3rd January 2010, 17:07 | #41 | Link | |
Software Developer
3rd January 2010, 19:22 | #43 | Link |
Unregistered User
What about --autoresize WxH or --fittobox WxH
my subtitle site |
3rd January 2010, 20:08 | #44 | Link |
HDConvertToX author
the "!" character iirc has special pourpose on DOS shell...
BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
3rd January 2010, 20:14 | #45 | Link |
What about cropping?
It's the main filter I use -most 2.35:1 and 1.85:1 movies need cropping- along with resizing (via AviSynth currently) Some kind of preview for cropping would be nice so I can see what's it's gonna be like before encoding (I currently use GraphStudio + AvsP and save to .avs), I guess a lot of people use a preview function in a GUI they use for crop/resize preview |
3rd January 2010, 20:15 | #46 | Link | |
x264 developer
3rd January 2010, 22:36 | #47 | Link | |
3rd January 2010, 22:49 | #48 | Link |
I tried the beta executable in the first post on a typical NTSC DVD vob file. I don't know if this is a problem in just this build, but when I tell it to encode straight to an MP4 container, the video is all blocky. If I tell it to go straight to raw 264 stream, and mux it with YAMB, it does nicely.
YAMB output: http://img695.imageshack.us/img695/7128/outx.png x264 output: http://img684.imageshack.us/img684/9812/out2.png Edit: Nevermind about the frame rate issue, it was variable and I was looking at it incorrectly. Edit2: Matroska exports work fine. Last edited by bnshrdr; 3rd January 2010 at 22:58. |
4th January 2010, 00:58 | #51 | Link | |
Spinner of yarns
http://www.esnips.com/doc/1a661a92-0...v1379_release3 Mirror (megaupload) http://www.megaupload.com/?d=LY5OXCR3 The patch is here. http://pastebin.com/m6d750da9 I am managing timecode format file I/O.
僕と契約して、L-SMASH developerになってよ! L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software Last edited by VFR maniac; 4th January 2010 at 01:21. |
4th January 2010, 01:16 | #52 | Link | |
Please could you upload it elsewhere (Megaupload) ? |
4th January 2010, 02:54 | #54 | Link | |
1) mkvmerge does not need timecodes file because it correctly handles pts from input files. 2) MP4Box does not support matroska timecode files |
4th January 2010, 04:56 | #55 | Link |
This is only tangentially related to the thread, but could a "--timecodes" parameter be added to x264, so it can load external timecodes (e.g. v1/v2 Matroska) for use with input methods other than LAVF/FFMS? This would allow for bitrate-based control over input formats that are CFR in nature (e.g. Avisynth, YUV, Y4M). This would eliminate the need to calculate the average framerate of these sources, and would allow an accurate bitrate report in the output.
4th January 2010, 05:02 | #56 | Link | |
x264 developer
4th January 2010, 10:37 | #57 | Link |
HDConvertToX author
fyi i added initial support for this x264 build to my MicroX264.
now is possible to select demuxer (no audio or resize is done) BHH
4th January 2010, 12:15 | #58 | Link |
HDConvertToX author
--demuxer avs and --demuxer ffms detect different framerate even if both using ffmpegsource
C:\PROGRA~1\PUREBA~2\_TESTF~1\NUOVAC~1>x264.exe --output zzz.mkv --demuxer ffms vc1.fps.problem.m2ts ffms [info]: 1920x1080p 1:1 @ 30000/1001 fps (vfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2 SSE3 Cache64 x264 [info]: profile High, level 4.0 ^C C:\PROGRA~1\PUREBA~2\_TESTF~1\NUOVAC~1>x264.exe --output zzz.mkv --demuxer avs vc1.fps.problem.m2ts avs [info]: trying FFmpegSource2... indexing... succeeded avs [info]: 1920x1080p 0:0 @ 250000/8211 fps (cfr) x264 [info]: using cpu capabilities: MMX2 SSE2 SSE3 Cache64 C:\PROGRA~1\PUREBA~2\_TESTF~1\NUOVAC~1>x264.exe --output zzz.mkv --demuxer lavf vc1.fps.problem.m2ts [mpegts @ 0030a6b0]MAX_READ_SIZE:5000000 reached lavf [info]: 1920x1080p 1:1 @ 30000/1001 fps (vfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2 SSE3 Cache64 BHH
4th January 2010, 13:14 | #59 | Link | |
1. reencode input with x264 (creating a .264 and a timecode file) 2. convert audio (creating a bunch of .mp3, .aac, .ac3 files) 3. multiplex subtitles, audio, video with the timecode file and a bunch of tags Would it be hard to output mp4 time code files? |
4th January 2010, 13:15 | #60 | Link | |
With true vfr support the fps value does not really matter, you can use any value without losing a/v sync. Last edited by roozhou; 4th January 2010 at 13:23. |
beta, ffmpegsource, libavformat, test, x264 |
