16th August 2022, 11:30 | #4581 | Link |
How can we encode and have 3 audio tracks?
Update: never mind. I see multiple audio tracks are implemented. In the container I thought you could only add and mux audio. But you can actually also encode there. Thank you. Last edited by Atlantis; 16th August 2022 at 21:58. |
30th August 2022, 14:08 | #4582 | Link |
Here is a machine translation of a beginner-friendly guide, originally authored by Doom9 member Brother John.
The translation process was easier than a thought it would, but I think the result is already good. Some things are not yet up-to-date. Tools used: https://www.deepl.com/translator https://github.com/marktext/marktext Find it here: website: https://staxrip.github.io/x265-encoding-tutorial website repo: https://github.com/staxrip/x265-encoding-tutorial I've updated the staxrip wiki, so people can find it. Native speakers helping to update it would be very helpful.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 30th August 2022 at 14:11. |
21st September 2022, 01:58 | #4583 | Link |
Changed PC today, now with Windows 11 instead of Windows 10.
Now, mp4 files re-encoded with VideoRedo won't load in StaxRip. Any help will be gladly appreciated. Thanks. Last edited by maupassant; 21st September 2022 at 03:50. |
21st September 2022, 07:49 | #4584 | Link | |
Formally known as .......
https://learn.microsoft.com/en-us/cp...?view=msvc-170 After all, that error msg is for this |
21st September 2022, 15:43 | #4585 | Link | |
Yes, I did. All of them. Last edited by maupassant; 21st September 2022 at 15:54. |
4th November 2022, 01:36 | #4586 | Link |
DPX -> HEVC@Veryslow
so I have this line loaded into stax vapoursynth
"clip = havsfunc.SMDegrain(clip, tr=2, Str=1.5, pel=1, search=3, prefilter=6, thSAD=180, contrasharp=True, truemotion=False, RefineMotion=True, chroma=False, plane=0)" what i want is to enter more parameters for the prefilter=6 which is BM3DCUDA. how do i do that? |
11th November 2022, 02:27 | #4587 | Link | |
eg:- Code:
(clip,tr=8,thSAD=800,thSADC=400,thSCD1=400,thSCD2=130,contrasharp=true,prefilter=6,str=1.2,refinemotion=true,blksize=8) |
11th November 2022, 21:12 | #4588 | Link |
well the call puts the parameters for SMDegrain and not for the prefilter.
the syntax for BM3DCUDA is like this: BM3D_CUDA (clip, clip "ref", float[] "sigma", int[] "block_step", int[] "bm_range", int "radius", int[] "ps_num", int[] "ps_range", bool "chroma", int "device_id", bool "fast", int "extractor_exp") but I don't understand how to integrate this parameters into the SMDegrain line. Examples DGSource("sample.dgi") ConvertBits(bits=32) BM3D_CUDA(sigma=0.5, radius=2) BM3D_VAggregate(radius=2) ConvertBits(bits=16) the example is from http://avisynth.nl/index.php/BM3DCUDA |
16th November 2022, 02:40 | #4589 | Link | |
However, maybe you could try something like this :- Code:
pre=BM3D_CUDA(sigma=5,radius=1) SMDegrain(tr=4,thSAD=400,thSADC=200,thSCD1=400,thSCD2=130,contrasharp=true,prefilter=pre,str=1.2,refinemotion=true) |
22nd November 2022, 22:31 | #4590 | Link |
Stax
Is StaxRIP still being worked on? There are new features in Rigaya NVenc that may need to be incorporated as well as updates on many plugins
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
26th November 2022, 00:45 | #4591 | Link | |
Same goes for Handbrake, last build was way back in Jan '22. And not that too many seem to use RipBot264, it's also pretty much stalled, too. Edit:- got a substantial RipBot264 update today Last edited by TDS; 26th November 2022 at 01:10. |
29th November 2022, 11:15 | #4593 | Link | |
https://github.com/cdgriffith/FastFl...ases/tag/5.0.0 |
29th November 2022, 23:43 | #4594 | Link |
Big Bit Savings Now !
AV1 is already in Staxrip (2.13.0): AOMEnc, Rav1e, SVT-AV1
11th December 2022, 16:29 | #4596 | Link |
https://github.com/staxrip/staxrip/graphs/contributors
If all are really nice to stax76, Dendraspis, JKyle, and all the others I guess yes ;-)
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 11th December 2022 at 16:32. |
12th December 2022, 05:46 | #4597 | Link | |
So, unless you are "brave" enough to update it yourself, who knows what's going on, moving forward. Sad, really, and it's not the only encoding app that seems to be "slipping behind" |
24th December 2022, 12:14 | #4598 | Link |
Hi all,
I have some MP4 files that I want to remux into MKV Mediainfo shows a content description in the General>Comment section in the MP4. After remuxing that information is gone ... Is there a way to copy that information over into the MKV with StaxRip? |
28th December 2022, 18:53 | #4599 | Link |
I'd really like to know that as well. I took a look at some of its components last week, and a lot of them were outdated. While you can manually update the latest binaries for some stuff like FFMpeg, SVT-AV1, or AOMEnc, there's some stuff that seems to stop working with newer versions. VapourSynth, for example, is already on v61, but updating it manually from v54 seems to break things.
If the development has stopped and the author is no longer interested in (or capable of) updating the tool with new features, perhaps you could at least consider doing occasional across-the-board-component-update maintenance releases from now on, so the more casual users can at least get the performance benefits of encoder updates, newer FFMpeg features, and so on? |
29th December 2022, 19:38 | #4600 | Link |
I want to encode a large .avi file (200GB, FICV) to x264.
The auto-selection for the source is FFVideoSource instead of AVISource. The ffindex build time is too long. In the case of .avi files is there any advantage to using FFVideoSource?
Greece PAL User... |
