Old 9th January 2017, 14:40   #2801  |  Link
Reel.Deel
Originally Posted by dipje View Post
Isn't it possible and an idea to port fmtconv from vapoursynth to avs+? Would give you all the resizers, kernels, chroma conversion, matrix conversion, gamma space conversion and dithering tools you would I guess.
There's already z.lib resizers: http://forum.doom9.org/showthread.php?t=173986
Reel.Deel is offline
Old 9th January 2017, 15:51   #2802  |  Link
pinterf
Originally Posted by Wilbert View Post
Was asking about the output. Apperantly the code is in main.cpp (*), but i don't know that part well enough to tell what and how it should be updated.
(*) see CAVIStreamSynth::Info, CAVIFileSynth::ImageSize, CAVIStreamSynth::ReadFrame and CAVIStreamSynth::ReadFormat.
Thanks for the hints. Made some tests with vdubmod14.
ConvertToYV16().ConvertBits(16)  # 1st frame OK, crash when play
ConvertToYV12().ConvertBits(16)  # P016 unknown
ConvertToYV12().ConvertBits(10)  # P010 unknown
ConvertToYV16().ConvertBits(10)  # 1st frame OK, crash when play
ConvertToRGB32().ConvertBits(16)  # BRA[64] OK, upside down
ConvertToRGB24().ConvertBits(16)  # BGR0 unknown (could not locate decompressor)
For BRA[64] I had to reverse the output though (in avisynth internally it's upside down like RGB32)
pinterf is offline
Old 9th January 2017, 16:03   #2803  |  Link
odyssey
I have a minor issue with plugin loading in Avisynth+
Plugins loaded with absolute path works fine, but if they are just loaded with their name, it complains that it can't find the plugin in the current working dir. It never searches for it in the plugins directory.
E.g. LoadPlugin("DGMVCDecode.dll")
If I comment it out, it works, because it finds it in the plugins directory when calling the function.
Perhaps this should be fixed, so it behaves the same way as normal Avisynth?
odyssey is offline
Old 9th January 2017, 16:11   #2804  |  Link
shekh
Crash in which module? With VapourSynth P210/P216 worked for me.
VirtualDub2
shekh is offline
Old 9th January 2017, 16:27   #2805  |  Link
Groucho2004
Works fine for me. What do you use to load the script? VDub, mpchc, x264?
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 9th January 2017, 16:35   #2806  |  Link
pinterf
I don't know. Not in avisynth. Works for single step forward or backward.
I will build a 32 bit test soon.
pinterf is offline
Old 9th January 2017, 17:01   #2807  |  Link
pinterf
New test build: Avisynth+ r2367
20170109 r2367dev
  • VfW: BRA[64],b64a,BGR[48],P010,P016,P210,P216,Y3[10][10],Y3[10][16],v210
    experimental, just to have feedback
    Default format FourCCs:
    RGB64: BRA[64]
    RGB48: BGR[48]
    YUV420P10: P010
    YUV420P16: P016
    YUV422P10: P210
    YUV422P16: P216
    Use these global variables to override default formats:
    OPT_Enable_V210 = true --> v210 for YUV422P10
    OPT_Enable_Y3_10_10 = true --> Y3[10][10] for YUV422P10
    OPT_Enable_Y3_10_16 = true --> Y3[10][16] for YUV422P16
    OPT_Enable_b64a = true --> b64a for RGB64
  • Overlay: blend for float format
  • Overlay: blend: SSE4 for 10-16 bit, SSE2 for float
  • AddAlphaPlane: also accepts clip with Y-only or alpha (YUVA/PRGBA/RGB32/64) for alpha source
    (was: optional int/float mask value)
pinterf is offline
Old 9th January 2017, 17:03   #2808  |  Link
tuanden0
Can someone help me the filter fft3dGPU crashed if I use SetFilterMTMode("FFT3dGPU", 3)
Here is my script:
SetFilterMTMode("LWLibavVideoSource", 3)
SetFilterMTMode("gradfun2dbmod", 2)
LWLibavVideoSource("E:\Download\test.mp4")
AssumeFPS(24000, 1001)
#Denoise
FFT3DGPU(sigma=4,bt=3).gradfun2dbmod()
Prefetch(6)
tuanden0 is offline
Old 9th January 2017, 18:34   #2809  |  Link
shekh
I can produce a crash with input pane. Will take some time.
Fixed (build 38494).
VirtualDub2
shekh is offline
Old 9th January 2017, 19:24   #2810  |  Link
shekh
I see bigendian tags:
[10][10]3Y
[16][10]3Y
VirtualDub2
shekh is offline
Old 9th January 2017, 19:36   #2811  |  Link
jpsdr
I think it would be great if (at least) the formats RGB64, YUV422P10 and YUV422P16 would be exposed through the VfW interface. Then we can open such scripts in Virtualdub and encode straight to MagicYUV (without any color conversion).
How do you "open" in VDub this kind of avs script ?
Configure video in "DirectStream Copy" ?
I think there will still be an issue with the "Output format to compressor/Display" in Video Color Depth. How do you configure this one ?
Because even if the Compressor can handle it, what about the display ? Disabling both Output and Input Video Pane ? Because the display will probably be possible only with color format VDub understand.
It could be interesting, i'm curious to see how you think you may work and configure VDub for this kind of files.
jpsdr is offline
Old 9th January 2017, 20:33   #2812  |  Link
Reel.Deel
@jpsdr
Use shekh's VirtualDub mod: https://forum.doom9.org/showthread.php?t=172021
Old 9th January 2017, 20:58   #2813  |  Link
pinterf
[10][10]3Y
[16][10]3Y
Isn't is normal? It is encoded the same way as all the others.
012P = P210
008Y = Y800
[16][10]3Y = Y3[10][16]
etc...
pinterf is offline
Old 9th January 2017, 21:26   #2814  |  Link
shekh
012P = P210
008Y = Y800
etc...
This is strange but these literals are translated differently.
'610P' -> 'P','0','1','6'
'\012\0123Y' -> 10,10,'3','Y'
How about this:
#define MAKEFOURCC(byte1, byte2, byte3, byte4) (((uint8)byte1) + (((uint8)byte2) << 8) + (((uint8)byte3) << 16) + (((uint8)byte4) << 24))
MAKEFOURCC('Y', '3', 10, 16)
VirtualDub2
shekh is offline
Old 9th January 2017, 21:50   #2815  |  Link
pinterf
Thanks, then I will do this way. Noticed that behaviour but could not find the real reason for it, maybe it is undefined or compiler specific to define dword such way...
pinterf is offline
Old 9th January 2017, 21:57   #2816  |  Link
pinterf
Is there any planar rgb for VfW? Or else I could convert them to classic packed rgb formats on the fly? And 12 and 14 bit 420/422 formats could be silently converted and reported as 16 bits as well.
pinterf is offline
Old 9th January 2017, 22:12   #2817  |  Link
shekh
MagicYUV implements these (planar rgb/rgba 10,12,14,16) G3[0][10], G4[0][10], G3[0][12], G4[0][12], G3[0][14], G4[0][14], G3[0][16], G4[0][16]
I don`t implement them (it is boring and benefit over b64a is not obvious)
VirtualDub2
shekh is offline
Old 10th January 2017, 12:50   #2818  |  Link
jpsdr
Having planar data format over interlaced/packed can be a great benefit, the most is avoiding to have to transform (and transform back) the data into planar for doing the process/filter whatever.
Originally Posted by Reel.Deel View Post
@jpsdr
No 64bits version ?
And it seems it's not using the last version for code base, as some menu/interfaces are different from the version i'm using.
Nevertheless, it still can be usefull to have this.
Otherwise, tested :
64bits RGB(A) : Working.
4:2:2 YCbCr 10bits : Working.
4:2:2 planar YCbCr 16-bit : Working.
4:2:0 planar YCbCr 16-bit : Complain can't find decoder for P016.
4:4:4 planar YCbCr 16-bit : Everything is grey.
Release 38494.
jpsdr is offline
Old 10th January 2017, 13:18   #2819  |  Link
sl1pkn07
Pajas Mentales...
Originally Posted by jpsdr View Post
No 64bits version ?
https://sourceforge.net/projects/vdf.../version%2014/
@printf you can upload the avs+ binaries to github instead of cyberloker?
greetings
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline
Old 10th January 2017, 15:06   #2820  |  Link
shekh
If you promise to port some useful filters for rgb planar mode, I can implement it.
Otherwise just having planar source "supported" but immediately converted to packed - is not useful.
No 64bits version ?
Since original VirtualDub was never hosted publicly, I have no idea about last code base.
If you have it, please share.
Of course some menu/interfaces are different, I am making changes after all.
Not implemented yet.
Release 38494.
May accept Y416 but AviSynth+ does not implement it, I wonder what happens.
VirtualDub2
shekh is offline
