Old 25th June 2008, 23:06   #21  |  Link
zemog
Originally Posted by mikeytown2 View Post
BTW what does AGG stand for?
Nothing important, just an identifier, based in my family name, that I used to add to the functions written by my for my own use.
If you add some improvement or new feature, you can change it at your preference.
zemog is offline   Reply With Quote
Old 25th June 2008, 23:13   #22  |  Link
mikeytown2
Resize Abuser
mikeytown2's Avatar
Originally Posted by Gavino View Post
[EDIT: I bet you tested it with static clips, eg ColorBars ]
how did u know?!?!
Thanks for the input, I think all the problems fixed now. As for pc_range=true, it probably has something to do with the mask. IanB used it in post #9 above. I also added an audio check.
# DissolveAGG() June 25th, 2008
#  Dissolve with a Wipe. Wipe has alpha channel mask for nice effect.
# Inputs
#  clip a - starting clip
#  clip b - ending clip
#  int "Duration" - Number of overlapped frames
#  string "Mode" - Four modes are possible: LeftToRight, RightToLeft, TopToBottom, BottomToTop.
#  float "WindowSize" - 2.0 is default. larger: more sharp.
#  float "MaskSharpnessStart" - 1: Big Blur; 100: Sharpest. Default 50.
#  float "MaskSharpnessEnd" - 1: Big Blur; 100: Sharpest. Default 50.
Function DissolveAGG(clip a, clip b, int "Duration", string "Mode", float "WindowSize", float "MaskSharpnessStart", float "MaskSharpnessEnd")
	#Set Defaults
	Duration=Default(Duration,30)
	width=a.width()
	height=a.height()
	Mode=Default(Mode, "LeftToRight")
	MaskSharpnessStart=Default(MaskSharpnessStart, 50.0)
	MaskSharpnessEnd=Default(MaskSharpnessEnd, 50.0)
	WindowSize=Default(WindowSize, 2.0)
	AudioMix=Dissolve(a, b, Duration).KillVideo()
	a = a.KillAudio()
	b = b.KillAudio()
	#Check Input
	Assert(Mode=="LeftToRight" || Mode=="RightToLeft" || Mode=="TopToBottom" || Mode=="BottomToTop",
	\"DissolveAGG: Only Four Modes are possible: LeftToRight, RightToLeft, TopToBotoom BottomToTop. Mode=" + Mode)
	Assert(Duration >= 0, "DissolveAGG: Duration [" + String(Duration) + "] must be a positive value")
	Assert(Duration <= a.Framecount()-1, "DissolveAGG: Duration[" + String(Duration) + "] is greater then " + Chr(10) + "clip A length[" + String(a.Framecount()-1) + "]")
	Assert(Duration <= b.Framecount()-1, "DissolveAGG: Duration[" + String(Duration) + "] is greater then " + Chr(10) + "clip B length[" + String(b.Framecount()-1) + "]")
	#Set Parameters
	EvalString = Mode=="LeftToRight"? "BlankWidth=Int(4/2*WindowSize)
	BlankHeight=height
	startX1=BlankWidth + 0.5
	endX1=1.5
	startY1=0
	endY1=0
	x2=WindowSize*2-2
	y2=0
	ClipLeft=b
	ClipLeftStart=0
	ClipLeftEnd=Duration
	ClipRight=a
	ClipRightStart=FrameCount(a)-Duration-1
	ClipRightEnd=0" : Mode=="RightToLeft"? "BlankWidth=Int(4/2*WindowSize)
	BlankHeight=height
	startX1=1.5
	endX1=BlankWidth + 0.5
	startY1=0
	endY1=0
	x2=WindowSize*2-2
	y2=0
	ClipLeft=a
	ClipLeftStart=FrameCount(a)-Duration-1
	ClipLeftEnd=0
	ClipRight=b
	ClipRightStart=0
	ClipRightEnd=Duration" : Mode=="TopToBottom"? "BlankWidth=height
	BlankHeight=Int(6/2*WindowSize)
	startX1=0
	endX1=0
	startY1=BlankHeight + 0.5
	endY1=3.5
	x2=0
	y2=WindowSize*2-2
	ClipLeft=b
	ClipLeftStart=0
	ClipRight=a
	ClipRightEnd=0" : Mode=="BottomToTop"? "BlankWidth=height
	startX1=0
	endX1=0
	startY1=3.5
	endY1=BlankHeight + 0.5
	x2=0
	y2=WindowSize*3-4
	ClipLeft=a
	ClipLeftEnd=0
	ClipRight=b
	ClipRightStart=0
	ClipRightEnd=Duration" : ""
	Eval(EvalString)
	#Make Mask
	BlackBar = BlankClip(a, length=Duration+1, width=BlankWidth, height=BlankHeight, pixel_type="RGB32")
	WhiteBar = BlankClip(BlackBar, color=$FFFFFF)
	BWmask = Mode=="LeftToRight" || Mode=="RightToLeft" ? StackHorizontal(BlackBar,WhiteBar) : StackVertical(BlackBar,WhiteBar)
	BWmask = BWmask.Animate(0,Duration,"GaussResize",
	\ width, height, startX1, startY1, x2, y2, MaskSharpnessStart,
	\ width, height, endX1, endY1, x2, y2, MaskSharpnessEnd)
	#Glue it together
	Trim(a, 0, FrameCount(a)-Duration-1)
	last + Overlay(Trim(ClipLeft, ClipLeftStart, ClipLeftEnd), Trim(ClipRight, ClipRightStart, ClipRightEnd), mask=BWmask, pc_range=True)
	last + Trim(b, Duration+1, 0)
	HasAudio(AudioMix) ? AudioDub(last,AudioMix) : last
mikeytown2 is offline   Reply With Quote
Old 26th June 2008, 01:44   #23  |  Link
Gavino
Avisynth language lover
It's more or less there, but I think it's still not quite right.
Frame Framecount(a)-Duration-1 of a is repeated.
(ShowFrameNumber can be useful for testing these sort of things.)
I'm not sure about this bit, but the way I see it, the mask should be of length Duration.
Clip a's part in the transition should run from Framecount(a)-Duration to the end, and clip b's part from 0 to Duration-1.
Then the final part of the total should be b.Trim(Duration, 0).
Or is it just that the mask is extended by one frame at the end to cover the first full frame of b, and it all works out? (If so, why don't you need to do the same at the beginning of the mask, making it Duration+2?)
In the validation checks, Duration needs to be strictly > 0 (perhaps even > 1 in the light of the above), otherwise Animate will fail (and you have 2 typos ("then") in the error msgs).
(Funny how it's always easier to spot errors in someone else's code. )
As for pc_range, I imagine IanB had a good reason. but I'd like to understand it as pc_range does not affect the mask in Overlay.
EDIT: I'm now wondering if in fact you need to append a blank frame to a, prepend a blank frame to b, and use a mask of length Duration+2 ??
Old 26th June 2008, 16:04   #24  |  Link
Gavino
Here's an update which I think gets the transition boundaries exactly right. It even handles a Duration of 0, which effectively reduces to a splice.
I've also made MaskSharpnessEnd default to MaskSharpnessStart so you only have to specify the latter one if you want them to be the same. Also did some minor fixes and tidying up.
# DissolveAGG() June 27th, 2008
# Inputs
#Set Defaults
width=a.width()
height=a.height()
MaskSharpnessEnd=Default(MaskSharpnessEnd, MaskSharpnessStart)
a = a.KillAudio()
b = b.KillAudio()
#Check Input
\"DissolveAGG: Only Four Modes are possible: LeftToRight, RightToLeft, TopToBottom, BottomToTop. Mode=" + Mode)
Assert(Duration >= 0, "DissolveAGG: Duration [" + String(Duration) + "] must not be a negative value")
Assert(Duration < a.Framecount(), "DissolveAGG: Duration[" + String(Duration) + "] must be less than " + Chr(10) + "clip A length[" + String(a.Framecount()) + "]")
Assert(Duration < b.Framecount(), "DissolveAGG: Duration[" + String(Duration) + "] must be less than " + Chr(10) + "clip B length[" + String(b.Framecount()) + "]")
#Set Parameters
aMid = Trim(a, FrameCount(a)-Duration, 0)
bMid = Trim(b, 0, -Duration)
BlankHeight=height
endX1=1.5
startY1=0
endY1=0
x2=WindowSize*2-2
y2=0
ClipLeft=bMid
ClipRight=aMid" : Mode=="RightToLeft"? "BlankWidth=Int(4/2*WindowSize)
BlankHeight=height
startX1=1.5
startY1=0
endY1=0
x2=WindowSize*2-2
y2=0
ClipLeft=aMid
ClipRight=bMid" : Mode=="TopToBottom"? "BlankWidth=width
startX1=0
endX1=0
endY1=3.5
x2=0
y2=WindowSize*3-4
ClipLeft=bMid
ClipRight=aMid" : Mode=="BottomToTop"? "BlankWidth=width
startX1=0
endX1=0
startY1=3.5
x2=0
y2=WindowSize*3-4
ClipLeft=aMid
ClipRight=bMid" : ""
Eval(EvalString)
#Make Mask
BlackBar = BlankClip(a, length=Duration+2, width=BlankWidth, height=BlankHeight, pixel_type="RGB32")
BWmask = BWmask.Animate(0,Duration+1,"GaussResize",
\ .Trim(1, Duration)
#Glue it together
last = (Duration > 0 ? last + Overlay(ClipLeft, ClipRight, mask=BWmask, pc_range=True) : last)
last + Trim(b, Duration, 0)
Old 27th June 2008, 12:29   #25  |  Link
Gavino
Another bug fixed (mask handling in TopToBottom mode with non-default Window). Edited previous post rather than posting it all again.
Thanks to mikeytown2 for doing most of the hard work on this version, gracias a zemog for original version and credit to IanB for outline idea.
Old 27th June 2008, 23:08   #26  |  Link
Chainmax
Huh?
Chainmax's Avatar
I have a problem with FadeIn0 and FadeOut0. I am using the following simple script:
video=Mpeg2source("X:\wherever\clip.d2v")
audio=NicAC3Source("X:\wherever\clip.ac3")
AudioDub(Video,Audio)
SeparateFields()
Spline36Resize(656,224)
AddBorders(32,8,32,8)
FadeIn0(30)
FadeOut0(60)
Weave()
But it seems like the fade-out only lasts 30 frames and the fade-in isn't even considered at all. Am I missing something?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it.
Chainmax is offline   Reply With Quote
Old 28th June 2008, 00:01   #27  |  Link
Gavino
You need to put the fades after the Weave (which halves the framerate). The fade-in probably was there, but would have been only 15 frames and so easily missed, especially if your clip starts off dark.
BTW I'm not sure if this really belongs in this thread, although I suppose it's in the same general area.
Old 28th June 2008, 09:13   #28  |  Link
mikeytown2
Resize Abuser
mikeytown2's Avatar
Gavino, thanks for polishing up the function! Been busy for the last couple of days.
Chainmax you could try adding the fades before SeparateFields() as well. Other then that, I have no idea on the fade in.
Old 2nd July 2008, 00:18   #29  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
....or just double the framecount, so that it actually fades every field (as you'd want for interlaced material), instead of screwing up the temporal fade.
Old 8th July 2008, 07:03   #30  |  Link
mikeytown2
Resize Abuser
mikeytown2's Avatar
Starting to get somewhere... I'm using Fizick's Rotation Plugin (1.31) to rotate the mask.
http://avisynth.org.ru/rotate/rotate.html
# DissolveAGG() July 7th, 2008
#  Dissolve with a Wipe. Wipe has alpha channel mask and selectable angle for nice effect.
# Inputs
#  float "Angle" - Angle of the wipe
Function DissolveAGG(clip a, clip b, int "Duration", float "Angle", float "EndAngle", string "Mode", float "WindowSize", float "MaskSharpnessStart", float "MaskSharpnessEnd")
#Set Defaults
Duration=Default(Duration,Round(Framerate(a)))
Angle=Default(Angle,0)
EndAngle=Default(EndAngle,Angle)
width=a.width()
height=a.height()
Diagonal = Ceil(sqrt(pow(width(a),2)+pow(height(a),2)))
a = a.KillAudio()
b = b.KillAudio()
#Check Input
#Set Parameters
BlankHeight=Diagonal
endX1=1.5
startY1=0
endY1=0
x2=WindowSize*2-2
y2=0
ClipLeft=bMid
startX1=1.5
startY1=0
endY1=0
x2=WindowSize*2-2
y2=0
ClipLeft=aMid
ClipRight=bMid" : Mode=="TopToBottom"? "BlankWidth=Diagonal
startX1=0
endX1=0
endY1=3.5
x2=0
y2=WindowSize*3-4
ClipLeft=bMid
ClipRight=aMid" : Mode=="BottomToTop"? "BlankWidth=Diagonal
startX1=0
endX1=0
startY1=3.5
x2=0
y2=WindowSize*3-4
ClipLeft=aMid
Eval(EvalString)
#Make Mask
\ Diagonal, Diagonal, startX1, startY1, x2, y2, MaskSharpnessStart,
\ Diagonal, Diagonal, endX1, endY1, x2, y2, MaskSharpnessEnd)
BWmask = BWmask.Trim(1, Duration).Animate(0, framecount(BWmask)-1, "Rotate", Angle, $000000, 0, -1, Angle, width, height,  EndAngle, $000000, 0, -1, EndAngle, width, height)
#Glue it together
Example
a = ColorBars(320,320).Trim(0,99)
b = a.invert()
DissolveAGG(a,b, 80, angle=-15.0, endangle=105.0, WindowSize=10)
It's not "perfect" because it uses the clip's Diagonal to calc the mask, thus the start and end is a little off. thats what the -15 and 105 is for. Ideally it would be 0 and 90. It falls apart if its not square like it is for the example.
Edit: I think if i where to use EffectRotation i could make this behave better, because i can select the center of rotation. I could do it with zoom as well now that i think about it. Doing that i should be able to keep the arc in the corner, and that should get rid of the -15 and 105 oddness. it will be hard to make this a smart function...
Old 9th July 2008, 15:16   #31  |  Link
NerdWithNoLife
NerdWithNoLife's Avatar
I don't know if this is what you want, but you can do a slide-in with KenBurnsEffect. Let's assume you have a 640x480 video:
a=AviSource("clipA.avi")
b=AviSource("clipB.avi")
StackHorizontal(a,b)
KenBurnsEffect(startFrame=0, endFrame=29, endPanX=0, startPanX=-640).crop(0,0,640,480)
I think it has to be RGB32, so you may have to add ConvertToRGB32()
NerdWithNoLife is offline   Reply With Quote
Old 10th July 2008, 08:38   #32  |  Link
tin3tin
tin3tin's Avatar
The link at the first post seems to be down, so I can't see what transition you're after. These are the avs transitions included in DVD slideshow GUI. They are just avisynth scripts located in the DVD slideshow GUI\Transitions folder.
A lot of them are done with vcmohan's great transall plugin.
DVD slideshow GUI(Freeware).
tin3tin is offline   Reply With Quote
Old 10th July 2008, 10:40   #33  |  Link
mikeytown2
Resize Abuser
mikeytown2's Avatar
Here's an UGLY hack of the above working with 0 and 90. Requires KenBurnsEffect
Function DissolveAGG_test(clip a, clip b, int "Duration", float "Angle", float "EndAngle", string "Mode", float "WindowSize", float "MaskSharpnessStart", float "MaskSharpnessEnd")
#Set Defaults
width=a.width()
height=a.height()
a = a.KillAudio()
b = b.KillAudio()
#Check Input
#Set Parameters
EvalString = "BlankWidth=Int(4/2*WindowSize)
ClipLeft=bMid
ClipRight=aMid"
Eval(EvalString)
#Make Mask
BWmask = StackHorizontal(BlackBar,WhiteBar)
BWmask = BWmask.GaussResize(width, Diagonal)
BWmask = BWmask.AddBorders(Diagonal-width/2,0,0,0).AddBorders(0,0,Diagonal-width/2,0,$FFFFFF)
BWmask = StackVertical(BWmask, BlankClip(BWmask))
BWmask = BWmask.Animate(0, framecount(BWmask)-1, "Rotate", Angle, $000000, 0, -1, Angle, BWmask.width(), BWmask.height(),  EndAngle, $000000, 0, -1, EndAngle, BWmask.width(), BWmask.height())
BWmaskA = BWmask.Trim(0,-Duration/4).KenBurnsEffect(width=Round(width*1.0),height=Round(height*1.0),startzoomfactor=-100,endzoomfactor=-100, startalign=5, endalign=5, startpanX=-Diagonal-BlankWidth/8, endpanX=-Diagonal, startpanY=Diagonal/(float(width)/height), endpanY=Diagonal/(float(width)/height))
BWmaskB = BWmask.Trim(Duration/4,(Duration*3)/4-1).ZoomBox(Round(width*1.0),Round(height*1.0),zoomfactor=-100, align=5, panX=-Diagonal, panY=Diagonal/(float(width)/height))
BWmaskC = BWmask.Trim((Duration*3)/4,0).KenBurnsEffect(width=Round(width*1.0),height=Round(height*1.0),startzoomfactor=-100,endzoomfactor=-100, startalign=5, endalign=5, startpanX=-Diagonal, endpanX=-Diagonal, startpanY=Diagonal/(float(width)/height), endpanY=Diagonal/(float(width)/height)+BlankWidth/8)
BWmask = BWmaskA+BWmaskB+BWmaskC
#Glue it together
#BWmask
a = ColorBars().Trim(0,99)
b = a.invert()
DissolveAGG_test(a,b, 80, 0.0, 90.0, WindowSize=20)
The main advantage of this function over transall is the blurred mask. The transition line is softer and adjustable with DissolveAGG
Old 10th July 2008, 12:02   #34  |  Link
Gavino
BWmaskA = BWmask.Trim(0,-Duration/4). etc
BWmaskB = BWmask.Trim(Duration/4,(Duration*3)/4-1). etc
BWmaskC = BWmask.Trim((Duration*3)/4,0). etc
I haven't tried it out or anything, but I can see that this part won't work with Duration < 4.
Bit messy to fix, perhaps easiest just to replace the last of these lines with
BWmask = Duration < 4 ? BWmask : BWmaskA+BWmaskB+BWmaskC
Extreme cases are the acid test of whether an algorithm is correct. A good test case is Duration=1 which should show a single frame with 50% of both clips.
BTW You've left a stray ShowFrameNumber on the line previous to these.
