2nd January 2006, 20:24 | #981 | Link | |
...and yes lets move to .NET 2.0! |
3rd January 2006, 00:51 | #982 | Link |
Pain and suffering
compile x264-svn:
Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42 for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727 Copyright (C) Microsoft Corporation 2001-2005. All rights reserved. OneClickConfigurationDialog.cs(201,16): error CS0246: The type or namespace name 'OneClickSettings' could not be found (are you missing a using directive or an assembly reference?) OneClickProfile.cs(9,11): error CS0246: The type or namespace name 'OneClickSettings' could not be found (are you missing a using directive or an assembly reference?) OneClickProfile.cs(10,10): error CS0246: The type or namespace name 'OneClickSettings' could not be found (are you missing a using directive or an assembly reference?) OneClickProfile.cs(22,39): error CS0246: The type or namespace name 'OneClickSettings' could not be found (are you missing a using directive or an assembly reference?) OneClickWindow.cs(16,17): error CS0246: The type or namespace name 'lavcSettings' could not be found (are you missing a using directive or an assembly reference?) OneClickWindow.cs(17,17): error CS0246: The type or namespace name 'snowSettings' could not be found (are you missing a using directive or an assembly reference?) OneClickWindow.cs(18,17): error CS0246: The type or namespace name 'xvidSettings' could not be found (are you missing a using directive or an assembly reference?) OneClickWindow.cs(29,17): error CS0246: The type or namespace name 'VideoUtil' could not be found (are you missing a using directive or an assembly reference?) OneClickWindow.cs(377,37): error CS0246: The type or namespace name 'AspectRatio' could not be found (are you missing a using directive or an assembly reference?) |
3rd January 2006, 01:20 | #983 | Link |
The transition to .NET 2.0 means that compile.bat no longer works (it uses the .NET 1.1 compiler). Anyway, MeGUI 0.2.3.1030 adds no features that are relevant to x264-svn, so try compiling 1029a, as that should work with .NET 1.1
3rd January 2006, 01:56 | #985 | Link |
Pain and suffering
@berrinam
I cant compile with 1.1 also anymore: compile x264-svn: Microsoft (R) Visual C# .NET Compiler version 7.10.6001.4 for Microsoft (R) .NET Framework version 1.1.4322 Copyright (C) Microsoft Corporation 2001-2002. All rights reserved. OneClickConfigurationDialog.cs(13,12): error CS1518: Expected class, delegate, enum, interface, or struct OneClickConfigurationDialog.Designer.cs(3,5): error CS0116: A namespace does not directly contain members such as fields or methods OneClickConfigurationDialog.Designer.cs(3,19): error CS0101: The namespace 'MeGUI' already contains a definition for 'OneClickConfigurationDialog' OneClickConfigurationDialog.cs(13,26): (Location of symbol related to previous error) OneClickWindow.cs(13,12): error CS1518: Expected class, delegate, enum, interface, or struct OneClickWindow.Designer.cs(3,5): error CS0116: A namespace does not directly contain members such as fields or methods OneClickWindow.Designer.cs(3,19): error CS0101: The namespace 'MeGUI' already contains a definition for 'OneClickWindow' OneClickWindow.cs(13,26): (Location of symbol related to previous error) I already have a working version of megui.exe with older source, i was just pointing this out, so DEVs can fix it |
3rd January 2006, 09:03 | #987 | Link |
clueless n00b
I'll see to it that compile.bat will work properly under .NET 2.0 but as already pointed out, the move has been done.. I've already made several changes towards that effect and I'm currently revamping the video encoder architecture.. as a sideffect getting rid of the last two remaining compiler warnings that affect .NET 2.0.
And as Sharktooth mentioned: conditional compilation is currently broken.. so you can't build any new svn builds.. but since there have been no changes for that particular version, it shouldn't be too problematic.
3rd January 2006, 17:01 | #988 | Link |
Mr. Sandman
@doom9: tortoise svn cant store the pass.
Microsoft.DirectX.AudioVideoPlayback is not necessary!!! :P
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 3rd January 2006 at 17:11. |
3rd January 2006, 17:27 | #989 | Link |
Mr. Sandman
CVS update:
Fixed x264 and Snow conditional compiling Removed Microsoft.DirectX.AudioVideoPlayback from the references Sources: http://www.webalice.it/f.corriga/meg....0.2.3.1030.7z Bins on SF.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 3rd January 2006 at 17:44. |
3rd January 2006, 18:41 | #990 | Link |
Sorry, been away from computer access for the New year. I'll grab the latest CVS tonight and start looking at what I can fix now that we've moved to the 2.0 framework.
Are we going to start using the task and bug reporting features of SF so that we can coordinate changes more efficiently? I'd like to just look at my SF account to see what changes are needed rather than digging through this long thread. |
3rd January 2006, 20:53 | #992 | Link |
Mr. Sandman
ensure to load the default profile.
3rd January 2006, 22:01 | #994 | Link | |
Also I assume you mean enabling and disabling of controls when you see activation/deactivation. |
3rd January 2006, 22:02 | #995 | Link |
Mr. Sandman
The TO DO list is not up to date
I think it has been already done (or at least partially done). As soon as doom9 updates the TO DO list in the first post i'll add a TODO.txt to the CVS.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 3rd January 2006 at 22:05. |
3rd January 2006, 22:33 | #996 | Link |
I don't remember you.
I dont speak programming, but I'd like to see MeGUI get better as it has a lot of potential. The main errors and bugs that I have encountered thus far; When I use the Avisynth creator and hit prevew after inputing the d2v file, I get a narrow black bar that has no video. Also, when I hit crop, I get this;
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentNullException: Value cannot be null. Parameter name: image at System.Drawing.Graphics.DrawImage(Image image, Int32 x, Int32 y, Int32 width, Int32 height) at MeGUI.VideoPlayer.resizeBitmap(Bitmap b, Int32 nWidth, Int32 nHeight) at MeGUI.VideoPlayer.positionSlider_Scroll(Object sender, EventArgs e) at MeGUI.VideoPlayer.crop(Int32 left, Int32 top, Int32 right, Int32 bottom) at MeGUI.AviSynthWindow.sendCropValues() at MeGUI.AviSynthWindow.crop_CheckedChanged(Object sender, EventArgs e) at System.Windows.Forms.CheckBox.OnCheckedChanged(EventArgs e) at System.Windows.Forms.CheckBox.set_CheckState(CheckState value) at System.Windows.Forms.CheckBox.OnClick(EventArgs e) at System.Windows.Forms.CheckBox.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///E:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- megui Assembly Version: 0.2.3.1030 Win32 Version: 0.2.3.1030 CodeBase: file:///F:/DVD%20Rips/bitcalc/MeGUI/megui.exe ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- bvd27uqz Assembly Version: 0.2.3.1030 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- jq7878b1 Assembly Version: 0.2.3.1030 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 8yf-dzrk Assembly Version: 0.2.3.1030 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Bob, I'm going to need you to come in on Saturday mmkay?.... |
3rd January 2006, 22:38 | #997 | Link |
Mr. Sandman
No it means a value cannot be "null"...
Can you post your .avs and .d2v files too?
3rd January 2006, 22:52 | #998 | Link | |
Heres the link to my d2v file; http://hailut.homedns.org/VTS_08_1.d2v made it using DGindex 1.45
3rd January 2006, 23:23 | #999 | Link | |
3rd January 2006, 23:37 | #1000 | Link |
@fegul: This sounds like it could be a problem with either DGDecode.dll in the wrong place (I'm no longer exactly sure where it should be, but charleski should know), or the Default Profile not selected in the avs profile window.
@devs: The problem with the default profile not selected by default should be solved by changing Code:
avsProfile = "default"; Code:
avsProfile = "Default Profile"; |
development, megui, not a help thread |
