14th February 2008, 22:36 | #3181 | Link |
Turkey Machine
I think ffdshow's decoding of elementary MPEG-2 files is broken somehow. It seems to output a SAR of 64:27 for a 16:9 720x576 video, when it's reporting internally that the SAR is 64:45. MPC's internal decoder has no such problems. Resize and aspect is disabled. Do you need a sample stream to confirm this?
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld |
15th February 2008, 13:37 | #3183 | Link | ||
15th February 2008, 14:11 | #3184 | Link | |
I suggest that this option covers both audio and video. IMO there's no need to separate them - at least during the installation process. This'll make it less confusing for beginners. Us advanced users can easily make further changes in the DirectShow control page which should remain unchanged. |
15th February 2008, 18:05 | #3185 | Link | |
ffdshow/AviSynth wrangler
np: Grad_U - Knob III (CMYK)
now playing: [artist] - [track] ([album]) |
15th February 2008, 18:47 | #3186 | Link |
Escaped ampersand bug
@Haruhiko:
With rev1626 you fixed a bug where subtitles with an "&" in the filename were incorrectly shown in ffdshow's context menu. Unfortunately, your bugfix introduced another bug: Scenario 1 Code:
Directory A & B |--> A & B.mkv |--> A & B.srt Scenario 2 Code:
Directory A & B |--> A & B.mkv |--> A & B.srt |--> AB.srt Looking at the code, I see that you simply escaped a single "&" with "&&" which is the correct way but you're escaping the path to the subtitle file too (variable files contains file names and the corresponding paths). The reason why Scenario 1 and 2 work in the beginning is that the escaping doesn't occur until you open the context menu (makeSubtitlesMenu()). If you then change the subtitle (or even select the same one), processCmd() will operate with the incorrect, escaped path (which was passed via GetMenuString()). My analysis may be wrong, so take it with a grain of salt. Java FTW! |
15th February 2008, 19:25 | #3187 | Link |
EphMan
MKV in FFDShow
Are MKV files not supported in FFDShow? Or is there an option I need to tick somewhere in config to allow decoding support?
I use WMP w/ FFDShow Tryouts and it plays everything I throw at it lately but nothing in an Matroska container. |
15th February 2008, 19:28 | #3188 | Link | |
If you want to play files with a container format that isn't supported by DirectShow out of the box install a splitter. np: Rumpistol - Dodvaegt (Intelligent Toys 4)
15th February 2008, 21:07 | #3189 | Link | |
Turkey Machine
I suspect it's something to do with my MPEG-2 in MKV bug not being nice with different SARs, but if it's doing it with elementary files, that suggests otherwise? And I can't remember if it happened last time with the elementary files.....
16th February 2008, 01:50 | #3190 | Link |
Kid for Today
OK I think I have fixed my problems with ffdshow and reclock
if I check "drop frame on delay : 1 ms", I get perfect synchronisation with reclock resampling 23.976@24 fps in 48.000 Hz.....it stays right on 24.000 even after 2 hours straight so basically if you could still fix the bug with winamp2 plugins explained here, that'd be really AWESOME http://forum.doom9.org/showpost.php?...postcount=3111 the ability to hide the winamp2 plugin GUI would also be fantastic....like in winamp. TIA, Last edited by leeperry; 17th February 2008 at 19:42. |
16th February 2008, 02:02 | #3191 | Link | |
n00b
16th February 2008, 07:50 | #3192 | Link |
Leak, clsid, Inventive Software and others.
Thanks a lot for your help. Really appreciate it. Though the problem may seem small, your suggestions have helped me in checking out ffdshow code from the repository. The problem was with the url. As Leak had suggested I tried with https://ffdshow-tryout.svn.sourcefor...ffdshow-tryout and it worked. Thanks once again. Taklu. |
17th February 2008, 19:42 | #3193 | Link |
Kid for Today
I've made 2 profiles in ffdshow audio...one for movies and one for music.
but for WMV files, it never works. the "movie" profile is supposed to be enabled when "ffdshow video decoder" is active(I've set ffdshow video to "all supported"), but it doesn't work for WMV files......even though "ffdshow video decoder" is loaded ?! |
17th February 2008, 20:16 | #3194 | Link |
Why don't you use the default profile in this case? Because the condition "ffdshow video decoder is in the filter chain" will (or should at least) always be true. So it makes no sense to use that condition.
MPC-HC 2.2.1 |
17th February 2008, 20:20 | #3195 | Link |
Kid for Today
well it works perfectly fine....except for WMV files.
the "movies" profile is used if "ffdshow video decoder" is loaded otherwise, the "music" profile is used. but for WMV files, it falls back to the "music" profile.....even though "ffdshow video decoder" is loaded. |
17th February 2008, 22:07 | #3196 | Link |
Why do you have a "music" profile in the video settings of ffdshow? That makes no sense.
The audio and video settings (including the profiles) are fully separated in ffdshow!
MPC-HC 2.2.1 |
17th February 2008, 23:02 | #3198 | Link | |
* One ("movies") when the ffdshow video decoder is in the graph, since the audio decoder is then probably decoding a movie's soundtrack * Another one ("music") when there's just the audio decoder in the graph, since that's probably the media player just playing some MP3 file or the like (Personally, I'd just use a dedicated audio player (i.e. Foobar2000) for playing music, but that might be just me in that case...) np: Proem - Live @ KVRX 10-09-2001 (Merck Fragments)
17th February 2008, 23:13 | #3199 | Link |
Ok, I have read it incorrectly. I thought you defined the profiles in the video decoder.
But there indeed is a bug. It also doesn't work with for example "Video Renderer". Edit: A workaround would be to use this condition: "ffdshow Video Decoder;DMO Wrapper Filter"
MPC-HC 2.2.1 Last edited by clsid; 17th February 2008 at 23:22. |
18th February 2008, 00:36 | #3200 | Link |
Kid for Today
w00t thanks, clsid!
I tried with "ffdshow Video Decoder;WMVideo Decoder DMO" as it says in the filters section....but that didn't work well I got one "movie" profile that doesn't resample to 96 Hz to avoid problems with Reclock doing 23.976@24 resampling. in the "music" profile, I've got noise shaping set to "heavy", and resampling in high quality to 96 KHz. both profiles are processed with the "OzoneMP" winamp2 plugin in 32 bit float, and output in 24 bit integer through WaveOut to my M-Audio Audiophile USB and my Sony MDR-CD3000. I've tried foobar, but the GUI sucks, and I very much like Gabest's mp3 decoder.....sounds really good to me there's some bugs in the winamp2 plugin support as explained here : http://forum.doom9.org/showthread.ph...30#post1100930 hopefully haruhiko_yamagata would fix them soon enough Last edited by leeperry; 18th February 2008 at 00:39. |
