Old 17th February 2019, 22:22   #4501  |  Link
Groucho2004
Originally Posted by wonkey_monkey View Post
"All of them will return true if the colourspace is RGB (in an way)"
If that's true, then they would all be true whether it's RGB24, RGB32, or Planar RGB. Which means you'd have no way to distinguish RGB24 and RGB32.
Alright, I'm awake now. So, I guess it should be:
IsRGB() - Returns true for all RGB color spaces
IsRGB24(), IsRGB32, IsRGB48, IsRGB64 - Self-explanatory
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 17th February 2019, 23:10   #4502  |  Link
Motenai Yoda
Motenai Yoda's Avatar
as the only difference between rgb24 and rgb32 is the 8 bit alpha channel you can use both bitperpixel==32 and hasalpha to check it
powered by Google Translator
Motenai Yoda is offline
Old 17th February 2019, 23:35   #4503  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Wouldn't YV24 with Alpha return the same result with those?
Edit: oh, I think you meant if we already knew it was RGB. True, but IsRGB24() and IsRGB32() work as expected anyway, it's the wiki that's wrong.
wonkey_monkey is offline
Old 18th February 2019, 00:58   #4504  |  Link
bool IsRGB() const;
bool IsRGB24() const;
bool IsRGB32() const;
All of them will return true if the colorspace is RGB (in any way). The last two return true if the clip has the specific RGB colorspace (RGB24 and RGB32).
Its a bit [EDIT: well a lot] misleading, is intended to mean 'all RGB colorspaces will return true for IsRGB()'.
Same thing for the IsYUV thing.
StainlessS is offline
Old 18th February 2019, 11:01   #4505  |  Link
real.finder
since there are no way to get avs+ version I made AvsPlusVersionNumber() function to use it in avs scripting, the 1st one (IsAvsPlus) from the wiki but with some edit since there are no need for lower case and other things for all avs+ versions I seen
function IsAvsPlus()
    FindStr(VersionString, "AviSynth+")  != 0
function AvsPlusVersionNumber()
    IsAvsPlus ? eval(MidStr(VersionString(),17,4)) : 0
blankclip(color=color_white)
Subtitle(String(AvsPlusVersionNumber))
tested with r1576 and above and all fine but let hope nothing will change to make it break in future
See My Avisynth Stuff
real.finder is offline
Old 18th February 2019, 11:12   #4506  |  Link
pinterf
Hi real.finder, I've seen that too-many-DLLs load-unload issue, why MEGUI is hectic about it?
pinterf is offline
Old 18th February 2019, 11:24   #4507  |  Link
Groucho2004
For your "IsAVSPlus()" function, would you not rather use a try/catch construct around AddAutoloadDir("")? That function is exclusive to AVS+ and seems a safer check than the version string acrobatics.
Old 18th February 2019, 11:24   #4508  |  Link
real.finder
hi pinterf, I think because it has it own plugins folder and use AvisynthWrapper.dll and so, which mean a lot of dll's load already, and also I test it in full portable mode (with system has no avs at all) and then used ClearAutoloadDirs() AddAutoloadDir("path to plugins folder") in script and it's same thing especially after start encode (since it sometimes work in preview)
same script and folder work ok with x264 alone
Old 18th February 2019, 11:28   #4509  |  Link
real.finder
that can used too, but as I said those work already since the begin of avs+, and they look nicer than any other methods
Old 18th February 2019, 11:38   #4510  |  Link
Groucho2004
Out of curiosity - Under what circumstances would you need the revision number?
Old 18th February 2019, 11:49   #4511  |  Link
ChaosKing
A check with AddAutoloadDir whould detect Avisynth Neo also as Avisynth+ (it basically is avs+ with cuda stuff) while AvsPlusVersionNumber returns 0. VersionString() returns on avs neo: "Avisynth Neo 0.1 (r2882, Neo, i386)"
It this case a check with AddAutoloadDir would be prefered.
https://github.com/nekopanda/AviSynthPlus/releases
ChaosKing is offline
Old 18th February 2019, 12:00   #4512  |  Link
real.finder
same circumstances that old VersionNumber be used, like keep support for some older versions
Old 18th February 2019, 12:04   #4513  |  Link
Groucho2004
Originally Posted by ChaosKing View Post
Avisynth Neo
Arrrgh. Yet another version. Let's confuse the crap out of the average user.
Old 18th February 2019, 12:05   #4514  |  Link
Groucho2004
What support? Can you be more specific? Maybe a couple of examples?
Old 18th February 2019, 12:10   #4515  |  Link
real.finder
I don't have nvidia so and didn't use Avisynth Neo, it already not work with any of IsAVSPlus (both wiki and mine) and AvsPlusVersionNumber, it's better if the Developer of Avisynth Neo make it like this "Avisynth+ 0.1 (r2882, Neo, i386)"
Old 18th February 2019, 12:15   #4516  |  Link
real.finder
support older avs+ in some scripts, like the old 1576 and so, since there are new functions added every time in avs+
Old 18th February 2019, 12:19   #4517  |  Link
Groucho2004
If AVS+ had a simple script function "FunctionExists()" (same as the API function), testing for certain features would be a lot easier.
@pinterf
See above.
Edit: Or maybe a few simple utility functions which return true/false such as IsHighBitDepth() (HasHighBitDepth() ?), IsMultiThreaded(), etc. Just thinking out loud...
Old 18th February 2019, 12:24   #4518  |  Link
real.finder
maybe but I like use it like vanilla AviSynth VersionNumber(), with < or >, simple and nice
Old 18th February 2019, 12:24   #4519  |  Link
From RT_Stats function list thing,
AviSynth+_0.1_(r2772,_MT,_i386)_ORDERED_Function_List
FunctionExists    "s"
ie, already implemented. [Of course you have to know that its AVS+ before you can use it, or Try/Catch]
Old 18th February 2019, 12:28   #4520  |  Link
Groucho2004
already implemented
Ooops, you're right.
