26th August 2008, 12:09 | #1901 | Link | |
Location: The Great North (the better half of North America)
Also, even though I will continue to use the GUIs it is still good to know that piece of information about the command line process... thanks again. |
26th August 2008, 12:38 | #1902 | Link | |
That's why it's not blu-ray compilant. I've heard that there is a way to re-add the bars but it need to re-enconde and seems very complicated. There is any solution for a movie like 1280x588 get back to 1280x720 ? |
26th August 2008, 12:50 | #1903 | Link | |
eac3to seems to be doing the job now. Cheers |
26th August 2008, 12:54 | #1904 | Link |
HD DVD Audio
Now that I know how to use eac3to, if I convert a HD DVD video only using RipBot264 and seperatley use eac3to to convert the DD+ sountrack to WAVs and Surcode to DTS, will the resulting audio sync with the video coverted to Blu-Ray format by Ripbot? Cheers.
26th August 2008, 13:00 | #1905 | Link |
It will, but you will need to remove the pulldown from the HDDVD video stream before you run it through ripbot... I'm not sure how using ripbot. I do this through tsMuxeR then recode using MeGUI.
26th August 2008, 17:24 | #1908 | Link | |
note: Input file is dts created by eac3to -re-encoded into dts via surcode- (or extracted by eac3to directly), output file is dts again which has revized by eac3to. ok ? Last edited by rica; 26th August 2008 at 18:24. |
26th August 2008, 19:36 | #1909 | Link |
Let me clarify a little bit more:
Extracting re-encoding lpcm to dts (via surcode) with eac3to: Code:
eac3to v2.57 command line: eac3to\eac3to.exe "F:\SPIDER_MAN_3\BDMV\STREAM\New Folder\00011.m2ts" 2: "C:\Users\rica\Desktop\Try\lpcm.dts" ------------------------------------------------------------------------------ M2TS, 1 video track, 9 audio tracks, 27 subtitle tracks, 2:19:11 1: h264/AVC, 1080p24 /1.001 (16:9) 2: RAW/PCM, 5.1 channels, 16 bits, 48khz 3: TrueHD/AC3, 5.1 channels, 48khz 4: AC3, 5.1 channels, 640kbit/s, 48khz, dialnorm: -25dB ************* [a02] Extracting audio track number 2... [a02] Reading RAW/PCM... [a02] Swapping endian... [a02] Remapping channels... [a02] Writing WAVs... [a02] Creating file "C:\Users\rica\Desktop\Try\lpcm.R.wav"... [a02] Creating file "C:\Users\rica\Desktop\Try\lpcm.L.wav"... [a02] Creating file "C:\Users\rica\Desktop\Try\lpcm.SL.wav"... [a02] Creating file "C:\Users\rica\Desktop\Try\lpcm.C.wav"... [a02] Creating file "C:\Users\rica\Desktop\Try\lpcm.LFE.wav"... [a02] Creating file "C:\Users\rica\Desktop\Try\lpcm.SR.wav"... Found Surcode DTS Encoder version 1.0.21.0. Surcode encoding successfully started. Please wait... Closing Surcode... Video track 1 contains 200231 frames. eac3to processing took 27 minutes, 58 seconds. Surcode encoding took 21 minutes, 43 seconds. Done. Lets revize that dts with eac3to: Code:
eac3to v2.57 command line: eac3to\eac3to.exe "C:\Users\rica\Desktop\Try\lpcm.dts" "C:\Users\rica\Desktop\Try\out.dts" ------------------------------------------------------------------------------ DTS, 5.1 channels, 2:19:11, 24 bits, 1536kbit/s, 48khz Removing DTS zero padding... Creating file "C:\Users\rica\Desktop\Try\out.dts"... eac3to processing took 1 minute, 49 seconds. Done. Last edited by rica; 26th August 2008 at 21:45. |
26th August 2008, 20:48 | #1911 | Link | |
BTW, here in first step eac3to just extracts (or dumps ) waves and later surcode takes the job from eac3to for re-encoding and surcode itsellf creates this zero padding. So until surcode encodes, eac3to has nothing to remove. In second step eac3to this time removes that Last edited by rica; 26th August 2008 at 21:46. |
26th August 2008, 21:54 | #1912 | Link | |
26th August 2008, 22:33 | #1913 | Link | |
CMD method is the best way if you don't need to type lots of parameters (i 'd newer prefer x264 in command line) and bla-bla... Last edited by rica; 26th August 2008 at 23:54. |
27th August 2008, 01:14 | #1914 | Link | |
b4k3d
27th August 2008, 07:31 | #1915 | Link |
HD DVD to Blu-Ray keeping DD+
HD DVD's - I've demuxed the video and audio (usually Dolby Digital Plus) using EVOdemux, fixed the video using either vc1conv or h264info and added the resulting fixed video file to TSMuxer. I change the file extension of the demuxed DD+ soundtrack to .ac3 and then add that to TSMuxer. Then mux together to form a blu-ray file.
Whilst the audio shows as DD+ in TSMuxer, I'm not sure that this is compliant blu-ray audio, until I play the resulting BD-R back through a standalone player connected to my Onkyo amp via HDMI I can't be sure. I don't really want to convert the DD+ to wavs and then DTS via Surcode, as you are already converting a compressed lossy soundtrack so the resulting DTS track won't be as good as the original DD+. Does anyone know about the comapatability of DD+ with blu-ray, is there something I need to do to the audio before? Thanks for your help. |
27th August 2008, 09:18 | #1918 | Link | |
When you demux using EVOdemux you set the extension of the audio stream to AC3 regardless of what type of Dolby it is. Same with subtitles, set as .sup... run through SUPread to convert to HDDVD .sup to BD .sup. Don't forget, when demuxing using EVOdemux to "Read XPL" before demuxing, the will auto-join the two Feature_EVO's and identify languages of the streams. EDIT: Besides removing the pulldown, are you recoding your HDDVD vc1 or h264 video stream before muxing to BD? Last edited by odin24; 27th August 2008 at 09:21. |
27th August 2008, 09:38 | #1919 | Link |
Life's clearer in 4K UHD
Here's some info regarding DolbyDigital+ (EAC3) audio spec compliance for Blu-ray and HD-DVD: -
27th August 2008, 09:50 | #1920 | Link | |
Thanks for the clarification SeeMoreDigital. @ hdpete, I'm not sure, or even if this is possible, how to take a HDDVD DD+ track and make it a DD+ BD compliant stream, AC3 core with DD+ data. |
tsmuxer |
