Old 2nd March 2017, 16:58   #42801  |  Link
clsid
AMD HD7770 does not support HEVC.
Old 2nd March 2017, 17:03   #42802  |  Link
cork_OS
cork_OS's Avatar
Originally Posted by XMonarchY View Post
What plans does madshi have for madVR that its development seems to have slowed down? What can we expect in madVR 1.0.0?
Well...
I don't really like to comment on future plans much. But for version 1.0 I do hope to have all important areas covered.
I'm infected with poor sources.
cork_OS is offline   Reply With Quote
Old 2nd March 2017, 17:47   #42803  |  Link
Damien147
Oh,my fault.Probably he can't see the problem then.RX4x0 specific it seems.
Damien147 is offline   Reply With Quote
Old 2nd March 2017, 19:14   #42804  |  Link
leeperry
Kid for Today
Moar better everything eventually.
Old 2nd March 2017, 19:55   #42805  |  Link
Damien147
No matter what the ''3D'' effect of softcubic was the best.Wish he can ''tweak'' something with todays shaders and recreate it.It won't be a bad idea as a whole to choose the best attributes of each shader and combine them.You know,take that from that and take that from that... I don't know if I am saying nonsense.
Old 2nd March 2017, 20:50   #42806  |  Link
Bloodred
Originally Posted by Georgel View Post
Laptop GTX 1080. Same power as desktop, cooling isn't as good so it heats more. Its safe temps are up to 92C where it becomes a real problem.
Yeah, that explains it. On my desktop 1080 at least NGU doesn't seem to heat it up more than a normal load (a game), using the same fan curve of course.
Bloodred is offline   Reply With Quote
Old 2nd March 2017, 22:07   #42807  |  Link
hannes69
What a clever idea!
Seems like you want to mix up apples with pears and bananas. Thatīs fruit salad
Serious: Scaling algorithms use very different technologies, itīs the same like you canīt really mix a petrol and a diesel engine.
If it would be so easy like you think, then it would already exist, because there are many clever people sitting on this planet...
E.g. NGU is very different from simple bilinear and bicubic algorithms, you canīt create a better bicubic upscaler with elements of NGU...
hannes69 is offline   Reply With Quote
Old 3rd March 2017, 02:37   #42808  |  Link
Oguignant
Oguignant's Avatar
3d lut file
Does anyone know how to create a 3d lut file? Any web that explains it?
I use Calman 5 software, but I do not have good results.
"To infinity, and beyond!"
Oguignant is offline   Reply With Quote
Old 3rd March 2017, 02:52   #42809  |  Link
Asmodian
There is a Display Calibration thread here but most of us are using Argyllcms instead of Calman. The new version of DisplayCal has made creating 3DLUTs for madVR very easy.
There is also SpectraCal's madVR 3D LUT Calibration Quick Start Guide.
Please ask calibration setting questions in the other thread so we don't fill up this one with calibration.
madVR options explained
Old 3rd March 2017, 03:01   #42810  |  Link
Oguignant
Oguignant's Avatar
I have problems to calibrate my tv oled, 100% Cyan is left with a DeltaE 2000 of 17. I do not understand why, all other values ​​are ok
Old 3rd March 2017, 04:58   #42811  |  Link
Asmodian
100% colors are often hard to get right, maybe your display simply cannot display the correct 100% cyan, but this can get very complicated and shouldn't be discussed in this thread.
Old 3rd March 2017, 11:24   #42812  |  Link
Damien147
@hannes69
Yes,something like Madshis monster!
I have no idea how things work.I'm just enjoying the result.I used to be a ''vlc guy'' if you get me but madvr made me ''curious''.Ok,I said nonsense it seems.
Old 3rd March 2017, 16:08   #42813  |  Link
IggySLO
Is there a way to make the seek bar larger in exclusive mode?
It looks like it has a fixed size and it doesn't scale up on larger screens, so this makes it very small on a 4K tv. This isn't really a big problem, just a bit of a nuisance on the rare occasion when I'm trying to check the time.
This is my 1st post here and I hope this is the right place to ask . madVR is the best!
IggySLO is offline   Reply With Quote
Old 3rd March 2017, 16:54   #42814  |  Link
Damien147
Right click in desktop--->display settings--->change the size of text,apps,and other items
Set it to 300% for example and check if it fixes things.
Old 3rd March 2017, 18:00   #42815  |  Link
IggySLO
Even if this would make a difference for the seekbar in madVR, I don't think it's the most practical solution.
My PC doubles as a htpc (connected to avr via hdmi) and I don't need everything on my system to be bigger just for this one madVR setting .
Old 3rd March 2017, 18:11   #42816  |  Link
Damien147
300% serves me well for the desktop/browser too.I don't know what else you can do.
Old 3rd March 2017, 23:02   #42817  |  Link
jkauff
What player are you using? If you forego Full Screen Exclusive mode and instead use windowed mode and just maximize your player, you can take advantage of seek bar customizations within the player (assuming your player has them).
Old 3rd March 2017, 23:25   #42818  |  Link
70MM
X Cinema Projectionist NZ
Can someone please explain me something I still dont understand even though I have read the descriptions many many times.....
Im upscaling to 4K and only use Window Mode, I have never understood what Exclusive Mode actually gives me that Window Mode doesn't, can someone explain please?
I know many here only use only Window Mode like myself, but then many others use only Exclusive Mode, why I wonder?
I have tried it many times but always go back to Window Mode as I just dont get it... sorry to be a bit dumb on this one...
70MM is offline   Reply With Quote
Old 4th March 2017, 01:27   #42819  |  Link
pose
Basically it is the most stable mode for madVR.
pose is offline   Reply With Quote
Old 4th March 2017, 01:29   #42820  |  Link
70MM
Stable in what way please?
If one has no dropped frames etc etc would one still want to use it or just stick with Window mode?
