Old 29th January 2012, 17:11   #21  |  Link
Golova
Originally Posted by Blight View Post
Golova:
Pressing F4 should reset the skin. If you can reliably reproduce this skin issue, I need to know, because here it doesn't happen.
I've upgraded it from v7 to v8, than this issue appeared.
I found it caused by my *.key file.
You can apply my *.key file to repeat this skin issue.
Golova is offline   Reply With Quote
Old 30th January 2012, 14:39   #22  |  Link
Blight
Software Developer
Blight's Avatar
Golova:
Ah, that's a known issue, if you've previously used a custom keyboard mapping file, you need to recreate it from the default keyboard mapping (which changed in v8.1 to accommodate the new mode behavior).
Yaron Gur
Zoom Player . Lead Developer
Blight is offline   Reply With Quote
Old 30th January 2012, 17:42   #23  |  Link
Golova
Thank you!
I'v replaced/added to my file:
// Skin Mode Functions (F4-F9)
exAddKey(None,115,exSkinMode,1)
exAddKey(None,116,exSkinMode,2)
exAddKey(None,117,exSkinMode,3)
exAddKey(None,118,exSkinMode,4)
exAddKey(None,119,exSkinMode,5)
exAddKey(None,120,exSkinMode,6)
from default key file, now all fine.
Old 31st January 2012, 12:34   #24  |  Link
Blight
Software Developer
Blight's Avatar
Cool
Yaron Gur
Old 1st February 2012, 10:08   #25  |  Link
italospain
italospain:
This is very weird, I wonder if it's related to a specific ZP setting you're using.
Does it happen if you run defaultsettings.exe and then only change the fullscreen setting before trying to switch to fullscreen?
If you can narrow down the reason, I might be able to come up with a fix.
Yes it it happen after defaultsettings.exe
i dont know what to do.
I cant understand why not more people are complaining my setup has nothing special.
Nevertheless the best player in the world
italospain is offline   Reply With Quote
Old 7th February 2012, 18:35   #26  |  Link
Blight
Software Developer
Blight's Avatar
italospain:
watch this video, make sure you configure your multi-monitor setup the right way:
http://www.youtube.com/watch?v=nk9mYc1xKZo
And part 2:
http://www.youtube.com/watch?v=NH6ecCEMw4k
Yaron Gur
Old 7th February 2012, 20:51   #27  |  Link
italospain
italospain:
And part 2:
yeah the right way . doesnt help
btw i think it is impossible to make it wrong
Old 8th February 2012, 18:07   #28  |  Link
Blight
Software Developer
Blight's Avatar
italospain:
It's really strange that it's only affecting you and on two separate systems.
I personally use a multi-monitor environment every day...
Perhaps some third party desktop management software you have installed on both systems?
If you run ZP with the /f:1 or /f:2 command line, it doesn't open on the desired screen?
Yaron Gur
Old 9th February 2012, 11:18   #29  |  Link
italospain
italospain:
it only works if Zoom Player is already on the disired screen.
I have no third party management software installed.
Zoom Player 6 and 7 working fine.
Old 9th February 2012, 13:41   #30  |  Link
Blight
Software Developer
Blight's Avatar
Can you post a screenshot of the "Adv. options / System" and "Adv. Options / Interface / Position & Size" pages?
Yaron Gur
Old 10th February 2012, 11:15   #31  |  Link
italospain
here you go
https://rapidshare.com/files/4283867594/position.png
https://rapidshare.com/files/2454629754/System.png
Old 12th February 2012, 11:00   #32  |  Link
italospain
update
third system i installed Zoom Player 8 and fullscreen on monitor 2 doesnt work.
All 3 systems were connected over s-video as extended desktop.
if no one else is complaining it must be related to the s-video connection.
Blight can you test a extended desktop with s-video to reproduce the error ?
Old 13th February 2012, 23:33   #33  |  Link
Blight
Software Developer
Blight's Avatar
italospain:
I haven't tried an s-video configuration for years, my development machines don't support s-video anymore (only hdmi/dvi/vga).
The thing is, the code Zoom Player uses to position itself on secondary monitors is dependent on how windows identifies the monitors and not the connection type.
Can you post a screenshot of the windows monitor configuration dialog (in win7 it's right-click desktop, and select "screen resolution").
Please post your reply in the v8.1.1 release thread.
Yaron Gur
Old 22nd February 2012, 06:28   #34  |  Link
25minutes
Blight, I encounter the same issue that italospain is facing.
I've tested Zoom Player latest version 8.1.1. My main display is 1920x1080 LCD, secondary display is 1280x720 TV (Component Video Connection) in extended mode.
Starting ZP with /F:1 works fine. However, /F:2 doesn't show anything on TV, though I can see ZP running on task bar. If I click on ZP from task bar multiple times, finally it can show on TV. The same configuration works fine on Zoom Player 7.
Let me know what I can provide to tshoot the issue.
25minutes is offline   Reply With Quote
dvd, htpc, media center, media player, zoom player
