Old 14th June 2015, 17:52   #1  |  Link
reigan42
x264 lossless and presets
Hi, i'm using footage from an hdpvr2 that has x264/aac in m2ts container and I was wondering does it negatively affect quality in lossless x264 to use ultrafast preset over slower?
reigan42 is offline   Reply With Quote
Old 14th June 2015, 18:24   #2  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Lossless is lossless. Only size and speed changes with presets.
Old 14th June 2015, 18:30   #3  |  Link
reigan42
Thanks that helps me out alot
Old 15th June 2015, 08:21   #4  |  Link
neil wilkes
neil wilkes's Avatar
Yes it does make a difference.
There is no such thing as lossless 264 - it's a data reduced codec.
www.opusproductions.com
Multichannel Audio Productions
DVD-Audio/Video Authoring specialists
neil wilkes is offline   Reply With Quote
Old 15th June 2015, 08:51   #5  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
Of course there's - H.264 has special profile that supports all features needed for lossless encoding (which x264 of course supports).
vivan is offline   Reply With Quote
Old 2nd July 2015, 03:31   #6  |  Link
F J Walter
As mentioned, h.264 has features that allow for lossless encoding but few encoders support it, but x264 does. In x264 it's activated by setting QP to 0. When used, the video is encoded so that it can be decoded to a result that is bit-identical with the source of same chroma resolution. It switches to a special lossless macroblock coding mode where QP is not actually relevant, but it still benefits from the motion estimation searches, reference frames and so forth.
F J Walter is offline   Reply With Quote
aac, lossless, x264
