Old 28th April 2019, 01:25   #201  |  Link
hotripper
Originally Posted by semi70 View Post
I have a 2080 and I have the stutter issue too. I have no problems at all when im on the 418.91 driver. everything after that version I have the stutter issue. madvr is not reporting any problems and I tried every proposed fix posted here with no improvements.
when im in windowed mode there is no stutter too. it seems to be a full screen exclusive mode issue.
its a shame Im stuck on this driver now that they have released a HDR fix on the latest too.
Yep sounds exactly like what I was experiencing. My fix has worked for me. Sorry it didnt work for you. I cant go back to that driver, I game a lot and don't really wanna miss those updates as I actually play the ones they improved. And I have tried that driver and it only fixed it temporarily but after a couple of restarts over a few days it just came back. So might as well have latest driver, for me anyways. Seems like madvr might need a new update for the new cards but I believe he is busy with his project atm.
Havent noticed Nvidia container using high cpu, and I have been watching during trying to trubleshoot the stutter issue.
3700X - RTX2070 - 970EVO - EVGA Supernova 750W Gold - Sony KD55X720E
hotripper is offline   Reply With Quote
Old 28th April 2019, 10:23   #202  |  Link
el Filou
el Filou's Avatar
I think the Display Container LS only happens if you use standby/sleep.
Old 28th April 2019, 10:55   #203  |  Link
Klaus1189
Originally Posted by Manni View Post
And when did that last happen?
What makes you think it will be any different in the future?
This thread really show the poor state of drivers/OS incompatibilities.
Frankly, they could have released a driver with everything working (HDR passthrough and HDR API in 8bits) before axing 3D... but they didn't.
Well, ... there is nothing that needs to be added, except at least the devs should be paid great for their work if I consider the prices of the green cards.
@all:
What is exactly the problem some guys here have with AMD cards? I have several different ones here, I know these are not the fastest, but I am happy with them and these were not expensive.
Old 28th April 2019, 13:02   #204  |  Link
DMU
Originally Posted by Klaus1189 View Post
@all:
My problem is described here.
DMU is offline   Reply With Quote
Old 28th April 2019, 13:09   #205  |  Link
Klaus1189
Thank you, what file were you playing? Does it occur on hdr demo videos as well, so I can test, too? Maybe you can provide a link to a HDR file. Are you using HDR passthrough or processed in madVR?
Old 28th April 2019, 13:38   #206  |  Link
DMU
File here.
HDR passthrough.
Post about your results, please.
Old 28th April 2019, 13:59   #207  |  Link
Klaus1189
Cannot download file, seems it has too many downloads.
I search for other sources. Do you have another source?
Old 28th April 2019, 14:15   #208  |  Link
DMU
Lets try from here.
Old 28th April 2019, 14:42   #209  |  Link
ashlar42
Anyway I'm in the process of moving away from the HTPC altogether for film playback, provided that Envy delivers what we expect. Too much hassle really between OS, drivers and other issues.
And what do you plan on using, if I may ask? I don't see much around supporting everything correctly.
One needs bitstreaming for all audio formats, proper HDR with metadata and autoswitching, proper refresh rates with autoswitching... is there something around that offers all that?
Old 28th April 2019, 17:06   #210  |  Link
Klaus1189
It is not darker here. Only in FSE the composition rate is 60 which is wrong, but I don't know if it is an AMD issue or an Win 10 1809 issue, older versions of Win10 didn't had this issue. But it doesn't bother me, since I am fine in FSW, also the other issue is not relevant in FSW.
I tried to take screenshots directly but if you use passthrough the final pic is not displaying it right and in FSE I only got black picture, silly me, I knew that but forgot about it.
https://drive.google.com/drive/folde...O4?usp=sharing
I do get wrong colors in FSE, see also this issue on videohelp.com and also here here, FSW are the right colors. It also happens on SDR videos, I have a sample video of natural green grass which shows it perfectly. If it is shown wrong it gets very unnatural green, see also the color pattern in one of the videohelp threads.
Side note: Please use matching refresh rates, on your pics you were using 60 Hz for 23 Hz content. Avoid 3:2 Pulldown. But maybe you are using motion interpolation in madVR? Some love it some hate it.
Old 28th April 2019, 17:35   #211  |  Link
DMU
It is not darker here. I am fine in FSW.
I assume that you have Polaris, not Vega?
I understand this, but it does not cause me inconvenience.
I do not use Smooth motion.
Old 28th April 2019, 17:39   #212  |  Link
Klaus1189
Yes, Polaris RX480. I have a Vega 64 also here, but can not test now.
Just take a look at 50p videofile displayed at 60 Hz, it looks awful, especially during pans. I can only recommend using matched refresh rates. In my opinion one of the most important things.
Old 28th April 2019, 17:48   #213  |  Link
DMU
If possible, check this at Vega later. I think this is a problem of Vega.
Thank you for your recommendations. But I do not use content with a frequency of more than 30p.
Old 28th April 2019, 20:14   #214  |  Link
Manni
Off topic, but yes, I have an Oppo 203 clone (no disc) that does all that perfectly, and I'm working with a software developer friend at the moment to get a better interface from an iPad with a popular front end, as the Oppo 203 wasn't supported.
All the other media players I've looked at have issues with video and/or audio. The Dune Pro 4K could have been a great option but it doesn't look like it will ever work properly with the current chipset.
We've managed to get DVD/BD/UHD BD Folders working with this Oppo 203 clone. Files (mkv, ISOs) are a no go for now, but I already have all my discs ripped as folders anyway. I'll simply have to convert my 300 3D BD ISO rips to BD folders if we don't find a solution to play files (this is a limitation on the Oppo app itself, so hard to overcome as we have no command to sniff on the network). This will cost storage for 3D (double the space vs ISOs), but as my 3D collection isn't really growing, not too much of an issue. That won't help you if all your collection is in mkv or ISOs and if you're not willing to convert it.
Of course this will only work when/if the Envy lands, there is no way I can use this without a 3D LUT and HDR dynamic tonemapping with pixel shaders. At least not with my JVC projector, as the tonemapping is ok but far from being as good as what madVR delivers.
So for now, my HTPC is still very much necessary, but hopefully not for long .
EDIT: funnily enough, this is the post of the devil: my post count is 666 as of now
Win11 Pro x64 b23H2
Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33
madVR/LAV/jRiver/MyMovies/CMC
Denon X8500HA>HD Fury VRRoom>TCL 55C805K
Old 29th April 2019, 11:28   #215  |  Link
ashlar42
Oppo 203 clone? Details in PM, if you can. Edit: don't worry I've found everything. After more than a decade of Kodi, I could not go back to a GUI like that but it's a very interesting development, for sure.
I lured you here, son. There's no escaping now. Surrender to the dark side.
Old 29th April 2019, 13:06   #216  |  Link
Manni
You must have missed the part where I mentioned the work I'm doing to get this supported with a very popular front end on any tablet, phone etc, so that you can select the title you want to watch on a modern, beautiful interface and get it to play on the clone.
Unfortunately this requires a PC/laptop as a bridge between the tablet/phone and the clone, but the result is great: pretty and fully-featured interface on iPad (search, categories, genres, etc), flawless playback for all content, zero driver/OS headaches
Again, not an option for me until Envy lands, but very much looking forward to testing this combo.
Sorry everyone for the OT, let's move on
Win11 Pro x64 b23H2
Old 29th April 2019, 16:15   #217  |  Link
Klaus1189
Manni, just one last time offtopic. What App are you using with your clone 203? Do you have any link for the app and the clone. I got it that there is work to do, but maybe I could need at least one thing of these in future for anything. I am open to see new things.
Old 29th April 2019, 16:41   #218  |  Link
cremor
Important note about 430.39:
Many users (myself included) report about high CPU usage of the process NVDisplay.Container.exe. Nvidia acknowledged the bug here: https://forums.geforce.com/default/t...36972/#6036972
cremor is offline   Reply With Quote
Old 29th April 2019, 19:18   #219  |  Link
Asmodian
Interesting, may be related to the stutter some users are also experiencing? I do not see any CPU usage by NVDisplay Container, all instances of it show 0% CPU usage, and I do not have stuttering.
madVR options explained
Old 30th April 2019, 00:02   #220  |  Link
hotripper
May be a sleep issue
I dont think it has anything to do with the stuttering issues, I have stuttering but do not see ANY apps or services utilizing cpu abnormally
