Old 17th April 2011, 20:26   #1  |  Link
Blight
Software Developer
Blight's Avatar
Announcing Zoom Player v8 RC2
Hi Everyone
We've got RC2 ready for your testing!
We also have a nicer version of the Drapes HD media center navigation interface on our facebook page.
And once v8 goes final, we'll also post HD versions of the default background images in 16x9, 16x10 and 4x3 aspect ratios.
Download Zoom Player v8 Release Candidate 2
Here's the change list from v8 RC1:
* The station interfaces will now give you access to more than 13,000
streaming radio stations.
* The LAV Splitter is now supported for AVI, MOV, MP4, FLV, OGG, OGM and
MPEG2 Transport Streams. Please take note that if the LAV Splitter is
installed, it disables microsoft AVI splitter from working properly.
Tis means that you must set Smart Play's "AVI" Source filter to
LAV Splitter or use the MPC (Gabest) AVI Splitter as the "AVI" Splitter
filter.
* You can now use the Ctrl+"A" macro to cycle through the available audio
channels when using the LAV Splitter.
* New "VP8" profile added to the Smart Play options dialog.
VP8 is used by the WebM format and can be decoded using FFDShow and
the MPC Video Decoder (FFDShow may need configuration to enable
VP8 support).
* New "TWOS Audio" profile added to the Smart Play options dialog.
Requires LAV Audio Decoder.
* You can now associate the ".WebM" extension.
* New Setting (Adv. Options / Playback / Video) which enables a fix when
moving the player window from video area causing the window to jump to
an unexpected position.
Affects only Windows VISTA (or newer) when the video renedrer is set to
'Haali Video Renderer', 'MadVR', 'VMR7' or 'VMR9'.
* The Station List Media Center interface now has a
"Go To top of list" function.
+ Added a new H.264 sub-type for CoreAVC 2.5.1 compatibility.
+ Selecting MadVR as the video renderer automatically enables the
"Overlay covers entire video area" setting.
+ The Re-Synch Audio Ahead/Back now works in 25ms increments rather than
the 10ms used previously.
+ The default volume control change value is now 5%, up from the previous 3%.
+ The default Zoom In/Out value is now 10%, up from the previous 1%.
+ The default 'Keyboard Video Window Move' value has changed to 5%,
up from the previous 4 pixels.
+ The "fnVidLeft", "fnVidRight", "fnVidUp", "fnVidDown" functions now
use the 'Keyboard Video Window Move' value while in fullscreen.
Previously, these functions only moved by 1 pixel.
+ Updated Media Center navigation icons.
- Dragging the player window by clicking "Ctrl + Left mouse button" (or
other configured setting) within the video area was broken in Windows
Vista and Windows 7 when certain video renderer were used (VMR7/VMR9/
Haali/MadVR). Now there's a workaround in place that ensures the window
is dragged to the correct location (with minor flickering at times).
- Several settings were not remembered correctly with Zoom Player Home FREE.
- The Install Center did not load on Windows XP due to a corrupt
manifest file.
- The 'forcibly hide the windows taskbar in fullscreen mode' setting will
now hide the Start Orb (button) in Windows VISTA and Windows 7.
- Deleting a media library catgeory, would erase other categories if their
name was very similar (example "movies" and "movies2").
- The "Custom Mouse Wheel Down" function was not being saved.
- Opening a display pattern (Shift+"P"), no longer stops the playing
video before closing it. This ensures the previous play position is
saved correctly.
- Other bugs introduced between v7 final and v8 RC1
Yaron Gur
Zoom Player . Lead Developer
Blight is offline   Reply With Quote
blu-ray, dvd, media player, zoom player
