Old 31st October 2012, 19:58   #15181  |  Link
madshi
Microsoft told me which interfaces I have to support, and I already did support them, but I found a bug in one of them. Anyway, can you guys please check whether AnyDVD is still needed? And if it is needed, is it also needed for EVR? I need to know this, because that would be one more thing I could ask the Microsoft guys, now that I have their attention. If I tell them now all is fixed, I don't want to get back at them later and ask another question.
Old 31st October 2012, 20:04   #15182  |  Link
cyberbeing
Broadband Junkie
Originally Posted by JarrettH View Post
I get scrambling and other nonsense from the protections used (I think?).
Have you already applied the KB2709981 hotfix which went live on Windows Update a couple months ago?
Old 31st October 2012, 20:06   #15183  |  Link
vlatko27
madshi, I just wanna say you freaking rock, man. thanks for all your effort and involvement.
vlatko27 is offline   Reply With Quote
Old 31st October 2012, 20:09   #15184  |  Link
detmek
I don't have encrypted DVDs but I tried 3 DVD discs without protection and it works! MPC-HC Lite + LAV Filters 0.52.0 + Microsoft DVD Navigator on Windows 7 Home Premium SP1.
Edit:
I also got huge log file on my desktop, 247MB.
detmek is online now   Reply With Quote
Old 31st October 2012, 20:09   #15185  |  Link
SamuriHL
SamuriHL's Avatar
Now to get the J River guys to support this.
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
Old 31st October 2012, 20:11   #15186  |  Link
SamuriHL
SamuriHL's Avatar
(I'll try an encrypted DVD in a few....I need to build MPC and LAV first)
Old 31st October 2012, 20:15   #15187  |  Link
Matching_Mole
Ok guys. The detailed descriptions about that DVD playback sometimes works with some media players and filter combinations made me think. And I got a reply from Microsoft, too. So here's a new test build which *might* help with DVD playback. Please don't get up your hopes too high. It seems to help on a quick check on my win7 PC, but I haven't done any real tests yet.
http://madshi.net/madVRdvd.rar
I never succeed to have DVD working with Madvr until now, even with the last version of LAV. But your test version has solved the issue on my windows seven 64 version (with regular MPC-HC), which is great!!
Matching_Mole is offline   Reply With Quote
Old 31st October 2012, 20:23   #15188  |  Link
Prinz
I tested the new dvd madvr version.
With anydvd active it is working now, but if I deactivate anydvd I get a Error in MPC-HC:
DVD: Fehler mit Kopierschutz.
If I change to EVR or Sync Renderer It it's working with anydvd deactivated.
Prinz is offline   Reply With Quote
Old 31st October 2012, 20:27   #15189  |  Link
noee
Just tried with an encrypted DVD in the drive. With DVDPasskey enabled, it works, MPC-BE/LAV/madVR. Without DVDPasskey, it does not work.
Edit: Sorry, yes, EVR works either way (with or without DVDPasskey with the encrypted DVD).
noee is offline   Reply With Quote
Old 31st October 2012, 20:28   #15190  |  Link
Toku
Same problem. With Anydvd active the dvd loads, (But Media player classic gives me a strange error box "The parameter is incorrect)
but without anydvd active (Loading an encrypted dvd) I get a
"Dvd: Copy-protect fail" error
Toku is offline   Reply With Quote
Old 31st October 2012, 20:30   #15191  |  Link
madshi
Can I have a log from such a "copy-potect fail" problem, please?
Old 31st October 2012, 20:34   #15192  |  Link
Prinz
Log:
https://www.dropbox.com/s/5ejksm798j9zrju/madVR%20-%20log.zip
Old 31st October 2012, 20:36   #15193  |  Link
SamuriHL
SamuriHL's Avatar
Sweet. Looks like you guys are on top of it. I'm having a problem building LAV right now so I'm glad others can test it. This is exciting though. madVR for DVD. Holy hell yea.
Old 31st October 2012, 20:39   #15194  |  Link
dansrfe
Brilliant, madVR DVD test build works!
I'm guessing that you'll turn off the automatic log file creation when the next build is finalized?
Thanks madshi, you rock!
Old 31st October 2012, 20:43   #15195  |  Link
madshi
Well, I can't see anything wrong in that log. Not sure if there's anything I can do make playback work without AnyDVD. Anyway, not such a big problem, I guess...
Old 31st October 2012, 20:46   #15196  |  Link
SamuriHL
SamuriHL's Avatar
Not for me. Who the hell runs an HTPC without AnyDVD anyway? :P
Old 31st October 2012, 20:46   #15197  |  Link
JarrettH
Oooook...
Restored MS DVD Navigator, AnyDVD off (DVD: Copy-Protect Fail...this happened with the next three DVDs I tried)
http://depositfiles.com/files/cb2mxxejt
Restored MS DVD Navigator, AnyDVD on (works)
http://depositfiles.com/files/rkqzgotzq
Menus are kind of hit and miss though.
Old 31st October 2012, 21:13   #15198  |  Link
madshi
madVR v0.84.4 released
http://madshi.net/madVR.zip
* fixed: DVD playback often resulted in Macrovision errors
* improved Jinc AR algorithm for clean computer type images/videos
* added support for new subtitle interface (e.g. for future xy-vsfilter build)
Please note that madVR does not (yet?) support an extra input pin for subtitles and DVD menus. So if you want to have DVD menus fully working, you have to use a decoder which blends them on top of the video frames (e.g. LAV Video Decoder).
Old 31st October 2012, 21:14   #15199  |  Link
madshi
QUESTION: Which video decoder is used when playing DVDs with EVR *without* AnyDVD?
Microsoft is telling me that their best guess why madVR can't play encrypted DVDs without AnyDVD might be that the video decoder doesn't support decryption.
Old 31st October 2012, 21:16   #15200  |  Link
nevcairiel
I should make LAV Video use the subtitle interface for those (it already does internally), except it just doesn't work so well for menus and interactive feedback on a still DVD menu image...
