11th July 2018, 23:56 | #15901 | Link | |
ByteShare
I can't remember if it was a version fix or what I did to fix it. I remember even if I had a vjoin_.exe and a vjoin.exe it would be an issue. |
11th July 2018, 23:58 | #15902 | Link | |
ByteShare
Should be something like this: Code:
Loadplugin("C:\RipBot\Tools\AviSynth plugins\RgTools\RgTools.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\nnedi3\nnedi3.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\masktools\masktools2.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\mvtools\mvtools2.dll") LoadCplugin("C:\RipBot\Tools\AviSynth plugins\Yadif\Yadif.dll") Import("C:\RipBot\Tools\AviSynth plugins\Scripts\QTGMC.avs") video=QTGMC(video,Preset="very slow",FPSDivisor=2) |
11th July 2018, 23:59 | #15903 | Link | |
ByteShare
12th July 2018, 00:58 | #15904 | Link | |
12th July 2018, 01:35 | #15905 | Link | |
C:\>"C:\Users\Main\Desktop\New folder\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "C:\Temp\RipBot264temp\job1\job1.avs" -strict -1 -f yuv4mpegpipe - | "C:\Users\Main\Desktop\New folder\tools\x264\x264_x64.exe" --colorprim bt709 --transfer bt709 --colormatrix bt709 --crf 20 --fps 30000/1001 --force-cfr --min-keyint 30 --keyint 300 --frames 43412 --sar 1:1 --level 4.1 --preset veryslow --tune film --aud --nal-hrd vbr --vbv-bufsize 62500 --vbv-maxrate 62500 --deblock=-2,-1 --b-pyramid=2 --sar 16:15 --stdin y4m --output "C:\Temp\RipBot264temp\video.264" - y4m [error]: bad sequence header magic x264 [error]: could not open input file `-' C:\>"C:\Users\Main\Desktop\New folder\tools\mkvtoolnix\mkvmerge.exe" -o "C:\09 Wonder Drug_Track01.mkv" --compression 0:none --title "09 Wonder Drug_Track01" --default-duration 0:30000/1001fps "C:\Temp\RipBot264temp\video.264" mkvmerge v23.0.0 ('The Bride Said No') 32-bit Error: buffer_c: num > m_filled. Should not have happened. Please file a bug report. ------------------------- Elapsed Time: 00h:00m:02s Last edited by Danette; 12th July 2018 at 01:51. |
12th July 2018, 06:05 | #15906 | Link | |
ByteShare
12th July 2018, 06:05 | #15907 | Link |
ByteShare
Nope, still have this issue:
Cannot load file 'C:/RipBot264/Tools/AviSynth plugins/KNLMeansCL/KNLMeansCL.dll'. Platform returned code 126: The specified module could not be found. Last edited by byteshare; 12th July 2018 at 07:09. |
12th July 2018, 08:04 | #15908 | Link |
Have you installed VC redist 2017 ?
12th July 2018, 09:08 | #15909 | Link | |
ByteShare
Yes, both x86 and x64.
I see: Microsoft Visual C++ 2005 Microsoft Visual C++ 2010 x86 Microsoft Visual C++ 2010 x64 Microsoft Visual C++ 2013 x86 Microsoft Visual C++ 2013 x64 Microsoft Visual C++ 2017 x86 Microsoft Visual C++ 2017 x64 only thing I see different on the computer working and the one not is that the one working has 2012 x86 and x64. I'm going to install those and see what happens. Last time I uninstalled all of the Microsoft Visual stuff and then only installed MSV 2017 x86 & x64 before the format. Update: tried again after installing Microsoft Visual C++ 2012 x86 & x64 and a reboot...same issue. Using AVSMeter: Quote:
12th July 2018, 22:21 | #15911 | Link |
Hello,
Another question I am not great at this so bare with my stupidity, please. I am trying to do an AVCHD of a movie it has DTS-HD. The only option I am getting is 2.0 FFMPEG AC3 256 kbps [cbr[. Is this right? How come I don't get a copy stream option? Thanks in advance! |
13th July 2018, 23:16 | #15913 | Link |
Software Developer
Having the same Java shit as above. After updating to 1.23.0, it says Java is not installed. But it is.
Disclaimer: Posts written by me are my views, ideas and opinions only, and should not be taken as facts, unless stated otherwise! |
14th July 2018, 03:04 | #15916 | Link | |
ByteShare
14th July 2018, 05:21 | #15917 | Link | |
I uninstall Ripbot and install 1.22 again and it works the first time I open it. Then, the second and subsequent times, it updates and then says I don't have Java installed. Rinse, repeat. |
14th July 2018, 12:51 | #15918 | Link |
If you are having issues with java detection then add
CheckRequiredSoftware=0 in RipBot264.ini under [settings] tag
15th July 2018, 00:10 | #15919 | Link | |
ByteShare
Update: (first time I've been able to get to the forums in a while) Fixed the problem by installing AMD's OpenCL driver. I was missing OpenCL.dll Last edited by byteshare; 19th July 2018 at 08:03. |
