Old 13th April 2015, 12:41   #28881  |  Link
tobindac
Originally Posted by tobindac View Post
massive 'green' artifact here on 64bit
though I don't see much use for the version yet since I always use SVP on top which is still 32bit.
GPU is an R9 290 latest stable drivers.
I figured this artifact appears with chroma upscaling set to NNEDI3.
tobindac is offline   Reply With Quote
Old 13th April 2015, 12:43   #28882  |  Link
Jtacdf
Nobody else gets that 'green image' artifact? Weird, I don't have any novel setup. Just an R9 290 on W8.1.
tobindac, are you using a crossfire setup as well with 14.12 driver? That green artifact comes from nnedi3 being enabled in a crossfire setup.
Everything works without issue if you turn off Xfire manually in CCC. Unfortunately, creating a specific 3d application setting to turn off Crossfire still causes it to appear.
Core i7 4790K@4.6Ghz - Asus Maximus VII Formula - AMD R9 290X 4GB Crossfire - Windows 10 Pro x64
Jtacdf is offline   Reply With Quote
Old 13th April 2015, 12:44   #28883  |  Link
tobindac
I deleted that message. I figured the artifact appears with NNEDI3 on chroma upscaling.
I don't have a Crossfire setup.
I never had one on this PC.
Old 13th April 2015, 12:50   #28884  |  Link
Jtacdf
That's pretty strange. Everything works fine for me running with 1 GPU. I'm using a 290x with 15.3 beta driver.
Are you using a AMD APU? From my limited understanding (since I'm using intel), AMD APU+GPU do have some form of crossfire as well.
Old 13th April 2015, 13:25   #28885  |  Link
StinDaWg
you sure? i would call this a bug.
It's not a bug, if your tv has proper 72/96hz playback it looks better than frame blending.
I could never stand madVR's implementation of smooth motion. I'd rather watch with judder than the loss of sharpness you get with frame blending.
StinDaWg is offline   Reply With Quote
Old 13th April 2015, 13:43   #28886  |  Link
Soukyuu
Soukyuu's Avatar
Great, now I can finally ditch that 32-bit player chain... once the wrinkles are ironed out.
Getting a white/cyan checkerboard pattern now and then instead of the video in windowed fullscreen (no overlay) and the mpc-hc x64 test build.
Also a crash on exiting said fullscreen mode (sent a report).
edit: There is sometimes a "fade to grey" on first subtitle line using latest xySubFilter beta x64. The screen just fades to a dark grey color while sound continues.
Disabling overlay or going fullscreen exclusive crashes on first subtitle line seemingly randomly.
AMD Phenom II X4 970BE | 12GB DDR3 | nVidia 260GTX | Arch Linux / Windows 10 x64 Pro (w/ calling home shut up)
Soukyuu is offline   Reply With Quote
Old 13th April 2015, 15:12   #28887  |  Link
madshi
madVR v0.87.21 released
http://madshi.net/madVR.zip
* fixed: (un)install.bat now works without having to manually "run as admin"
* fixed: active display wasn't properly set in the settings (x64)
* added workaround for window subclassing crash (x64)
Although the x64 crash seems to be gone now, I'd still like to encourage media player developers to implement "IMadVRSubclassReplacement", as MPC-HC has already done (thanks kasper93).
Old 13th April 2015, 15:39   #28888  |  Link
aufkrawall
I wonder when there will be the next surprise release, with Jinc downscaling, framerate conversion and 10 bit output.
Old 13th April 2015, 16:14   #28889  |  Link
SecurityBunny
Nvidia Geforce 350.12 driver seems to crash when going into windowed fullscreen mode. Using MPC-HC 1.7.8.156 (x64) & MadVR v0.87.21 (x64). Driver crash also occurs with version 350.05. Fullscreen playback seems to be fine with exclusive mode enabled.
Driver 347.88 is fine with both exclusive fullscreen and windowed fullscreen.
SecurityBunny is offline   Reply With Quote
Old 13th April 2015, 16:19   #28890  |  Link
nijiko
Hi-Fi Fans
64 now! Awesome!!!
nijiko is offline   Reply With Quote
Old 13th April 2015, 16:40   #28891  |  Link
cvrkuth
what display modes do you use and what operation system?
23 hz should be the right refreshrate for nearly 90% off all BD content. but if you haven't added this it should use this.
List of display modes: 1080p23, 1080p24, 1080p50, 1080p59, 1080p60
There was issue in the 32 bit version, v0.86.10. Madshi then do workaround and issue was gone.
I noticed that when playing 1080p24 (mkv, m2ts, ts .. full screen exclusive mode, default settings) my screen goes to 23hz. Because of this, there is a drop frames every 30-40 sec.
If I uncheck 'Present Several frames in advance "(old path), my screen stays in 24hz.
Intel Core i7-4790 CPU @ 3.60GHz, RAM 32 GB Dual-Channel DDR3 @ 665MHz (9-9-9-24),
Panasonic TX-P42G20E, NVIDIA GeForce GTX 970, Win 10 Pro x64,
PotPlayer 1.7.16291 64-bit, madVR v0.92.17
cvrkuth is offline   Reply With Quote
Old 13th April 2015, 16:53   #28892  |  Link
khanmein
x64 for mpc & lav filter stable with madvr?
khanmein is offline   Reply With Quote
Old 13th April 2015, 17:02   #28893  |  Link
the nvidia 349 branch added a serious issue with nnedi3. i'm going to test this later but i think is very unlikely that this issue is fix in this version. so it's maybe not a good idea to use this version with madVR.
Old 13th April 2015, 17:07   #28894  |  Link
SecurityBunny
As far as my testing has gone, x64 MPC-HC (1.7.8.156) with native lav filters works perfectly fine with x64 MadVR (0.87.21). Just the later nvidia display drivers (350.05 & 350.12) crash when going into windowed fullscreen. Also causing the video player to crash or report madvr direct x initialization failure. This behavior only occurs with windowed fullscreen, exclusive fullscreen seems to function just fine.
Downgrading nvidia driver to 347.88, both windowed and exclusive fullscreen function as intended with x64 versions.
Old 13th April 2015, 17:36   #28895  |  Link
ThurstonX
Thanks for the x64 build and fix :-)
I just tested a few files using the stable release of MPC-HC 1.7.8 x64, LAV as external filters, and the "MPC-HC has stopped working" error I was receiving with 0.87.20 when closing MPC-HC seems to be fixed with 0.87.21.
ThurstonX is offline   Reply With Quote
Old 13th April 2015, 18:12   #28896  |  Link
tobindac
R9 290 on latest stable drivers.
i7 cpu with disabled igpu.
Old 13th April 2015, 18:14   #28897  |  Link
obieobieobie
Symantec antivirus doesn't like mvrsettings32.dll in this new version (0.87.20+)
False positive?
obieobieobie is offline   Reply With Quote
Old 13th April 2015, 18:17   #28898  |  Link
tobindac
It still requires run as admin here. Win8.1.
Old 13th April 2015, 18:24   #28899  |  Link
madshi
No problems here with NNEDI3 chroma upsampling on my HD7770 on Windows 8.1. Probably a driver issue?
False positive?
Yes, of course. Please contact their customer support and complain. Loudly. Reporting a properly signed dll as a false positive is a sign of a very bad behaving anti-virus software. Seriously, you may want to consider changing to a better product.
Works for me. Is it working/failing for you other guys?
Old 13th April 2015, 18:44   #28900  |  Link
obieobieobie
Madshi, is the DLL packed?
I will report the false positive
