Old 2nd September 2014, 10:51   #1  |  Link
Blight
Software Developer
Blight's Avatar
Announcing Zoom Player v9.3 final
Version 9.3 brings many new user interface tweaks to the fullscreen navigation interfaces, making it more suitable for use with a mouse or touch device (tablets).
Download:
http://www.inmatrix.com/files/zoomplayer_download.shtml
What's new since v9.2:
  * Support for registering the GXF, MXF media exchange formats
    file extensions.
  * New Smart Play profiles for GFX, MXF, Motion JPEG2000 and DVCPro
    formats.
  * Clicking on the fullscreen navigation interfaces title area now
    navigates to the previous interface (like using the navigate "left"
    function).
  * The current navigation icon is now drawn next to the fullscreen
    navigation interface's title.
  * Clicking the "Main" fullscreen navigation interface now toggles
    back and forth between the function page and the navigation interface
    selection index.
  * The playlist, file browsing and media library fullscreen navigation
    interfaces display item and selected item counts on the right-side
    of the path section.
  * New "Main" entry on the main fullscreen navigation interface functions
    page that returns to the main navigation interface selection index.
  * The fullscreen virtual-keyboard navigation interface's text box can
    now be clicked to move the text-caret to the clicked position in the
    text.
  * The fullscreen navigation skinning code has been enhanced to control
    whether navigation arrows are displayed on each navigator interface.
  * The fullscreen navigation skinning code has been enhanced to allow
    specifying a specific file for each navigation icon.  Navigation icon
    sizes are no longer fixed at 160x160 pixels (source resolution).
  * New setting (Adv. Options / Interface / Fullscreen Navigation / Settings)
    to pre-load navigation graphics, improving load time at the cost of
    additional memory usage.
    Customization) to prevent the navigation icon from being displayed
    next to the title text.
    Customization) to prevent the navigation title from being displayed.
    File Tracker) that tracks and displays download progress in the media
    library and file browsing fullscreen navigation interfaces when using
    the qBittorrent BitTorrent download client:
    http://www.qbittorrent.org/
  * New skin-script code specifying the fullscreen navigation interfaces'
    icon position and scale next to the title text.
  + Several fullscreen navigation customization features have been moved
    from other pages to the new customization page on the advanced options
    dialog.
  + Several fullscreen navigation widget have been polished to better
    fit the navigation style.
  + Multiple fullscreen navigation skin files can now reside in the same
    folder, allowing graphical element re-use for a smaller distribution.
  + All settings on the fullscreen navigation customization options dialog
    page are now updated in real time, making it much simpler to customize
    the fullscreen navigation interfaces.
  + Using the fullscreen navigation's navigation skin selection interface
    now updates the navigation skin as soon as you highlight a skin entry.
  + Detaching the control bar now overrides all other control bar
    positional settings.
  + Adding files/folders to the playlist using the media library or file
    browsing fullscreen navigation interfaces now reports the number of files
    actually added to the playlist.
  + The Advanced playlist control now works 200% faster by pre-allocating
    some RAM (10mb ram for a playlist with 40,000 entries).
  - Image rotation was completely broken (did nothing) in v9.2.
  - Fixed a vulnerability when loading specially crafted ".BMP" files.
  - The information dialog ("I" keyboard macro) will no longer appear
    partially off-screen when the playback window is positioned at a screen
    corner.
  - When applying file extension association, the confirmation dialog
    appeared in the wrong screen position.
  - Adding a streaming URL using the playlist editor would clear the entire
    playlist instead of appending the URL to the end of the playlist.
  - Hardened the language-pack parsing code to better handle several
    types of translation errors.
  - The "DefaultSettings.exe" application that resets Zoom Player's settings
    to their default values did not work with the Steam Edition of Zoom Player.
  - Fixed several issues related to conflicts between assigned double-click
    and single-click mouse functions, like the inability to exit fullscreen
    mode when double-click is set to switch to "Fullscreen on/off" and single
    click set to "Move Video / Window".
  - The "ESC" key no longer closes the keyboard editor's key mapping dialog,
    allowing the "ESC" key to be mapped.
  - Loading playlists with embedded media-duration information skips
    the media-duration scanner's background operation from trying to get
    the media's duration from the media file itself.
  - The advanced playlist control dialog would take twice as long to open
    if the 'Search' was set to "Starting with...".  Only noticable on massive
    playlists.
Yaron Gur
Zoom Player . Lead Developer
Blight is offline   Reply With Quote
htpc, media player, tablet, zoom player
