Old 4th December 2019, 00:55   #57981  |  Link
WuNgUn
Anyone know of a way to pass thru web video thru MadVR? Obviously some 3rd party software player...?
WuNgUn is offline   Reply With Quote
Old 4th December 2019, 01:27   #57982  |  Link
Crimson Wolf
https://streamlink.github.io/
https://ytdl-org.github.io/youtube-dl/index.html works with latest MPC-HC using advanced section settings for YDLMaxHeight if you put youtube-dl.exe in the $PATH.
Above two works for most streamed video sites.
Crimson Wolf is offline   Reply With Quote
Old 4th December 2019, 01:32   #57983  |  Link
WuNgUn
I was thinking more of a imbedded video in HTML...not a video playing service per-se.
I'll check it out...
Old 4th December 2019, 01:37   #57984  |  Link
mambans
Hey, Since I recently reformatted my PC my potplayer + madvr have started to stutter (a lot of "presentation glitches") in FSE mode. But sometimes when I disable FSE and smooth motion there are no more stutters and very rarely even FSE works without any stutters. Anyone have any idéas why FSE could stutter?
OSD:
FSE osd
Windowed osd (glitches & dropped frames are from the FSE mode)
Some settings:
Window mode
Exclusive mode
General
Smooth motion
Dithering
mambans is offline   Reply With Quote
Old 4th December 2019, 01:52   #57985  |  Link
WuNgUn
Looks like streamlink wants a plugin specifically for the website... Which there isn't one. (just a generic HTML page)
Old 4th December 2019, 07:51   #57986  |  Link
Asmodian
Windows 10 seems to have broken FSE in many situations. Even when it works fine it is only being emulated. I recommend against using it now, I think it was 1809 or 1903 that really made FSE cause more trouble then it prevented.
madVR options explained
Old 4th December 2019, 11:28   #57987  |  Link
Siso
Siso's Avatar
a 1050 ti can nearly for sure do NGU low so you have to be a bit more precise.
What do you mean by more precise? With my current monitor 2560x1080p I can do NGU High and downscale with SSIM 1D 100% AR LL with rendering times around 22 ms, with no dropped frames or delayed frames. So I was wondering if I need a new card. The difference between 2560x1080p and 3440x1440p is big.
Old 4th December 2019, 12:25   #57988  |  Link
ryrynz
ryrynz's Avatar
Just spend as much as you can afford, a 1070 or 1080 are good value for this.
Old 4th December 2019, 12:47   #57989  |  Link
Siso
Siso's Avatar
I may buy 1070. I think it will do a good work.
Old 4th December 2019, 12:51   #57990  |  Link
el Filou
el Filou's Avatar
What's the point of doubling 1080 content on a 1080 screen? Wouldn't sharpen/enhance detail do the job for much lower GPU load? Or are you speaking of SD material?
I don't double 1080 content on my 1440 desktop screen even though I'm sitting so close to it, Jinc is just fine. Doubling is worth it for "800p" 2.39:1 content though.
HTPC: Windows 10 1909, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 4th December 2019, 13:25   #57991  |  Link
then the 1050 should be able to do the same to upscale to a resolution of 3440x1440p that pretty much the same work load because in both cases you are scale up to 3840x2180 and downscale this to the target resolution as long as you are not using error diffusion or other filter the work is very similar.
so are you sure you are already using NGU high?
Old 4th December 2019, 13:45   #57992  |  Link
Klaus1189
I tested FSE with my RX480 on 1903 which was terrible after a new clean install of 1903 after using 1809. But I must admit I only tested it several month ago with the drivers available back then.
I tested it some days ago again on 1909 with my newer RX 5700 XT and latest drivers and it works just as fine as windowed.
Old 4th December 2019, 13:56   #57993  |  Link
QBhd
QB the Slayer
QBhd's Avatar
FSE does not work as well as Windowed on a 5700 XT. I'm betting if you didn't noticed the difference you are not pushing the 5700 XT very hard. When I tried it the other day I was surprised it worked, but then I looked at the OSD and could clearly see the difference (even though both worked).
QB
QBhd is offline   Reply With Quote
Old 4th December 2019, 14:11   #57994  |  Link
rendertimes on a RX 5700 are pretty meaningless the clocks are changed very aggressively i even get lower rendertimes in FSE then windowed.
there is even still a way to get the old FSE but not this topic again.
Old 4th December 2019, 15:19   #57995  |  Link
Klaus1189
You're right, I don't need highest settings, but these are at least sufficient for me So when higher settings are being used which use lots of GPU calculation then the difference are higher rendering times when using exclusive mode on newer Win10 because it's not a "real" exclusive one anymore?
Old 4th December 2019, 15:28   #57996  |  Link
mambans
Thanks for the help. I'll use windowed mode and hope for some update for win 10.
(Weird it worked the day before but might be an update or something I installed on the new install)
Old 4th December 2019, 15:44   #57997  |  Link
Siso
Siso's Avatar
At least it is what the OSD says. I use ordered dithering.
Old 4th December 2019, 15:46   #57998  |  Link
Siso
Siso's Avatar
My monitor has 2.37:1 AR and I mostly watch movies in that AR, 1920x1080p movies don't need any upscaling or doubling, the other movies 816p, 800p they do need doubling.
Old 4th December 2019, 17:40   #57999  |  Link
mclingo
oddly i find the opposite with FSE, when deployed i have no issues, without it I get small glitches here and there and black screens now and again, havent tried it off again since I moved to RX 5700, i'm still on 1809
OLED 4k HDR EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 444 RGB -MD RX 5700 8GB 20.1.3 KODI DS - MAD/LAV 92.17+ 113 beta - 0.74.1 - 3D MVC / FSE:off / MADVR 10bit
Old 4th December 2019, 22:09   #58000  |  Link
ryrynz
ryrynz's Avatar
I did this on my plasma and it was beautiful. High quality upscaling and downscaling NGU sharp and SSIM 2D produce a superior image to say just sharpening alone. I used it for all cinema content with no extra sharpening required. You need a good GPU to pull this off.
