15th April 2007, 18:24 | #2841 | Link | |
clueless n00b
16th April 2007, 01:24 | #2842 | Link |
There's an avisynth plugin called twriteavi that can write a huffyuv avi file while the first pass is being done. With some clever scripting it's possible to use the exact same script for first and second passes, but the second pass actually uses the huffyuv avi written during the first pass as the source. It's not something I'd recommend be added to MeGUI (too many things to go wrong), but it is a possibility for people who want speed and know how to manually write scripts.
19th April 2007, 17:28 | #2843 | Link | |
Can you tell me if "adding an atom to the mp4 container" is implemented in MeGUI itself or mp4box? Perhaps I could try to write a patch and you could decide on that? |
19th April 2007, 17:43 | #2844 | Link |
clueless n00b
megui doesn't do anything on a container level (or encoding level for that matter).. it's strictly a control application (well, almost strictly, it does some audio decoding via avisynth and pipes that data to audio encoders).
28th April 2007, 16:32 | #2847 | Link |
Pain and suffering
or http://x264.nl for a compile (still revision 117)
5th May 2007, 09:52 | #2848 | Link |
@check: I have not still got newest version. In tag directory, newest version is 2193
Version Megui , is at x264.nl, has many new feature but also lost many old feature such as: in queue tab, click button "load", then ... nothing.... Last edited by thuongshoo; 5th May 2007 at 10:17. |
9th May 2007, 16:09 | #2849 | Link |
my megui doesnt update any more, it just saying "There are 0 files that can be updated". its been like this for ~1 month now (?) and even continues after I reinstalled windows & megui completely. I dont believe there would be nothing to update since that long time e.g. x264 version is from 635, while 655 seems to be the latest right now, or dgindex still bein 1.48 etc.
the 2 update servers in the update list I have are the 2 standard ones. |
10th May 2007, 00:44 | #2850 | Link | |
Posts: n/a
13th May 2007, 06:40 | #2852 | Link |
Bug bash:
0.2.4.1040 Commit by berrinam: - Small new feature: AutoEncode has better filesize choosers. (addresses 1654588) - If the bitrate calculator doesn't contain an appropriate framerate, one is added (fixes 1676934, includes code from there) - Removed the unused avsConfigurationDialog.cs - Fixed 1652664 (no commandline previews) - Fixed 1653755 (Muxer reports audio in wrong notation) - Fixed 1679572 (Turbo Mode in LMP4 multipass sometimes not selectable) - Fixed 1696067 (Video encoding doesn't use the specified filename) (a duplicate of 1653186: Video Output not passed to commandline) - Fixed 1688789 (One Click Encoder Crashes with Automatic Deinterlace checked) - Fixed 1675408 (mkvmerge split option incorrect) - Fixed 1666878 (Vobsubber changing output doesn't work) - Fixed 1659596 (Load DLL in Avisynth configuration dialog) - Fixed 1652312 (xvid b-frames default wrong) |
14th May 2007, 08:09 | #2856 | Link |
Some cosmetic features this time.
0.2.4.1041 Commit by berrinam: - Allow non-integer XviD quantizers (1650574) - Make the main window expandable (1704963) - Groups of jobs can be moved up and down in the queue (1685623) - Allow autoscrolling the log (1661785) |
14th May 2007, 17:45 | #2857 | Link |
Thanks for the cosmetic fixes! I've been waiting for those. Is there any chance that they'll be a feature that'll save the position of the tab things in the queue window? Like, the size in pixels would be saved to a file and read when you started up meGUI. I like to have them just right so that it fits nicely into the window.
14th May 2007, 22:30 | #2860 | Link |
Since latest update (core 0.2.4.1041) Autoupdate button doesn't work anymore. I click but nothing happends!
Video Input: avs Video output: mp4 (x264) Audio input: avi (mp3) Audio output: mp4 (aac) I'm used to work with these settings and I've done tons of encodings, but now autoencode button is died. Can anyone check, please? Thanks ----------------------- update: rolled back to 0.2.4.1039 and everything is ok. ----------------------- update 2: version 1041 works using menu for autoencode Last edited by dinolib; 19th May 2007 at 20:07. |
development, megui, not a help thread |
