Old 21st July 2018, 09:30   #3101  |  Link
lansing
Originally Posted by HolyWu View Post
Then firstly try calling vspipe with full path to see whether the problem still exists.
"C:\Program Files (x86)\VapourSynth\core64\vspipe.exe" --y4m "bob.vpy" - | ffmpeg ...
Declaring the whole path works. So the problem should be vs pointing to the wrong vspipe environment path on installation.
Update: I found the path in the system variable. It is pointing to "C:\Program Files (x86)\VapourSynth\core32".
Update 2: I changed the path manually to the core64 folder and it worked. But then when I run the vs installer again, it won't add back the original core32 path to the system variable. Even if I remove the modified path->uninstall->reinstall, the installation won't add it back, this looks like a bug to me.
Old 21st July 2018, 13:26   #3102  |  Link
lansing
IIRC the vs installer never adds the path to system environment variable for the users. You must manually add it yourself.
Oh yes you're right, I double checked on another computer and the installation is not adding the environment variable either, so it must be me who added it long time ago.
Old 22nd July 2018, 16:28   #3103  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
VSRepo
You should all try out VSRepo now. As of test 9 it's more or less feature complete and only needs some additional testing.
If there's any plugin or script missing you think should be added simply request it in the linked thread.
IMPORTANT INFORMATION FOR PLUGIN/SCRIPT WRITERS:
If you host your stuff on GitHub new releases will be picked up automatically. Just remember to make official releases now and then (I'm looking at you, script writers) and that's it. If you choose to reject the light of GitHub then manual updates will be necessary. Fortunately very few of you have done so. Also post in the linked thread if a manual update is needed.
Myrsloik is online now   Reply With Quote
Old 25th July 2018, 15:38   #3104  |  Link
lansing
Just out of curiosity, does vapoursynth has an official logo/icon? I was using Simple x264 Launcher and in the "about" tabs, it has vapoursynth with a snake logo and I found it really funny.
Old 26th July 2018, 02:53   #3105  |  Link
poisondeathray
I don't have Simple x264 Launcher, can you post the logo somewhere? (google can't find the snake)
I was wondering the same thing a while back.
Here is my logo animation when I was testing some particle simulations. I was thinking coalescing "vapour"; that type of thing - but it ended up looking more like "smoke" ... smoke synth
https://s22.postimg.cc/6yo6xau9d/vapoursynth.gif
Old 26th July 2018, 03:59   #3106  |  Link
lansing
Old 26th July 2018, 04:17   #3107  |  Link
poisondeathray
maybe the cute green guy is supposed to be a scary "python" ?
Old 26th July 2018, 09:53   #3108  |  Link
LigH
LigH's Avatar
Quite probably a Python reference.
I could imagine a logo like a python appearing out of a steamy pot.
New German Gleitz board
Old 26th July 2018, 09:56   #3109  |  Link
Myrsloik
Myrsloik's Avatar
Definitely a Python logo from somewhere. There's no official logo but one with some sharks circling a film clip would be nice to have...
Old 26th July 2018, 10:48   #3110  |  Link
ChaosKing
Hold My Beer ...
https://imgur.com/a/APLomKn
I think a steampunk shark would be way cooler
Old 26th July 2018, 11:57   #3111  |  Link
LigH
LigH's Avatar
Damn. Now I wasted hours making a vapoured Python logo (and then Mozilla browsers don't even render it transparently).
Why sharks?
Old 26th July 2018, 12:04   #3112  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by LigH View Post
Damn. Now I wasted hours making a vapoured Python logo.
Why sharks?
I don't know, it was just a throwaway idea I had long ago. A python squeezing a movie clip would be fun too.
Old 26th July 2018, 12:34   #3113  |  Link
LigH
LigH's Avatar
How about that: The Python double-snake logo being a "film clip"...
Old 26th July 2018, 15:54   #3114  |  Link
fAy01
https://www.pixiv.net/member_illust....st_id=66229306
- need to ask for permission if used.
fAy01 is offline   Reply With Quote
Old 26th July 2018, 20:03   #3115  |  Link
Myrsloik
Myrsloik's Avatar
I like this one. Give me an icon version and I'll make it the default icon for vpy files.
Old 26th July 2018, 20:40   #3116  |  Link
LigH
LigH's Avatar
I hope this ICO file is sufficient. It contains 32×32 and 48×48 icons with 256 and high colors (XP compatible), and 256×256 high colors with PNG compression for Vista+.
Old 26th July 2018, 21:37   #3117  |  Link
lansing
I think the shape looks weird, it would be better to be shaped as a square or a circle for an icon. For example, the original python logo is a circle.
Old 26th July 2018, 21:48   #3118  |  Link
poisondeathray
I'm not a fan of the "pink" film color either, or the translucency color combo where the "yellow" python looks "orange-ish?" behind the film
When viewing small icons, you lose sight and obscure part of the python logo (or at least the yellow python; blue guy is still visible), so the idea of "wrapping" around a film is not as clear either. Maybe a more transparent value , lighter gray shade for the film ?
Old 26th July 2018, 22:23   #3119  |  Link
LigH
LigH's Avatar
@lansing: Icons are always squares; you may not notice that when they have transparency. But gradual transparency only works in high color modes for icons. And circles are hard to create with low resolutions, may look frayed out, as you see in the samples above (binary transparency, 256 color palette icons).
@poisondeathray: Yes, the strip color is not so fortunate, it is the original from a free clipart; I may change that to a neutral gray, or you won't recognize the yellow well. Soon...
Old 26th July 2018, 23:30   #3120  |  Link
Are_
Can you make a svg version of it too?
Are_ is offline   Reply With Quote
speed, vaporware, vapoursynth
