15th April 2007, 19:54 | #121 | Link |
Nice .
Please check if the Bus Key is filled (don't post it) and whether the Volume ID MACs are exactly the same (don't post it). Also fot Bluray: is the sha-1 hash the correct one? (according to the KenD00's new specs that is) |
15th April 2007, 20:35 | #122 | Link | |
For bluray . SHA-1 is the correct one ! and Buskey is Filled :-) |
16th April 2007, 07:31 | #123 | Link | |
message as follow: C:\aacskeys>aacskeys.exe i v Error opening Media Key File i:\AACS\MKBROM.AACS Blu-ray BDAV file structure as follow, \AACS\MKB_RW.inf \AACS\AACS_av\CPSUnit00001.cci \AACS\AACS_av\Unit_Key_RW.inf Thanks a lot!!!!!! |
16th April 2007, 18:23 | #124 | Link | |
I really need help on this. arnezami Last edited by arnezami; 16th April 2007 at 18:26. |
17th April 2007, 02:58 | #125 | Link | |
Just let me know how to do. |
17th April 2007, 04:34 | #126 | Link | ||
#define AACS_CC_PUB_X "686795158131444840350934441718292981749606298444" #define AACS_CC_PUB_Y "667926496774724305600543583224894590551199207" #define AACS_LA_PUB_X "569519044145899916876682500420440111695939635058" #define AACS_LA_PUB_Y "111297986001312168148180416490690086062371334695" Quote:
17th April 2007, 06:20 | #127 | Link | ||
But only after I finished the implementation of automatic Device/Processing Key detection: this is gonna be a very cool and powerful feature and will be very useful for future attempts by "Key Finders" (aka hackers) to check if they have found a Key among (tons of) possible keys. Regards, arnezami Last edited by arnezami; 17th April 2007 at 07:05. |
20th April 2007, 18:40 | #131 | Link |
You didn't read the thread HyperHacker sent you to. It explains that AnyDVD doesn't need its database if you use it with an original disc, and you won't have ever seen their database. AnyDVD uses its own database as a backup, which lets it decrypt files mounted as an ISO or just copied off the original disc.
21st April 2007, 12:51 | #132 | Link |
I'm really busy implementing stuff into aacskeys.
Here is something to test: http://www.sendspace.com/file/f0lh56 Its now supports automatic Device/Processing Key detection . But it needs to be tested. If anyone has Device Keys (from our "old" Software Players which are going to be revoked anyway so you can release them if you like) then please test them and see if they are recognized as such. In the file "ProcessingDeviceKeysSimple.txt" you can simply throw your Device/Processing Keys. If they work on a disc then aacskeys should be able to recognize that. Here is what I put in for testing: Code:
DEADBEAFDEADBEAFDEADBEAFDEADBEAF DEEDDEEDDEEDDEEDDEEDDEEDDEEDDEED 12345678123456781234567812345678 87654321876543218765432187654321 AA856A1BA814AB99FFDEBA6AEFBE1C04 DEADBEAFDEADBEAFDEADBEAFDEADBEAF DEEDDEEDDEEDDEEDDEEDDEEDDEEDDEED 12345678123456781234567812345678 87654321876543218765432187654321 09F911029D74E35BD84156C5635688C0 DEADBEAFDEADBEAFDEADBEAFDEADBEAF DEEDDEEDDEEDDEEDDEEDDEEDDEEDDEED 12345678123456781234567812345678 87654321876543218765432187654321 In order for this to work on a new disc you need to find possible Keys (of course getting these is the hard part) and use aacskeys with these Keys on the new disc (or alternatively : copy the AACS directory from your new disc to a root dir of one of your HDDs and let aacskeys operate on that drive letter. Or mount these files/disc as an ISO. This will prevent wear and tear on your disc/drive). More will follow (like input of volume id/HPK) but this I had to get out so somebody can (hopefully) confirm its working. arnezami PS. As for speed: you will notice it takes quite a lot of time to test many keys. The current version isn't build for speed. There are several ways to speed it up (eg precomputation due to similarity in shapes of subsets) and shortcuts (like only trying a few C-values and ignoring others). In other words: you can't scan (full) memdumps with this program. Last edited by arnezami; 21st April 2007 at 16:09. |
23rd April 2007, 05:40 | #133 | Link |
No worky
Older version of aacskeys happily works with my current test disk (Total Recall): Code:
C:\aacs>.\aacskeys.exe i v Processing key: 09F911029D74E35BD84156C5635688C0 Encrypted C-value: B7422BF12E30C7308B66B877E376058D Corresponding uv: 00000001 Decrypted C-value: 50D497E0D724A42B08E010619D3B6DD7 Media key: 50D497E0D724A42B08E010619D3B6DD6 Encrypted verification data: 9ED2A5E1116D544F0338E74E8A4F9A0B Decr verif data should be: 0123456789ABCDEF Decrypted verification data: 0123456789ABCDEF07D27BEAF4FBDC72 AGID: 00 Host certificate from: Power DVD 7.1 Host certificate (Hcert): 0200005CFFFF0000000C00006E3DEB679B9A16AD FAA8E30878767BA6EB2A9B415385AD1181B4446C 31E9A5DD2AB808B364FF15885BAC490964318C9B F8029FCF76F688A54FBDA03F6D9332EF04E5A613 12DA85880A4D9CBB79D8602E Host Private Key (Hpriv): 4737676058D7029452514F0AB186DC4CCA8C578F Host Nonce (Hn): 2923BE84E16CD6AE529049F1F1BBE9EBB3A6DB3C Drive certificate (Dcert): ######################################## ######################################## ######################################## ######################################## ######################## Drive Nonce (Dn): ######################################## Drive key point (Dv): ######################################## ######################################## Drive key signature (Dsig): ######################################## ######################################## Host key (Hk): 0000000000000000000000000000000000000000 Host key point (Hv): 8E9B0E3CF41FA7DA3A829F604122EA4ED5261AA4 7570CE0BB9061A66FAF92C4A7D98ACC171CBF19B Host key signature (Hsig): ######################################## ######################################## Bus key (BK): ################################ Volume ID: 4000922B7BCD3536AC5CD7FA41FD0000 Voluem ID MAC: ################################ Volume Unique Key: F51EAABB7CD2E2ED05A6BE00126D4AA6 Title Key File MAC: 232F941592CBE19FF50865356153DEA7 Encrypted Title Key 1: 8D2F4E37CF6525FA88877BFFF77F5F50 Encrypted Title Key 2: 032609ADE9C4FB6B9C8F19E1BF3A8056 Encrypted Title Key 3: 25D499F134D0F546F346814C0E142D6C Encrypted Title Key 4: 8C03F7420B47ECF1C6A2BEE7174E416E [64 encrypted and decrypted title keys snipped] (ProcessingDeviceKeysSimpletxt as shipped) Code:
C:\aacs\aacskeys.new>.\aacskeys.exe i v Could not find a Processing Key or Device Key resulting in the Media Key. Aborting... C:\aacs\aacskeys.new> 09F911029D74E35BD84156C5635688C0 (Processing key that works with older version of aacskeys and this disk), I still get the same error message. Hope this helps. System in question is Windows XP, Pan European release (?), English locale. Xbox 360 HD-DVD drive connected over USB. Are there any other tests I can run? |
23rd April 2007, 06:10 | #134 | Link | |
Do others have the same problem here? Please test it. (btw it works fine on my system and I don't see (yet) why it would not work with yours) arnezami |
23rd April 2007, 06:10 | #135 | Link |
BTW, I have a couple of suggestions for aacskeys....
There are many revisions of it out there by now, so maybe implementing some sort of versioning as maybe the first line of the output would make sense. In the above post I refer to "older" aacskeys, but I have no idea which particular build it is. This would make your life easier with bug reports, etc. If you add a way of adding comments to ProcessingDeviceKeysSimple.txt (ie lines that will not be processed by the aacskeys, say lines that start with # or ; ), it would probably be useful for key management, etc. |
23rd April 2007, 06:16 | #136 | Link | |
http://www.sendspace.com/file/vdnfzt Please read my previous post. You may have missed it. arnezami PS. Regarding the extension of the text file: this is the "Simple" version and is for people thinking they might have found a new key. So they can just throw in possible keys... Last edited by arnezami; 23rd April 2007 at 06:18. |
23rd April 2007, 06:46 | #137 | Link |
I have made some changes so it gives more info. Hopefully this will clarify where the problem lies:
aacskeys v0.2.2 Please to others too: try this on different discs. Thanks . Last edited by arnezami; 23rd April 2007 at 06:55. |
23rd April 2007, 08:54 | #138 | Link | |
Does this version support BDAV disc? Error message as follow, Code:
C:\aacskeys_v0.2.2>aacskeys.exe m v aacskeys v0.2.2 Error opening Media Key File m:\AACS\MKBROM.AACS |
23rd April 2007, 18:41 | #139 | Link |
Ok. I now got the automatic Device Key detection working thanks to someone "lending me a hand" . Thanks. You know who you are .
I'm still going to (more methodically) check whether its really accurate but it looks very good now. Screenshot of usage for new aacskeys version: Anyway. Version 0.2.4 now supports volume id input too. This is going to be very handy when (well technically: if) we find the new Processing Key(s) without having a working HPK yet. aacskeys v0.2.4 For the other problem (that awhitehead posted): anyone please test this new version (just run it) and post your results Regards, arnezami @PepsiLee2001: no this version doesn't support BDAV yet. Please read my last posts about this. [edit] Small update: turned on something that wasn't supposed to stay turned off. PS. If/when the new Processing/Device Key is found and released you can use fetchvid to retrieve the Volume ID of a new disc and then use it as input for aacskeys. Last edited by arnezami; 23rd April 2007 at 21:53. |
24th April 2007, 04:24 | #140 | Link | |
Tested with US release of "Syriana" |
