Old 30th January 2010, 13:08   #1  |  Link
Cozmec
AAC to AC3
I have some mp4 movies with AAC 5.1 audio.
My player does not support aac decoding though (WD TV LIVE)
so I have extracted the mp4 AAC (5.1) audio track and I want to convert it to AC3 (5.1) and remux it again with the video. Is there an easy way? I haven't found anything yet. Is there another way I can get it to play in my player?
Cozmec is offline
Old 30th January 2010, 13:52   #2  |  Link
user822
the Software eac3to can do so
its a commandline tool:
eac3to.exe input.aac output.ac3
the problem with 5.1 aac is known in the Internet, only working solution up to now seems to be your way with ac3!
user822 is offline
Old 30th January 2010, 14:32   #3  |  Link
Cozmec
Thanks a lot for the fast response!
The problem is my track is in ".mp4" Will there be a problem?
And will i have the channel mix up I've read somewhere (Like Left being center and center being suround right etc.)
Cozmec is offline
Old 30th January 2010, 14:47   #4  |  Link
Where did you get those movies?
Guest is offline
Old 30th January 2010, 15:24   #5  |  Link
Cozmec
From a friend. Does this matter in any way? They are not pirated if that's what you ask.
Cozmec is offline
Old 30th January 2010, 15:59   #6  |  Link
Cozmec
AAC to AC3
- Foobar2000
- BeHappy-AviSynth
- Command line:
faad -w -b 24 input.aac | aften -readtoeof 1 -pad 0 -b 640 - output.ac3
or
neroAacDec -if input.mp4 -of - | aften -readtoeof 1 -pad 0 -b 640 - output.ac3
I ve tried BeHappy but I lost myself. What exactly is the option to convert 5.1 AAC to 5.1 AC3
And by command line. Do you mean eac3to??
Cozmec is offline
Old 30th January 2010, 17:10   #7  |  Link
Yes, it matters. Thread closed for rule 6 violation.
Guest is offline
5.1, aac, ac3, mp4
