#21 | Link |
That issue is because changing trim(0,1) in vub format (meaning single frame 0) would convert to trim(0,0) (entire clip).
So, is a 'special Case of trim(0,-1) which means 1 frame startiing at frame 0. Edit, issue arises because 0 as end frame, means 'all the way to the very last frame. Edit, having trouble with autocorrect.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 27th June 2016 at 23:24. |
#22 | Link | |
But there is another special case now: when I select frames 0-0 (0 frames) it creates the same Trim(0,-1) which is not good. Should it be Trim(0,0)? ![]() btw I edited msg 20
VirtualDub2 |
#23 | Link |
In vd, 0-0 (0 frames) should be ignored, there is no range.
#24 | Link |
In that case I will display a message.
Another question: I set a limit for importing frameset to 1024 chunks. Is it enough for all practical purposes or there exist a valid use case for importing more?
VirtualDub2 |
#25 | Link |
I'm sure that I would be more than happy with that
![]() Edit having quite bad problems, mo!bile.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 27th June 2016 at 23:56. |
#26 | Link |
I'm probably gonna dump vdubmod, it's kinda sad, really.
My auto correct keeps converting 'shekh' to 'enemy', is there something that you are not telling me ![]() Also corrects 'vdubmod' to 'crumble' for some strange reason.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 28th June 2016 at 11:58. |
#28 | Link | ||||
OK, tried new version, no problems that I can think of
![]() Tried copy plugin to vdub 1.10.4 plugins32, no crash (does not appear anywhere, presume its not supposed to). Avisynth Information, now does not crash, I dont really use that anyway, but nice it dont crash now (with no change in my Avs plugs dir). Quote:
Perhaps the disabled Crop() insertion could be of use (but I've never used it), it just allows user to set up crop inside VDub, then insert into script, user would then need to remove crop (usually attached to "Null transform filter"), and then refresh script. (add it or not, I'm happy either way). Thanks for posting the plugin source link, quite interesting. [EDIT: Project opened just fine in VS2008, have not tried to compile, yet] Can you remove the initial posted plugin link, you dont want people downloading that. Also, you perhaps want to shout a bit louder about your having added Vapoursynth script handling, I'm sure some will love that. One very small thing, in "Open With", your mod still shows as "VirtualDub" (same as official one), whereas VDMod shows as "www.virtualdub-fr.org", dont know where/how this is set but would it be possible to change so as to be able to select which version of VDub you want to open a file with (I've had to copy your exe into same place as original [and rename orig] so that I can right click and Open With. I actually now have about 6 or 7 versions of VD on sys, and would be nice if Open With worked with all of them individually. If I try to add another Open With VirtualDub, by browsing to your mod, it always uses the original one (hence the temp replacement). Anyways, I'm a very happy bunny already, thanks very much. All Hail Shekh ... ![]()
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 28th June 2016 at 15:05. |
#29 | Link |
Seems that afxres.h is not included with Express versions and so plugin cannot be compiled under VS 2008 Express.
(Part of MFC, is that really necessary ?) Code:
Compiling... accel.cpp c:\temp\vdfiltermod-scripted-d01fa5f6f9aeaf63cb6171347c2cad604e842fe1\accel.cpp(67) : fatal error C1083: Cannot open include file: 'afxres.h': No such file or directory AVSViewer.cpp c:\temp\vdfiltermod-scripted-d01fa5f6f9aeaf63cb6171347c2cad604e842fe1\avsviewer.cpp(62) : fatal error C1083: Cannot open include file: 'afxres.h': No such file or directory EDIT: For accel.cpp if I comment out include "afxres.h" I get this Code:
1>c:\temp\vdfiltermod-scripted-d01fa5f6f9aeaf63cb6171347c2cad604e842fe1\accel.cpp(80) : error C2065: 'ID_FILE_NEW' : undeclared identifier 1>c:\temp\vdfiltermod-scripted-d01fa5f6f9aeaf63cb6171347c2cad604e842fe1\accel.cpp(81) : error C2065: 'ID_FILE_OPEN' : undeclared identifier 1>c:\temp\vdfiltermod-scripted-d01fa5f6f9aeaf63cb6171347c2cad604e842fe1\accel.cpp(91) : error C2065: 'ID_EDIT_REDO' : undeclared identifier 1>c:\temp\vdfiltermod-scripted-d01fa5f6f9aeaf63cb6171347c2cad604e842fe1\accel.cpp(92) : error C2065: 'ID_EDIT_UNDO' : undeclared identifier 1>c:\temp\vdfiltermod-scripted-d01fa5f6f9aeaf63cb6171347c2cad604e842fe1\accel.cpp(102) : error C2065: 'ID_EDIT_FIND' : undeclared identifier Someone on StackOverFlow, says can replace afxres.h with windows.h if not using MFC.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 28th June 2016 at 15:50. |
#30 | Link | |
Best option right now is to add "b64a" output to Avisynth, as I already handle it. What else is possible? If its possible to automatically identify Avisynth output as stack16, I will add it (especially if it is rgb). Handling yuv would need a lot of supporting code which I dont want to implement right now.
VirtualDub2 |
#31 | Link | |
The only reason afxres is included is to have 5 ids like ID_FILE_NEW, better to just redefine them in resource.h.
VirtualDub2 Last edited by shekh; 28th June 2016 at 16:50. |
#32 | Link | |||
![]() Quote:
![]() I think these shell associations are created by some installers? I am not sure the code is in VirtualDub.
VirtualDub2 |
#33 | Link | ||||
I did copy/paste of FILE and EDIT id's from afxres.h into resource.h,
comment out include of afxres.h in both cpp files (no need to add include for windows.h). Resource.h has another include of afxres.h, commented out. resource.rc had another include, commented out, but then other problems, Code:
2>Compiling resources... 2>Microsoft (R) Windows (R) Resource Compiler Version 6.1.6723.1 2>Copyright (C) Microsoft Corporation. All rights reserved. 2>.\resource.rc(20) : error RC2144 : PRIMARY LANGUAGE ID not a number 2>.\resource.rc(55) : error RC2135 : file not found: 3 2>.\resource.rc(56) : error RC2135 : file not found: 4 2>.\resource.rc(57) : error RC2135 : file not found: 5 2>.\resource.rc(66) : error RC2135 : file not found: 6 2>.\resource.rc(73) : error RC2135 : file not found: 7 Quote:
![]() Quote:
![]() Quote:
before continuing. Bet it's done at that stage. Dont think that there is any way to tell Stack16 format. [EDIT: perhaps statistically fewer set bits in low byte].
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 29th June 2016 at 03:04. |
#34 | Link |
update from git, I just fixed it.
Note that there are project configurations for plugin and for standalone exe. exe is convenient for testing features which do not interact with VirtualDub. Or maybe it can be useful for something?
VirtualDub2 |
#35 | Link |
It's a long time since I installed Vdub, If I remember correctly, the VirtualDub.exe IS THE INSTALLER, and extracts
other stuff from inside itself. (I for years just copy a folder for ALL non-install programs, I can do a new OS setup and copy my NON-INSTALL folder to C:\ and copy the shortcuts folder into Start Menu\Programs\NON-INSTALL\ so can install all my non-install programs [at least 100], with minimum effort, and hotkeys installed too). Did registry search on "www.virtualdub-fr.org", and found this (only place in entire registry, except the copy of Current User) Code:
HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam\MUICache\ C:\NON-INSTALL\VDUB\VDUB_MOD\VirtualDubMod REG_SZ www.virtualdub-fr.org so somewhere in VD source there is a string "VirtualDub" that is installed to that location. I'll see if I can find the "www.virtualdub-fr.org" in vdmod source. EDIT: Here all places in vdmod source that have that string ("www.virtualdub-fr.org"). Code:
Setup.rc Changes.txt VirtualDub.rc Init.cpp projectui.cpp credits_mod.h Changes_MOD.txt Install_VDUB_ShellNoRoam.reg" Code:
Windows Registry Editor Version 5.00 [HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam\MUICache] "C:\\NON-INSTALL\\VDUB\\VDUB_MOD\\VirtualDubMod.exe"="www.virtualdub-fr.org" "C:\\NON-INSTALL\\VDUB\\VDUB_PLAIN\\VirtualDub.exe"="VirtualDub" "C:\\NON-INSTALL\\VDUB\\VDUB_DEEP\\VirtualDubDEEP.exe"="VirtualDubDEEP" EDIT: Obviously the path to the executables above is for my system only (ie, "C:\\NON-INSTALL\\VDUB\\VDUB_MOD\\" etc) Above double slashes are totally necessary for the .reg file (real path are only single backslash).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 29th June 2016 at 02:50. |
#36 | Link |
I tried to compile new source from Sourceforge, failed on resource.rc, #include "winres.h".
Winres.h not included in "Windows SDK for Windows 7 with DotNet 3.5 SP1" (one I'm using with vs 2008 Exp). So had a look at SDK I'm using for VS6(I had copy in VS6 include/mfc but wanted Express only access) and Toolkit 2003, ie "Windows Server 2003 R2 Platform SDK" (ISO:- http://download.cnet.com/Windows-Ser...l?tag=untagged) [EDIT: Mar 2006 Last SDK for VS6, despite some saying last is May 2005: See note 9 on wikipedia below https://en.wikipedia.org/wiki/Micros...DK#cite_note-9 ] and that has required header file in include\mfc. [EDIT: Need add that path to include 's] Compiled debug, and ran scripted.vdplugin OK. I dont usually do any multi-solution projects (or whatever you call them), but spent some time creating Release project and copied over a few things from the debug project (probably not all of below is necessary). Code:
Scintilla:- C/C++/General/Additional Include Directories/ include;lexlib;src C/C++/Preprocessor/Preprocessor definitions/ WIN32;NDEBUG;_LIB;SCI_LEXER;STATIC_BUILD;_CRT_SECURE_NO_WARNINGS;NO_CXX11_REGEX Librarian/General/Additional Dependencies/ imm32.lib Scripted:- General/Configuration Type/ Dynamic Library(.dll) C/C++/General/Additional Include Directories/ scintilla\include,VirtualDub C/C++/Preprocessor/Preprocessor definitions/ WIN32;_WINDOWS;_CRT_SECURE_NO_WARNINGS;PLUGIN C/C++/Code Generation/Runtime Library/ Multi-threaded (/MT) Linker/General/Outfile/ $(OutDir)\$(ProjectName).vdplugin Linker/Input/Additional Dependencies/ comctl32.lib Linker/Input/Module Definition File/ scripted.def Linker/System/Subsystem/ Windows (/SUBSYSTEM:WINDOWS) Linker/Advanced/Target Machine/ MachineX86 (/MACHINE:X86) EDIT: Its lovely not having to exit VDMod and start up VD Official just to run Video Analysis pass, me loves this, congrats on job well done, and appreciated so very much. ![]()
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 29th June 2016 at 12:53. |
#37 | Link | ||
Retried Guesser
Thanks for your good work, VirtualDub FilterMod is the best VirtualDub ever. EDIT "unstack" filter, good idea vvvv Last edited by raffriff42; 29th June 2016 at 14:27. |
#38 | Link |
If stack16 has no special metadata the best thing I can think of is to add stack16 to "alias format filter", or make another "unstack" filter exactly for this. Filter is good explicit way to express the intent and control it.
I`d like to hear who actually wants to use this and for what (simply transferring from avs to ffmpeg?) My own interest would be to study various denoising filters (in some future). --------------- Thanks for appreciation. My fork is still ridiculously hard to find and the download rate on sourceforge is vanishing. I wish I could stick a link onto official vd sourceforge ![]() btw would it be appropriate to move part of this thread related to avs editor to Avisynth development subforum?
VirtualDub2 |
#39 | Link | |
I have posted a notice in New Plugins & Utilities thread in AVS Usage, it should get some attention there as that thread is tracked by many forums and some kind of auto generated RSS or Special Interest feeds (not sure what they are called). EDIT: Here's the link to New Plugins & Utilities:- http://forum.doom9.org/showthread.ph...15#post1772115 PM me with link if your want me to change link to ScriptEd, to somewhere else (eg 1st post of this thread if you put link there).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 29th June 2016 at 15:00. |
#40 | Link | |
I unpacked VirtualDub.exe and plugins32 over a 32b pack 37200. Started VirtualDub.exe on Windows 7 SP1 Ult. 64b ger. Process stays in the background, does not show a visible window. Need a task manager to kill the process. I unpacked Veedub64.exe and plugins64 over a 64b pack 37201. Started Veedub64.exe on Windows 7 SP1 Ult. 64b ger. Process stays in the background, does not show a visible window. Need a task manager to kill the process. |
