Old 6th May 2016, 23:26   #37781  |  Link
Warner306
Originally Posted by Betroz View Post
Ok, what do you recommend that I change/remove?
At 2x (1080p -> 2160p), I would use SuperRes (3) without anti-bloating because SuperRes really doesn't bloat all that much if the image is not oversharpened. Nor does it need anti-ringing. enhance details (1.0) is another shader that is not redundant. To me, SuperRes at the right strength provides plenty of sharpening on its own.
sharpen edges and LumaSharpen are likely pushing the image towards being oversharp and are redundant. If you like the image really sharp, I might add sharpen edges with anti-bloating but not LumaSharpen on top of that.
Old 7th May 2016, 00:25   #37782  |  Link
ryrynz
ryrynz's Avatar
With my GTX 970 card I have :
- Chroma upscaling : NNEDI3 128
I've said it before and I'll say it again, good lord why?
Did you read anything in the forum before setting that, or even do a visual comparison between 16 or 32 neurons vs 128? Such a waste of resources.
Old 7th May 2016, 00:36   #37783  |  Link
aufkrawall
I find the opposite; the higher the scaling factor, the higher the value of SuperRes is appropriate because of how soft the image becomes.
I don't see where your latter sentence would contradict my statement.
Old 7th May 2016, 03:33   #37784  |  Link
Warner306
You're right; both are true.
Old 7th May 2016, 07:27   #37785  |  Link
Uoppi
So if I understood you and aufkrawall correctly:
The effect of SuperRes may be easier to spot when scaling SD -> 1080p vs. 720p -> 1080p using an identical SuperRes setting (1, 2, 3 etc.)
But because of the softness of SD, a higher SuperRes setting may be required to counter the softness (but with the increased the risk of artefacts). And 720p on the other may become oversharp, so a lower setting might be more appropriate.
Notice the "mays" and "mights". I do realize sharpening is about personal preference. I have sharpness turned to 0 on my Samsung TV; my eyes are sensitive to too much sharpness and start to "hurt".
That's why I tend to use SuperRes at 1, use no other sharpening and direct my available resources towards NNEDI3 processing. Also when downscaling, I use lower values, mostly bicubic 75% and for UHD -> 1080p also 2D SSIM 25%.
Uoppi is offline   Reply With Quote
Old 7th May 2016, 09:28   #37786  |  Link
Betroz
Is this for real?
Betroz's Avatar
If rendering time is below 30ms, why not? All my content is 23 fps, so my GTX 970 can handle it. Image doubling at NNEDI3 kills performance more.
My HTPC : i7 6900K @ 4.2 | nVidia GTX 1080Ti | TV : Samsung 75Q9FN QLED
Betroz is offline   Reply With Quote
Old 7th May 2016, 09:32   #37787  |  Link
but image doubling will have an effect on image quality unlike nnedi3 chroma at higher neurons.
Old 7th May 2016, 09:51   #37788  |  Link
Betroz
Is this for real?
Betroz's Avatar
I know, but super-xbr anti-bloat 25% is good for image doubling too, and the fans on my 970 card doesn't spin up as much as they do with NNEDI3. A good compromise I think. Chroma Upscaling 128 is nice to have with 1080p movies that run 1:1 (no image scaling).
Old 7th May 2016, 09:53   #37789  |  Link
QBhd
QB the Slayer
QBhd's Avatar
Exactly, spare those Chroma Neurons and spend them on NNEDI3 Image Doubling. I only bump my Chroma high when there is nothing left to give on Image. When I set up profiles, I always start with Image Doubling and see how high it can go, then if there is room to spare do I add to Chroma. I am sure Betroz could easily drop to 32 Chroma and get some NNEDI3 goodness out of Image Dougling
If the fans are not spinning up for Chroma 128, I highly doubt that it's even being used... Can you post a Screen shot of the OSD with that particular setup?
QB
QBhd is offline   Reply With Quote
Old 7th May 2016, 10:48   #37790  |  Link
Betroz
Is this for real?
Betroz's Avatar
QB
It is, but Chroma 128 doesn't tax my card as hard as Image doubling, at least not when super-xbr is used for doubling/quad. I do have tried diffferent settings...
Old 7th May 2016, 15:05   #37791  |  Link
Sunset1982
just read the new presentation of the new geforce cards. 1070 as strong as 980ti and 1080 stronger than titan... seems we will get a good jump in performance. Now lets see what amd got and then we'll see how much benefits madvr will get from this more powerfull gpu's when upsaling 1080p to 4k on my machine.
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 7th May 2016, 15:55   #37792  |  Link
wanezhiling
1070 is even stronger than titan x.
Old 7th May 2016, 16:02   #37793  |  Link
Uoppi
I currently use Super XBR 75 for doubling with some profiles where I can't afford NNEDI3. I'm considering whether I should try switching to Super XBR anti-bloat 25 because many seem to like it.
Any pointers as to the strengths/weaknesses of each, i.e. with what material would I best see their benefits or drawbacks? I've understood they should look pretty close.
Old 7th May 2016, 16:34   #37794  |  Link
BluesFanUK
Neither card is a substantial enough upgrade over a 980Ti to get more performance out of MadVR. Nvidia have provided no real proof other than one's apparently the equivalent of a Titan X and the other can out perform 980SLI.
The real performance cards are due out next year. The next Ti should allow some serious high settings for pushing 1080p@60 on to a 4K screen.
Speaking of which, i'm actually glad I downgraded my monitor back to 1080 (the 4K one I had was too hazy for my liking). I can use pretty much any setting I like now with my 980Ti and I can barely notice any difference. 4K is a gimmick. Beneficial to gamers perhaps, but you'd need a good 60-70" screen to appreciate the difference for video watching.
On another note, IMO, NNEDI3 is a complete waste of resources and I think Super-XBR looks miles better. I had all the settings ramped up on one of my profiles for 720p using NNEDI3, GPU was at about 99% with no dropped frames and no real improvement on screen. Changed to Super-XBR, less resource heavy and sharpens my images enough to look 1080. Guess it really is down to personal taste.
BluesFanUK is offline   Reply With Quote
Old 7th May 2016, 16:38   #37795  |  Link
nevcairiel
The current estimates (from their presentation information and the core/clock ratio) go around 15-20% over a TitanX/980Ti at stock, with easy 20% OC headroom, which personally I find substantial. Only benchmarks will reveal the real information either way however, and anything else is just speculation, both positive and negative.
Old 7th May 2016, 17:01   #37796  |  Link
Ver Greeneyes
They said that at the end, but I think that was taking their VR viewport trick into account (since that adds another ~40% performance in VR). Still, the 1070 won't exactly be a pushover either.
Old 7th May 2016, 17:16   #37797  |  Link
Stereodude
But who knows if the new architecture will actually be faster or not for madVR. Nvidia pretty much had AMD's number in the last gen when it came to gaming performance, but AMD's cards offered better madVR performance. A Nvidia card that was effectively the equal in gaming of a given AMD model had considerably higher rendering times with the same madVR options.
Stereodude is offline   Reply With Quote
Old 7th May 2016, 17:33   #37798  |  Link
nevcairiel
The Pascal architecture doubles the parallelism by making SM units smaller and doubling their count (64 vs 128 cores per SM, compared to Maxwell, Kepler had 192 cores per SM for comparison), which should help any tasks that are incredibly parallel, which image scaling should fall under. But in the end we won't know until we know.
Old 7th May 2016, 19:27   #37799  |  Link
har3inger
BluesFanUK, try out bilateral chroma with superchromares 2. I personally prefer it to all other algorithms (including nnedi3), and it costs way less than nnedi3.
har3inger is offline   Reply With Quote
Old 7th May 2016, 20:54   #37800  |  Link
sat4all
fellas, what's your debanding settings for bluray's remux, is it better to keep it off?
sat4all is offline   Reply With Quote
