13th January 2012, 23:28 | #8161 | Link | |
Will it be possible to select DXVA for interlaced VC-1 and CUVID for H264 or MPEG-2? Now one can only select either DXVA or CUVID for everything. Bat
Win 11 x64, Geforce RTX 4060 Ti 16GB, TV Sony KD-55X8509C HDMI, Denon AVR-X2700H, Core i7-9700K, 32GB DDR4, Creative Labs Gigaworks S750 7.1 speakers MPC Home-Cinema madVR LAV Filters |
14th January 2012, 00:50 | #8162 | Link | |
I don't say it often enough so for all your work! This thread has everything! I follow it every day. Sometimes it makes me laugh, sometimes I cringe at the responses some people get (justified or not ) but mostly I feel educated by reading and look forward to testing something new! Thanks Nev! Wo0zy |
14th January 2012, 07:22 | #8163 | Link |
Several.
- DXVA1 doesnt allow frame copyback - DXVA1 is only for Windows XP - FFMPEG only supports DXVA2
14th January 2012, 07:23 | #8164 | Link |
Why would you want that? CUVID is superior.
14th January 2012, 07:36 | #8165 | Link |
nev, do you know if HD MPEG2 software decoding handles errors differently than DXVA decoding? I've just started testing the 1080i and 720p wtv from OTA channels (I'm in the US so ATSC) recorded in Win 7's Media Center. They play relatively well, but with LAV Video's MPEG2 I get heavy gray blocking. With ffdshow, and the MS DTV-DVD decoder however, I don't get blocking, but I get slight color (reddish-greenish) and black level shifts. I don't get either when I just switch to EVR and a full DXVA chain, it plays just perfectly like on MC itself. So I still don't know for sure what's going on here, that's why I'm asking if errors from the capture could be the culprit, and somehow DXVA has better error resilience or something like that.
If it's not as simple as that, I could upload samples if anyone is interested to confirm.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
14th January 2012, 07:45 | #8166 | Link |
@ Andy o:
Are you using LAVSplitter? LAVvideo doesn't seem to like Microsoft's .wtv spltter (StreamBufferSource). If you use mpc-hc, block StreamBufferSource - you lose continuous live TV playback, but LAVSplitter works better for everything else, and gives you the ability to select audio streams.
Windows 7 x64 i7 870 16GB RAM AMD 6870 |
14th January 2012, 11:34 | #8168 | Link |
Benchmark results - Signature system - Video clip requested - LAV 0.44 latest
GraphStudio 0.3.2/ GraphStudio Next 0.4.5.5 (same results - 0.1fps difference) 3 passes - Null Renderer 5750 50,4 fps - GPU load 48% - 50% - CPU Load Max frequency ~ 25% average (6)750 56,2 fps - GPU load 52% - 53% - CPU Load Max frequency ~ 30% average DXVA Checker v2.6.2 LAV Video DXVA2 (6)750 EVR 53/54/54 - GPU Load 0/33/74 - CPU load max frequency 22/23/27 (6)750 VMR 48/54/56 - GPU Load 0/33/74 - CPU load max frequency 22/24/27 MS DS (vanilla DXVA2) A lot of artifacts - Not sure about valid speed (6)750 EVR 58/66/69 - GPU Load 0/3/3 - CPU load LOWEST frequency@1.6 GHz 9/10/11 MS MFT(vanilla DXVA2) Perfect decoding (6)750 EVR 68/71/72- GPU Load 0/1/7 - CPU load LOWEST frequency@1.6 GHz 0/10/10 Nice try - I'll skip because of: 1) High GPU load 2) High CPU load 3) Low decoding performance 4) Absolutely no need for anything else than EVR renderer Waiting for your DXVA vanilla solution. UPDATE: According to AMD and other sources over the Net, the only way to use Frame Copy with zero penalty is through OpenCL. If you want to implement a fast DXVA Frame copy solution for ATI hardware, you have to use OVD API (OpenVideo Decode). It's like NVCUVID and Intel's MSDK in its basic principle. No other way. Sorry.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all Last edited by NikosD; 14th January 2012 at 12:25. |
14th January 2012, 11:37 | #8169 | Link |
If you are running nothing but MPC-HC with LAV Filters do you only uncheck all the Transform Filters or do you uncheck all the Source Filters aswell. ?
All the guides seem to contradict each other with some even saying "Transform filters (Prefer) in 'External filters' override transform filters in 'Internal Filters' (usually). So there is no reason to disable all transform filters." |
14th January 2012, 12:27 | #8172 | Link |
Just exploring the latest LAV package with MPC and MadVR on XP SP2, Nvidia 8400GS with 285.58 driver.
However, with HW decoding (Nvidia CUVID) enabled in the LAV Video Decoder, 720p mkv files are incredibly pixelated and torn: if I disable HW decoding, it is smooth and unpixellated. Divx avi is fine. Doesn't change if I use EVR instead of MadVR. Is my 8400GS (the updated version, not the original) inadequate to support CUVID, or is something else wrong with my setup? |
14th January 2012, 12:53 | #8173 | Link |
@ Nev the latest x64 version ( "Revision 870a5b4451 dxva2: implement software fallback " ) it's just crashing (MPC-HC) while the x86 version it's not crashing (working with VC1i too ) but also has no DXVA just software
Intel UHD Graphics 750; Win 10 22H2 |
14th January 2012, 12:55 | #8174 | Link | |
Note that MPC-HCs DXVA status display doesn't work with this decoder.
14th January 2012, 13:22 | #8176 | Link | ||
Nev: I believe everything DVR-MS is a small subset of WTV container, is it at all possible to support DVR-MS in LAV Splitter? Last edited by Mixer73; 14th January 2012 at 13:29. |
14th January 2012, 13:44 | #8177 | Link | |
Format version : Version 2 File size : 1.28 GiB Duration : 41mn 53s Overall bit rate : 4 363 Kbps Encoded date : UTC 2012-01-03 12:05:59 Writing application : mkvmerge v5.2.1 ('A Far Off Place') built on Jan 2 2012 23:21:10 Writing library : libebml v1.2.3 + libmatroska v1.3.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : No Format settings, ReFrames : 2 frames Codec ID : V_MPEG4/ISO/AVC Duration : 41mn 53s Bit rate : 3 892 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.176 Stream size : 1.14 GiB (89%) Language : English Default : Yes Forced : No Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : A_AC3 Duration : 41mn 53s Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 115 MiB (9%) Language : English Default : Yes Forced : No Also discovered it pixelates badly on Youtube flv files. Last edited by IanD; 14th January 2012 at 13:48. |
14th January 2012, 13:58 | #8178 | Link |
14th January 2012, 14:17 | #8179 | Link |
DVR-MS works just fine with LAV Splitter, its just not a option in the installer. Just block the StreamBufferSource in MPC-HC and it should just work.
14th January 2012, 14:20 | #8180 | Link |
Yes it is
But maybe you can do something about the "DXVA" message cause even in the MPC-HC's stats (ctrl+J) it's saying "DXVA: Not using DXVA" ! and it's very confusing especially now with all this testing
