22nd November 2006, 13:31 | #261 | Link |
HDConvertToX author
18 is the crf value for X264 encoding .. BUT when you select XviD automkv SHOULD change it to the value written in xml profile...
can you tell me all click made to achive an xvid encoding with cq 18 ? i wasn't able to replicate BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
22nd November 2006, 16:05 | #262 | Link |
Quick note... I've been away for a little bit but calling AutoMKV with a file as a command line argument seems to be broken now. Not sure what build it happened with!
One other, not so small, thing.... I realize this might be a huge request, and if it is then no huge deal but hopefully! I do a lot of my video editing on a Mac in Final Cut Pro. It would be super convenient if AutoMKV was able to use DV Stream files (such as those captured by BTV Pro or outputted by FCP) as an input format. As it is, I have to convert them to DV AVI files in Quicktime Pro. Of course, this process re-encodes the file and degrades the quality. If I was able to use the ".dv" files directly in AutoMKV it would be a godsend! Barring that, does anyone know of a simple Mac-or-PC way to transcode .dv files to AVI without re-encoding the video?
"Some cultures are defined by their relationship to cheese." Last edited by glynor; 22nd November 2006 at 16:38. |
22nd November 2006, 16:46 | #263 | Link | |
HDConvertToX author
automkv command line interface isn't broken but UPGRADED
try from dos automkv.exe /? new example of command line "AutoMKV051b.exe automkv.ini _aaa.ts 1 0 0 0 start wait" Quote:
if not.. what is .dv ? and could you please send me a sample ? thanks BHH
22nd November 2006, 16:55 | #264 | Link |
i have a little problem with the movie.avs file ...
Something is going wrong converting to xvid ... and the only thing i can say ( 8) ) is that movie.avs is not showing anything - only returning "the scripts return value was not a video clip" ... #test2 movie = mpeg2source("D:\ACE3.0\tmp\movie.d2v") exists ... saying : DGIndexProjectFile13 1 D:\ACE3.0\tmp\film.m2v Stream_Type=0 MPEG_Type=2 iDCT_Algorithm=6 YUVRGB_Scale=0 Luminance_Filter=0,0 Clipping=0,0,0,0 Aspect_Ratio=4:3 Picture_Size=720x576 Field_Operation=0 Frame_Rate=25000 (25/1) Location=0,0,0,1517 film.m2v is playable ... Any ideas ? 8) ... Thanx FoGBaV Last edited by fogbav; 22nd November 2006 at 16:58. |
22nd November 2006, 17:09 | #265 | Link | |
I'll get back to you on the DV file stuff. I believe they are Quicktime-like files, not AVI. It's supposed to be a raw stream of what actually comes off of the camera or Analog<->Digital converter though. I'll do more research and I can certainly post a small example file.
"Some cultures are defined by their relationship to cheese." |
22nd November 2006, 17:33 | #266 | Link | |
HDConvertToX author
also is frame.txt created ? thanks BHH
22nd November 2006, 18:36 | #267 | Link | |
Details: (according to Quicktime Player) Video: Apple DV, 720 x 480 (640 x 480), Millions of colors, 29.97 FPS Audio: DV, Stereo, 48000 kHz Duration: 00:00:03.19 (3 seconds) Container: (according to G-Spot) File Type: Raw DV - IEC 61834 (.DV) Mime Type: video/DV I thought I'd mention. VLC can play this file back without problem (well, the colors are all messed up, but I think that's my config in VLC).
"Some cultures are defined by their relationship to cheese." Last edited by glynor; 22nd November 2006 at 18:46. |
22nd November 2006, 18:51 | #268 | Link | |
frame.log is created ...
Log : Quote:
Changing to H264 ... X264 is telling me : avis [error]: unsupported input format (DIB ) x264 [error]: could not open input file 'D:\ACE3.0\tmp\movie.avs' Last edited by fogbav; 22nd November 2006 at 19:03. |
22nd November 2006, 20:28 | #269 | Link |
HDConvertToX author
Ok, got the error. is due to NO RESIZE and INTERLACED content.
use this build www.64k.it/andres/data/a/AutoMKV051c.exe if ok i will publish changelog of 0.51c Thanks ofr testing BHH
22nd November 2006, 20:36 | #270 | Link | |
> Open automks51a (profile loads) > Select input file (a *.ifo file) > Select output directory > Select subtitle > Press Start What else should I look at for you? |
22nd November 2006, 20:39 | #271 | Link | |
12:52:29 Enabled CRF/CQ autoresize with value 18 It looks like it is still getting the quantizer value from this field rather than the profile! |
22nd November 2006, 20:45 | #272 | Link |
HDConvertToX author
@weaver4
got the error too. wait for a fix ! BHH
22nd November 2006, 21:27 | #273 | Link |
Hey. I've been doing some tests of AutoMKV vs. Nero Recode 2 (AutoMKV is looking good btw) comparing encodes of my DV sources.
One little thing that would be nice with AutoMKV is if it timestamped the entries in the log, and perhaps gave us a total encoding time when finished. So far it looks like AutoMKV is faster and a little better quality than Nero Recode 2! (Both are very good, but Nero's encodes are a little warmer than the source. AutoMKV with x264 is basically indistinguishable from my source clip.)
22nd November 2006, 22:34 | #274 | Link |
@buzzqw : You are the man !
Works like a sharm again ... thanx 4 your work ... going to encode now ...8) P.S. : Little small bug - xvid_ecraw second pass is running with priority normal ... (First one runs correctly on low) and ... i configure 1 Pass Xvid --- he is doing a 2 pass ... but this one is maybe my fault ... will check this tomorrow ... Last edited by fogbav; 22nd November 2006 at 23:07. |
22nd November 2006, 22:46 | #275 | Link |
HDConvertToX author
update to 0.51c www.64k.it/andres/data/a/AutoMKV051c.exe
changelog FIXED: in ts files, audio and video pid greater then 1000 were not processed (thanks to travisbell) FIXED: using NONE as resizer and AUTO deinterlacer on interlaced files... (thanks to fobgav) FIXED: loading automkv using a template with XviD CQ will not put the correct CQ value (from profile if CQ or 2.5 fo other template) ADDED: more resizer (maybe too tecnical now... as always i am open to suggestion) BHH
23rd November 2006, 09:53 | #276 | Link |
HDConvertToX author
UPDATE 0.51d www.64k.it/andres/data/a/AutoMKV051d.exe
FIXED:added a workaround to fix autodeinterlacer routines BHH
24th November 2006, 15:08 | #277 | Link | ||
HDConvertToX author
BHH
24th November 2006, 18:18 | #279 | Link |
Files too small
I tried to back up my copy of Aviator using AutoMKV 0.51d, constant quality XviD; quantizer of 3.
I tried using four different programs and here are the file size results. -AutoGK >> 1.2G -avi.net >> 1.21G -Staxrip >> 1.33G -MPEG Mediator >> 1.23G -AutoMKV >> .933G All five were done with CQ, with a quantizer of three. The audio file was the largest for AutoMKV by about 30 Meg. The size on all five are 640x272. It does not make any sense that AutoMKV result would be 25% smaller than these other four programs. Any ideas why? Here is the log file. ============================================ 08:26:12 0.51d - - - - - START JOBS - - - - - - - - - - - - - 08:26:12 Selected Input file: E:\Movies\RipAnyDVD\Aviator\VTS_01_0.IFO 08:26:12 Selected Output dir: E:\Movies\Output\ 08:26:12 Selected Container type: AVI 08:26:12 Selected Size: 1 DVD-R 08:26:12 Selected Slice: 1 08:26:12 Selected Encoder: XviD 08:26:12 Selected Profile: XviD_CQ30.xml 08:26:12 Selected Width: 640 08:26:12 Selected Resizer: BicubicResize (soft=0,0.333) 08:26:12 Selected Filters: RemoveGrain(mode=2) 08:26:12 Selected Deinterlacer: AUTO 08:26:12 NeroAACEnc.exe not present 08:26:12 Enabled CRF/CQ autoresize with value 3 08:26:12 Track Language 1: English (AC3 6ch, 0xBD 0x80) [0] 08:26:12 Audio Codec 1: Lame 08:26:12 Audio Quality 1: 4 08:26:12 Selected Unlimited media size 08:26:12 Starting Indexing 08:26:12 Dgindex CMD: C:\Downloads2\AutoMKV\AutoMKV051\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=1 -YR=2 -AIF=[E:\Movies\RipAnyDVD\Aviator\VTS_01_1.vob] -OF=[E:\Movies\Output\movie] -exit -minimize 08:29:05 Finished indexing 08:29:05 Starting fixing audio delay on track number 1 08:29:05 DelayCut CMD: C:\Downloads2\AutoMKV\AutoMKV051\exe\dgindex\Delaycut.exe -auto -out "E:\Movies\Output\fixed1.ac3" "E:\Movies\Output\movie T01 3_2ch 384Kbps DELAY -25ms.ac3" 08:29:31 Original 1' Audio Size: 489944064 bytes 08:29:31 Finished fixing audio delay 08:29:31 Encoding E:\Movies\Output\fixed1.ac3 To Mp3 with 4 quality 09:03:27 Encoded 1' Audio Track: 154390272 bytes 09:03:27 ForcedFilm applied: 100.000000% FILM found 09:03:36 Number of Frames: 244728 09:03:36 Framerate: 23.976025 09:03:36 Movie lenght in Seconds: 10208 09:03:36 Movie Width: 720 09:03:36 Movie Height: 480 09:03:36 CQ encoding XviD: C:\Downloads2\AutoMKV\AutoMKV051\exe\encoder\xvid_encraw.exe -cq 3 -progress -threads 1 -max_bframes 2 -imax 31 -quality 6 -vhqmode 1 -qtype 0 -pmax 31 -bmax 31 -bquant_ratio 162 -nochromame -noclosed_gop -bvhq -qmatrix "C:\Downloads2\AutoMKV\AutoMKV051\profiles\XviD-profiles\matrix\Sharktooth's EQM v3ULR.cqm" -i "E:\Movies\Output\movie.avs" -type 2 -avi "E:\Movies\Output\movie.avi" 11:57:03 Accepted values are between 4461743104 and 4743537664 bytes (movie+audio) 11:57:03 Got a file of size: 818629950 bytes + audio size 154390272 bytes (973020224) 11:57:03 Only Movie Size: 818629950 bytes 11:58:08 Final Muxed size: -1 bytes 11:58:08 11:58:08 Muxing Script 11:58:08 C:\Downloads2\AutoMKV\AutoMKV051\exe\matroska\AVIMux_GUI.exe E:\Movies\Output\muxavi 11:58:08 11:58:08 CLEAR 11:58:08 LOAD E:\Movies\Output\movie.avi 11:58:08 LOAD E:\Movies\Output\audio.mp3 11:58:08 SELECT FILE 1 11:58:08 ADD VIDEOSOURCE 11:58:08 SET INPUT OPTIONS 11:58:08 SET OPTION MP3 VERIFY CBR NEVER 11:58:08 SET OPTION MP3 VERIFY RESDLG OFF 11:58:08 SET OUTPUT OPTIONS 11:58:08 WITH SET OPTION 11:58:08 OPENDML 1 11:58:08 RECLISTS 0 11:58:08 AUDIO INTERLEAVE 3 FR 11:58:08 AVI ADDJUNKBEFOREHEADERS 0 11:58:08 PRELOAD 200 11:58:08 WITH AUDIO 11:58:08 NAME 1 english 11:58:08 END WITH 11:58:08 OVERWRITEDLG 0 11:58:08 CLOSEAPP 1 11:58:08 DONEDLG 0 11:58:08 ALL AUDIO 1 11:58:08 LEGACY 0 11:58:08 RECLISTS 1 11:58:08 NUMBERING OFF 11:58:08 MAXFILESIZE OFF 11:58:08 END WITH 11:58:08 START E:\Movies\Output\aviator_full.avi 11:58:08 11:58:08 Script AutoCrop.log 11:58:08 11:58:08 Crop(10,54,700,368) 11:58:08 11:58:08 Script Resmovie.avs 11:58:08 11:58:08 11:58:08 Script movie.avs 11:58:08 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\autocrop.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\blockbuster.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\cnr2.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\ColorMatrix.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\Convolution3D.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\corrector.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\DctFilter.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\Decomb.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\Deen.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\degrainmedian.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\DGDecode.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\EEDI2.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\fft3dfilter.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\FluxSmooth.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\frfun7.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\hqdn3d.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\LeakKernelDeint.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\MaskTools.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\medianblur.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\MipSmooth.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\mvtools.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\NicAudio.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\RemoveGrain.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\SangNom.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\SimpleResize.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\TBilateral.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\TDeint.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\TIVTC.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\TomsMoComp.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\TTempSmooth.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\UnDot.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\UnFilter.dll") 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\VSFilter.dll") 11:58:08 #loadpluginstart 11:58:08 11:58:08 #test1 11:58:08 11:58:08 Import("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\mvbob.avsi") 11:58:08 Import("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\QMF.avsi") 11:58:08 #importstart 11:58:08 11:58:08 #test2 11:58:08 11:58:08 movie = mpeg2source("E:\Movies\Output\movie.d2v") 11:58:08 function getOrder(clip c) { 11:58:08 order = GetParity(c) ? 1 : 0 11:58:08 Return order } 11:58:08 #filter1start 11:58:08 11:58:08 #test3 11:58:08 11:58:08 #cropstart 11:58:08 11:58:08 cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=0,threshold=34,samplestartframe=0) 11:58:08 fixed_aspect = 1.185185 11:58:08 c_width = width(cropclip) 11:58:08 c_height = Round(height(cropclip) / fixed_aspect) 11:58:08 input_par = float(float(c_width)/float(c_height)) 11:58:08 input_par = input_par > 1.4 ? input_par : (4.0/3.0) 11:58:08 out_width = 640 11:58:08 out_height = Round(float(out_width) / input_par) 11:58:08 hmod = out_height - (floor(out_height / 16 ) * 16) 11:58:08 out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) 11:58:08 new_aspect = (float(out_width) / float(out_height)) / fixed_aspect 11:58:08 autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=new_aspect,threshold=34,samplestartframe=0) 11:58:08 11:58:08 #resizestart 11:58:08 11:58:08 #test4 11:58:08 11:58:08 BicubicResize(out_width,out_height,0,0.333) 11:58:08 #filter2start 11:58:08 11:58:08 #test5 11:58:08 11:58:08 RemoveGrain(mode=2) 11:58:08 ColorMatrix("Rec.709->Rec.601",hints=false) 11:58:08 11:58:08 Script mkvmaudio.avs 11:58:08 11:58:08 LoadPlugin("C:\Downloads2\AutoMKV\AutoMKV051\exe\filter\NicAudio.dll") 11:58:08 NicAC3Source("E:\Movies\Output\fixed1.ac3") 11:58:08 EnsureVBRMP3Sync() 11:58:08 ConvertAudioTo16bit() 11:58:08 #Applyed Stereo downmixing routines 11:58:08 function stereo(clip a) 11:58:08 { 11:58:08 fl = GetChannel(a, 1) 11:58:08 fr = GetChannel(a, 2) 11:58:08 c = GetChannel(a, 3) 11:58:08 lfe = GetChannel(a, 4) 11:58:08 sl = GetChannel(a, 5) 11:58:08 sr = GetChannel(a, 6) 11:58:08 l_sl = MixAudio(fl, sl, 0.2929, 0.2929) 11:58:08 c_lfe = MixAudio(lfe, c, 0.2071, 0.2071) 11:58:08 r_sr = MixAudio(fr, sr, 0.2929, 0.2929) 11:58:08 l = MixAudio(l_sl, c_lfe, 1.0, 1.0) 11:58:08 r = MixAudio(r_sr, c_lfe, 1.0, 1.0) 11:58:08 Return MergeChannels(l, r).Normalize() 11:58:08 } 11:58:08 # 11:58:08 function original(clip a) 11:58:08 { 11:58:08 Normalize(a) 11:58:08 Return last 11:58:08 } 11:58:08 6==Audiochannels() ? stereo() : original() 11:58:08 11:58:08 Script mkvmaudio.bat 11:58:08 11:58:08 "C:\Downloads2\AutoMKV\AutoMKV051\exe\besweet\bepipe.exe" --script "Import(^E:\Movies\Output\mkvmaudio.avs^)" | "C:\Downloads2\AutoMKV\AutoMKV051\exe\besweet\lame.exe" -v --vbr-new -h -S -V 4 - "E:\Movies\Output\audio.mp3" 11:58:08 11:58:08 Script mkvmaudio2.avs 11:58:08 11:58:08 11:58:08 Script mkvmaudio2.bat 11:58:08 11:58:08 11:58:08 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - |
24th November 2006, 18:58 | #280 | Link |
HDConvertToX author
first question:
how about quality ? is all files at the same VISUAL quality ? second: resizer, was the same for all programs ? (i don't think so) third: filters, were the same for all programs ? (this maybe) fourth: matrix, was the matrix the same ? (i don't think so) fifth: the xvid_encraw was lauched with the same parameters ? (i don't think so) my only hope i that quality is at least equal as the movie done with others encoders about audio ... this is the command line... lame.exe -v --vbr-new -h -S -V 4 - audio.mp3 other program run different command line ? BHH
