Old 6th November 2019, 19:46   #21  |  Link
filler56789
SuperVirus
filler56789's Avatar
Originally Posted by LuigiVann View Post
hey Valgor, can we get an update about the latest libtheora from you and when the next one will be?
Two things:
1) about valgor:
Last Activity: 14th July 2012 17:13
2) Nobody uses Theora anymore.
But if you want to use it anyway, I recommend that you encode with ffmpeg2theora and then remux the video into an .AVI file with ffmpeg. Theora doesn't have B-frames so the remux will work well even with the VfW interface.
filler56789 is offline   Reply With Quote
Old 7th November 2019, 05:28   #22  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
I really wonder if there's a single use case for Theora today, even for legacy applications.
Did it ever have hardware support? Even VP8 got some hardware support, so that would be a much better choice if you need a royalty free codec on some old hardware.
Old 7th November 2019, 13:55   #23  |  Link
Liisachan
李姗倩 Lǐ Shān Qin
Liisachan's Avatar
Just fyi: when I tested theora long time ago, I used Theora Win32 Binary like this:
encoder_example -o output.ogg -v 3 -a 5 input.wav input.yuv
which generated (theora+vorbis).ogg iirc. It was (perhaps still is) also possible for VLC to write theora+vorbis.ogg and even theora+flac.ogg. And back then, there was Helix Player too, supporting Theora out-of-box.
But that's history, we better move on... although, it would have been fantastic if Theora had become a patent-free codec with x264-like quality.
Liisachan is offline   Reply With Quote
Old 9th December 2019, 23:27   #24  |  Link
benwaggoner
The big challenge is always that lots of great techniques are patented. AV1 and MPEG-5 EVC are two ways to approach that, but in the end VVC with its patented techniques remains the most technically promising forthcoming codec.
Sent from my SM-T837V using Tapatalk
Ben Waggoner
My Compression Book
