Old 16th April 2009, 02:12   #1  |  Link
880
Problem with Speed blu-ray
I have an unusual problem with the Speed (US) Blu-ray. When I put the disc in the drive it makes an unusual clicking noise. PowerDVD freezes. It took about 240 seconds longer than usual, but DumpVID found the VID.
Once I started DumpHD, it kept skipping each file. It would try to read a file, then fail with "I/O CRC error". It would skip the file and go on to the next one, but fail.
Oddly enough, I sent the Speed disc back to Netflix. I got the return disc today, and had the same problem!
My drive is a LG GGC-H20L with version 1.03 (official) firmware. My OS is Windows XP x64. I am using DumpHD 0.6 with AACSKeys 0.4.0a.
880 is offline
Old 16th April 2009, 03:30   #2  |  Link
blutach
Country Member
blutach's Avatar
Closed for rule 6 violation.
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline
drive, error, speed
