Old 23rd July 2018, 14:21   #61  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Originally Posted by RanmaCanada View Post
Is there any way we can get the benchmark updated, as several people with Epyc machines have tried to run it, and it will not run.
I doubt that this benchmark is designed to saturate all logical processors on EPYC 1(64threads)/2(96threads) anyway.
2160p is only enough up to 32 threads. You will have to run 2 instances to get 100% usage in this case on EPYC 1 and 3 for EPYC 2.
Old 24th July 2018, 23:00   #62  |  Link
RanmaCanada
True, but the problem is that people are reporting that it won't run on Windows Server SR2. As I don't have an EPYC myself, I sadly can't run the benchmark, and the people are only posting in the threads on reddit, and not creating accounts and posting here to report the issues. People have asked them to come here, but to no avail, so it's like a long game of telephone. Hopefully when TR2 is released we will get some good benchmarks
Old 25th July 2018, 12:59   #63  |  Link
Atak_Snajpera
tell them to run x265 FHD Benchmark
Ps. Overclocked 2990x@4GHz should give you ~90fps in 1080p with default settings.
Old 23rd August 2018, 01:12   #64  |  Link
RanmaCanada
And even you are having troubles with your benchmark haha :P I guess we need some new software to abuse these multi-core beasts?
Old 23rd August 2018, 11:30   #65  |  Link
Atak_Snajpera
Because numa nodes were not set for each encoder. Who would have thought that lack of direct access to memory by DIE1 and DIE3 will be so devastating for x265 video encoding. Relax. New version will assign each encoder to own NUMA node. This should reduce data traffic on infinity nodes and hence improve speed.
Old 13th December 2019, 00:46   #66  |  Link
Forteen88
Herr
I got "av_interleaved_write_frame(): Invalid argument" too, using "Benchmark_auto.bat" file. But the results.log file showed,
|     CPU             |   x264  |   x265  |   LAVC  |   auto  |   MMX2  |    SSE  |   SSE2  |   SSE3  |   SSE4  |    AVX  |   AVX2  |    All  |
|  Ryzen 5 3600       |  20.82  |   3.86  |   118   |   3.13  |   0.97  |   1.00  |   1.55  |   1.69  |   2.51  |    2.55 |   3.16  |    N/A  |
AMD Ryzen 3600 with DDR4-3200@3466.
Forteen88 is offline   Reply With Quote
