as it seems they are "raw". No matter what bit depth, signature or sample rate I choose, I only get noise. Strangely I am able to play the wav files with Directshow no problem.
How do I make the wav files readable in the sound editor applications?
It's frankly annoying that the output isn't wav standard.
IanD is offline
Old 27th November 2009, 09:39   #9586  |  Link
kypec
User of free A/V tools
kypec's Avatar
Try to add switch -simple and see if it helps your applications to recognize such stereo WAV files. If yes then you should blame those apps that they don't support standard WAV headers.
kypec is offline
Old 29th November 2009, 01:01   #9587  |  Link
tebasuna51
tebasuna51's Avatar
GoldWave (from v5.02, 2004? ) read WAVE_FORMAT_EXTENSIBLE headers without problems.
tebasuna51 is offline
Old 30th November 2009, 04:40   #9588  |  Link
73ChargerFan
73ChargerFan's Avatar
Perhaps the DTS core is being converted to a dts-wav file, instead of being decoded?
eac3to (DTS or DD file) filename.wavs should decode, one channel per file.
73ChargerFan is offline
Old 30th November 2009, 12:35   #9589  |  Link
IanD
Using -simple seems to have done the trick and both converted DTS HD MA and DD2.0 source files are now recognised as stereo wav.
However, I'm experiencing problems trying to synchronise the tracks: the DTS HD MA soundtrack is identified by eac3to as 24fps (not 23.976fps), whilst the commentary track I'm trying to synchronise to it is from a PAL source. Using the switches -25.000 and -ChangeTo24.000 results in the commentary being about 500ms longer than the soundtrack when the beginnings are synchronised.
I thought it might be possible to use the source switch -24.99x to fine tune the commentary conversion, in case the PAL source is not quite 25fps, but eac3to refuses to accept anything other than -25.000
Any thoughts?
Unfortunately I don't have access to an NTSC commentary, only a PAL one. It's quite close at the moment but not close enough because the commentary also has parts of the soundtrack that need to be in-sync with the on-screen action.
IanD is offline
Old 30th November 2009, 20:53   #9590  |  Link
Vick
Many thanks to Christopher Key for providing the HDCD decoder!
Hi madshi
Whether Chris has given you the HDCD decoder source code?
He does not respond to email (cjk32 cam ac uk)
Thnx
Vick
p.s. sorry for my poor english
Vick is offline
Old 30th November 2009, 22:40   #9591  |  Link
pcordes
hard to use under Wine on GNU/Linux
I'm an old-school GNU/Linux command line junkie. Running eac3to inside
screen, the output comes out like this:
$ alias eac3to='wine /usr/local/.../eac3to.exe'
$ eac3to foo.eac3
fixme:mixer:ALSA_MixerInit No master control found on HDA ATI HDMI, disabling mixer
fixme:reg:GetNativeSystemInfo (0x32fc80) using GetSyE-AC3, 5.1 channels, 0:31:59, 1536kbps, 48khz
# or, discarding wine's messages: eac3to 2>/dev/null
$ eac3to 2(1) Haali Matroska Muxer
I spent a while looking for --help output, until I eventually realized that its output was designed for a Windows command window, not a VT100 terminal emulator. It happens to work outside of screen, in just gnome-terminal, and in native xterm, though.
eac3to outputs a bunch of ^h (ascii 0x08) characters at the start of every line, and maybe under screen, reverse-line-wrap happens, and the cursor backspaces up to the previous line, so every line of text overwrites the one before. If I redirect the output to a file,
$ eac3to > eac3to.txt  2>/dev/null
$ file eac3to.txt
eac3to.txt: ASCII English text, with CRLF line terminators, with overstriking
$ hexdump -C -v eac3to.txt
00000000  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
00000010  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
00000020  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
00000030  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
00000040  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
00000050  20 20 20 20 20 20 20 20  20 20 20 20 20 20 0d 0a  |              ..|
00000060  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
00000070  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
00000080  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
00000090  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
000000a0  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
000000b0  20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20  |                |
000000c0  20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20  |                |
000000d0  20 20 20 20 20 20 20 20  0d 0a 08 08 08 08 08 08  |        ........|
000000e0  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
000000f0  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
00000100  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
00000110  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
00000120  08 08 08 08 08 08 08 08  08 08 65 61 63 33 74 6f  |..........eac3to|
00000130  20 76 33 2e 31 37 2c 20  66 72 65 65 77 61 72 65  | v3.17, freeware|
00000140  20 62 79 20 6d 61 64 73  68 69 2e 6e 65 74 20 20  | by madshi.net  |
00000150  20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20  |                |
00000160  20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20  |                |
00000170  20 20 20 20 20 20 20 20  20 0d 0a 08 08 08 08 08  |         .......|
00000180  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
00000190  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
000001a0  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
000001b0  08 08 08 08 08 08 08 08  08 08 08 08 08 08 08 08  |................|
000001c0  08 08 08 08 08 08 08 08  08 08 08 20 20 20 20 20  |...........     |
000001d0  20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20  |                |
000001e0  20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20  |                |
000001f0  20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20  |                |
00000200  20 20 20 20 20 20 20 20  20 20 20 20 20 20 20 20  |                |
00000210  20 20 20 20 20 20 20 20  20 20 0d 0a 08 08 08 08  |          ......|
But the overstriking doesn't have any effect anywhere: xterm or gnome-terminal. (it visually looks the same as regular text). In VT100, ^h is cursor-movement, not highlighting. If eac3to is doing that itself on purpose, please don't, at least under wine. The CRLF line endings are not a problem.
I'd also love to have an option to not play sound. I haven't tried just renaming the .wav files. Maybe you could add a -unix option, or check an environment variable, to turn off sound and not print funky text. It's harder to deal with options at the end, instead of as the first arguments (e.g. an alias doesn't work), but a wrapper script like
#!/bin/sh
wine /.../eac3to.exe "$@" -unix 2>/dev/null
# or use a wine cmdline arg to filter out the messages it always prints, instead of redirecting to /dev/null
would do the trick.
apparently, wine devs
don't want apps to detect wine, so the -unix option would be a nice feature. Or have a -nosound option, or a -quiet option. (OTOH, -quiet usually means no messages, not literally quiet.) I'm worried that -nosound would cause confusion, though, since someone might think it means exclude audio tracks. But it's -nosound, not -noaudio...
Anyway, that's my feature request, please and thank you.
pcordes is offline
Old 1st December 2009, 02:09   #9592  |  Link
samepaul
samepaul's Avatar
I encounter problem. During THD -> AAC encoding the warning "Clipping detected, a 2nd pass will be necessary." is written and then eac3to indeed performs 2nd pass, making final audio very quiet and practically useless. Is there way to ignore clippings and avoid "2nd pass"?
Also eac3to writes "Reducing depth from 64 to 32 bits". What does it mean? Looks like volume related issue as well... if so, is it possible to prevent this downgrading too?
samepaul is offline
Old 1st December 2009, 03:10   #9593  |  Link
tebasuna51
tebasuna51's Avatar
You can add the parameter:
-no2ndpass
but is a very little diferent volume.
Is the size of the audio sample, trust in eac3to, NeroAacEnc don't support 64 bit float audio samples.
Old 1st December 2009, 04:35   #9594  |  Link
samepaul
samepaul's Avatar
-no2ndpass
Thank you! It did the magic - volume remained good. Seems anti-clipping algorithm requires some improvements
samepaul is offline
Old 1st December 2009, 21:26   #9595  |  Link
tebasuna51
tebasuna51's Avatar
... Seems anti-clipping algorithm requires some improvements
Then there are big volume difference ...
Please, can you upload a sample?
Old 1st December 2009, 22:33   #9596  |  Link
samepaul
samepaul's Avatar
Seems you're right. I tried to notch the place where clipping occurs, cut it out and encoded with and without 2nd pass.
There was difference in volume, but not so dramatic as it was when whole track was encoded. So I don't think that these samples are good for debugging.
I think it's not completely fault of encoder. I guess the track has places with really hard overload, but when eac3to performs 2nd pass it lowers volume of whole track evenly. Of course, after this previously clipped parts (blows, shootings etc) sound better, but "normal" parts where people talk become indiscernible. If I have tool to detect exact places where eac3to detects maximal clipping I would prepare sample for you. But without this I'd have to submit whole 700mb track , which I don't know how to do.
Btw, I've mistaken when I wrote "TrueHD". It was actually AC3.
But nevertheless, regarding to volume optimization, I think if eac3to performs 2 passes it can normalize levels non-linearly.
samepaul is offline
Old 2nd December 2009, 01:06   #9597  |  Link
honai
Posts: n/a
... which is called Dynamic Range Compression (DRC) and is ignored by eac3to by default. DRC means you lose fidelity, and that is certainly not desirable if you want to preserve the quality of the original audio track.
Old 2nd December 2009, 01:38   #9598  |  Link
samepaul
samepaul's Avatar
Uhum... and making audio quiet so much that you hadly can distinguish what people say - this is what you call "high fidelity"? If so, I'd stick with normal fidelity
1st of all, DRC does not lower fidelity more than any volume adjustment, which is done by eac3to anyway. And really negligible comparing to quality loss due to audiocompression.
2nd, what I propose is not really DRC. Range compression only performed around overloaded zones, leaving ~90% (depending on content) of audiotrack intact.
samepaul is offline
Old 2nd December 2009, 02:14   #9599  |  Link
IanD
The switches -25.000 (source) and -ChangeTo24.000 imply that they are floating point values that "may" accept any floating point value, but in fact seem to be hardcoded to -23.976, -24.000 and -25.000 and nothing else is accepted.
Is there any way to define variable floating point values to finetune these parameters?
Is there an alternate way to perform non-standard resampling and time expansion/compression?
IanD is offline
Old 2nd December 2009, 03:35   #9600  |  Link
tebasuna51
tebasuna51's Avatar
To make the job eac3to use SSRC libraries to change the audio samplerate.
And not all conversion are possible. You can know available values here: http://avisynth.org/mediawiki/SSRC
There are commercial software like TimeFactory
And also AviSynth methods like TimeStretch
eac3to
