9th August 2019, 19:51 | #17101 | Link | |
If you have stable connections with static IP, you´re all set. Home-DSL or similar resets it´s IP adress within 24h in most countries, so you´d have to whip up some dyndns stuff... If the connection brakes down while encoding, in 80% the encode gets stuck, so you have to monitor everything alle the time. For VPN, you could use almost anything you can think of, ripbot doesn´t care.... I tried hamachi, AVM-Fritzbox VPN, etc.... |
9th August 2019, 20:45 | #17102 | Link | |
Job starts to encode I have three other files to "mute" and add them too I'll do my job eventually
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
10th August 2019, 00:52 | #17104 | Link | |
Is there another way to get encoding server pointed to another address/port? https://i.imgur.com/yZAGV4Z.png Last edited by rayers1060; 10th August 2019 at 02:07. Reason: added link to image |
10th August 2019, 09:55 | #17106 | Link | |
10th August 2019, 11:49 | #17108 | Link | |
2) No enough VRAM (1GiB)
10th August 2019, 18:42 | #17110 | Link | |
Shared folder
https://imgur.com/mh6Cc1K |
10th August 2019, 18:51 | #17111 | Link |
That's why people say to use VPN. You literally have to be a part of that LAN.
https://forums.tomshardware.com/thre...ernet.3389046/
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 10th August 2019 at 18:54. |
11th August 2019, 16:24 | #17114 | Link | |
Sorry for the late reply. Been away on business and just got back this past Friday. I noticed that 1.25 was released. I tried that one and the first thing I noticed on one of my machines, it reported that Haali Splitter was not installed. Strange as it was always installed. Either way i installed it via the link RipBot provided. I encoded:
Either way, thank you for your hard work and this great program!!!! |
11th August 2019, 19:05 | #17115 | Link |
Strange error after latest update
After Ripbot updated itself to the latest version, I did a test on several known files, and got this error: https://imgur.com/a/eKnHn1L . It only shows up on the server screen, not the log, which only says it could not open the file. The previous version encoded them perfectly, so I can only assume this is some sort of bug. I tried to download the newest version and do a fresh install, but the link on the page still only points to version 1.25.
12th August 2019, 16:18 | #17116 | Link | ||
ByteShare
I usually run a batch afterwards that muxes in subs from the source to keep the MKV titles, and the encoded audio from HandBrake since an old version handles audio the way I like, so I might not be the most help. Quote:
Also, try cropping the image Or WinKey + Shift + S to do a snip and select only the area you want for a screen grab. |
13th August 2019, 05:49 | #17117 | Link |
I am curious as to what these red indicators are.
I ask because I am seeing some strange actions during encoding. Some chunks are stalling before even starting. It seems to eventually start but it takes about a minute or more. I have six servers active (3 different machines) and four servers are stuck on "starting..." Does not always happen but it is intermittent. Any ideas?? Last edited by Viper714; 13th August 2019 at 05:55. |
13th August 2019, 10:11 | #17119 | Link |
Red = normal priority
Green = below normal Blue = low priority
13th August 2019, 14:04 | #17120 | Link |
Byteshare, I already tried removing the job several times with no luck. Imgur.com didn't complain about the file dimensions or size so I decided to be lazy and just post whole screen. Similar problems have happened occasionally after an update so I find that grabbing the latest version and doing a clean install usually solves the problem. The link still only points to 1.24 so I'll have to wait until Atak updates the link. What I find a little strange is that the error message only appears on the server screen, it doesn't get recorded in the log.
