Old 2nd October 2019, 18:09   #6721  |  Link
v0lt
Perhaps a signed beta will be released this fall. A stable release requires more time to prepare.
v0lt is offline   Reply With Quote
Old 3rd October 2019, 18:42   #6722  |  Link
wushantao
Originally Posted by zamar92 View Post
It won't play without TorrServer running. Some features were added to MPC-BE recently to support TorrServer similar way it already supported AceStream. TorrServer is usually run on a PC or device on LAN, it downloads torrent pieces sequentially and presents current cache in RAM as a media file served to the player on request via HTTP. TorrServer leeches changing cache content to the swarm while the torrent is played, but no local disk media copies are preserved or needed. Its convenient when local HDD space is restricted, or when using SSDs, flash, or permanent memory blocks with limited write & erase cycles. One can quickly preview, watch, or search & fast forward a movie without downloading first the entire copy. Its more robust than AceStream in 4K content watching. Currently TorrServer v1.1.68 seems the most stable with desktop players like MPC-BE.
As more folks wonder how to use TorrServer with MPC-BE, there's a small Russian Manual already in need of some update, but meanwhile hopefully can help someone. One can translate that page to their language with Chrome browser.
It's interesting to learn how these new player features work with international torrent trackers, and whether any bugs are observed or extra features desired? Just a reminder, its the player user sole responsibility to select lawful content for watching in their country.
thank you. i have already run the test. if this can automatically load the subtitles, that is perfect
wushantao is offline   Reply With Quote
Old 4th October 2019, 02:38   #6723  |  Link
Anima123
When repeatedly stroke left key (forward 4 seconds) during playback, the player will stuck eventually. It's bad since I will have to ctrl+Alt+Del to switch to another user in order to kill the player, when playback is in full-screen, in which case the Task Manager will not be visible.
Is it possible to fix it? I know watch a movie or show probably won't need it, but there're cases that do need to skip during playback, it would be really nice if this problem can vanish.
Anima123 is offline   Reply With Quote
Old 4th October 2019, 02:55   #6724  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Can't reproduce. I very often using seeking when watch serials - all perfect.
1 - What version MPC-BE.
2 - Show filters when playback.
3 - Reset setting.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 4th October 2019, 03:00   #6725  |  Link
Anima123
3 - Reset setting.
Probably you were not repeat frequently enough. It worked most of the time, until it hangs.
1 - 1.5.4.4792.x64
2 - I was using MPC Video Renderer, but the hang won't go away with other video renders, like madVR
3 - Will try it and see if it helps.
Old 4th October 2019, 03:24   #6726  |  Link
Aleksoid1978
I repeat very often
P.S. Try using only internal filters + EVR/EVR-CP.
Old 4th October 2019, 06:30   #6727  |  Link
zamar92
Originally Posted by wushantao View Post
thank you. i have already run the TorrServer test. if this can automatically load the subtitles, that is perfect.
Indeed the devs added a whole set of new features to support torrents playback more comprehensively. Surprisingly, the player can auto-load subtitles in TV shows with multiple episodes. The setting is not very intuitive though: Options - Playback - Remember selected tracks in playlist. It covers both audio and subtitles. I suggested to separate them to make more obvious for users, but it works.
zamar92 is offline   Reply With Quote
Old 4th October 2019, 06:34   #6728  |  Link
zamar92
when playback is in full-screen, Task Manager will not be visible.
Try Alt+Tab to return to desktop.
Old 4th October 2019, 07:37   #6729  |  Link
wushantao
will try it later
Old 4th October 2019, 14:26   #6730  |  Link
zamar92
will try it later
For slow torrents, one can also stop episodes jumping on network error by deselecting Goto Next on Error in Playlist Context Menu, and adjust Network wait time for a torrent to start playing in Options - Player - Other.
One can put
/add [HREF]
in Arguments of External Application Button or similar transfer control app, and uncheck adding Quotes to arguments, to amend MPC-BE Playlist with a list of different torrents to play by pointing to their magnet links as shown in the above Manual.
I also suggested to preserve TV Show and episode names in Recent files menu instead of direct torrent links, so a user could select the right one later. Another suggestion was to store torrent TV Show names in Favorites instead of their Episode names for easy selection later. Hopefully these features will be implemented one day, as its reasonably possible.
Old 5th October 2019, 17:28   #6731  |  Link
BetA13
cosmic entity
BetA13's Avatar
hy,
The MPC VR works really nice now for me now.. very light and fast.. THX for the Updates...
Theres only one Thing bugging me..
I dint know if there are plans to add more stuff but an option for "Debanding" would be very nice...
Thats the only thing missing for me to makes this renderer an default for my Windows installations..
If there are no Plans for it, would there be a way to use debanding externaly? like with shaders or something...
WHat ever might be the Answer, Thanks for the Renderer and all teh work for it....
Best Regards
BetA13 is offline   Reply With Quote
Old 5th October 2019, 18:24   #6732  |  Link
v0lt
@BetA13
Any additional post-processing cannot be added right now. We need a lot of code rework.
Old 5th October 2019, 18:41   #6733  |  Link
BetA13
cosmic entity
BetA13's Avatar
ok, Thank you for the quick Info
looking forward to the future of this Project..
Old 6th October 2019, 07:06   #6734  |  Link
Anima123
v0lt, what's the mpcvr-v0.3.3.868_dx9_dxva2vp_amd_1 is for?
The one that can be found it in the Russian forum on MPC VR renderer.
Old 6th October 2019, 10:11   #6735  |  Link
v0lt
This is for a user who has a problem with timeline navigation after 864.
Old 8th October 2019, 09:22   #6736  |  Link
Klaus1189
Updated german translation based on r4800
How do I see actual values in video decoder Status in the lower left corner, I can only see the GPU, but the three lines above containing input, output and framesize are always empty.
Old 8th October 2019, 09:48   #6737  |  Link
v0lt
You need to open the properties of the active video decoder (see Play-> Filters->MPC Video Decoder).
Translation updated in r4803. Thank.
Old 8th October 2019, 17:08   #6738  |  Link
wushantao
https://send.firefox.com/download/83...Cq3txzb6io7wDA
update simplified chinese translation files:)
Old 9th October 2019, 17:59   #6739  |  Link
beter
Update for translation of Traditional Chinese and Dutch.
https://www.sendspace.com/file/lqjwwh
And clarification needed. What does the "Larger only" exactly mean? My interpretation was "Only to shrink the videowindow to that percentage of screen when the video resolution is 'larger' than that of the screen". However, Wushantao's interpretation was "Only to make video window 'Larger' (until that percentage), but not to shrink any video window". It leads to two completely contradictory translations in the two versions.
beter is offline   Reply With Quote
Old 9th October 2019, 19:00   #6740  |  Link
v0lt
wushantao
Thank. Updates in r4805.
beter
Thank. Updates in r4807.
"Larger only" setting prohibits increasing the frame size when the window is fit to the screen. The window will be fitted (reduced size), if only the frame size is large.
