18th June 2013, 15:20 | #12341 | Link | |
SuperVirus
http://forum.doom9.org/showthread.ph...14#post1631214 |
20th June 2013, 02:17 | #12342 | Link |
Question about adjusting individual channels...
Hey everyone,
Is there a way to adjust individual channel levels in eac3to when changing formats? I would like to take an HDAudio source and modify the individual channel levels prior to converting to/writing a .w64 file. Thanks for your help, JSS |
22nd June 2013, 13:48 | #12346 | Link | |
French Love
Hello all,
What are all the extensions supported by eac3to ? I know that one Quote:
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial Demo for MVC Player Free: Trailer 3D 3DBD's Free - v0.0.0.0005.exe Old Programing free for all. |
22nd June 2013, 19:25 | #12347 | Link |
eac3to can output:
Video: .h264 .vc1 .m2v (all can be muxed to .mkv with Haali) Uncompressed audio (extract or decode): .wav (.wavs) .w64 .rf64 .pcm .raw Compressed audio (extract or encode): .ac3 .flac .dts (encode with SurCode) .m4a (aac audio in mp4 container encoded with NeroAacEnc) Other compressed audio (only extract): .eac3 .thd (.thd+ac3) .dtshd .aac .mp2 .mp3 Subtitles: .sup .srt .ass .ssa Chapters: .txt
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 22nd June 2013 at 19:27. |
23rd June 2013, 22:45 | #12348 | Link |
French Love
Already thank you very much for the reply
By cons I think it is missing, I just found one. Mpeg2 and it seems there are other ... Madshi, could you provide a list of standard format demux function in eac3to -help
24th June 2013, 00:49 | #12349 | Link | |
MPEG2 video -> .m2v MPEG2 audio -> .mp2 .mp3 (maybe .mp1 but I don't found any sample to test)
24th June 2013, 05:20 | #12350 | Link |
French Love
Thanks tebasuna51,
It's strange, works same MPEG2 video -> .m2v and .mpeg2 Why ? What's missing here and what's wrong here for extract only ? ( -demux) Code:
Keyword eac3to demux .extension ** VC-1 = .vc1 ** h264/AVC = .h264 ** MPEG2 = .m2v works with .mpeg2 ** AC3 = .ac3 ** E-AC3 = .eac3 ** AC3 Surround = .ac3 ** TrueHD = .thd ** TrueHD/AC3 = .thd+ac3 ** DTS = .dts ** DTS Master Audio = .dtsma ** DTS Hi-Res = .dtshr ** DTS-HD (no core) = .dtsnc ** DTS Express = .dtslbr ** FLAC = .flac ** RAW/PCM = .pcm ** MLP = .mlp ** WAV = .wav ** W64 = .w64 ** RF64 = .rf64 ** DTSWAV = .dtswav ** AC3WAV = .ac3wav ** AAC = .aac ** MP1 = .mp1 ** MP2 = .mp2 ** MP3 = .mp3 ** (PGS) = .sup ** (DVD) = .sup ** (SRT) = .srt ** (ASS) = .ass ** (SSA) = .ssa ** (VobSub) = ?
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial Demo for MVC Player Free: Trailer 3D 3DBD's Free - v0.0.0.0005.exe Old Programing free for all. Last edited by frencher; 25th June 2013 at 05:32. |
24th June 2013, 08:29 | #12351 | Link |
Depending on your purpose, you may want to support '.wavs' too (demultiplexes/decodes and de-interleaves a multi-channel audio stream to separate mono .wav files per audio channel).
VobSub consists of .sub (RLE-encoded DVD subpicture stream) + .idx (timecode and stream information text file). |
24th June 2013, 11:36 | #12352 | Link | |
The format of the file is defined in the file header. For instance you can use .dts for all of this: Code:
** DTS = .dts ** DTS Master Audio = .dts ** DTS Hi-Res = .dts ** DTS Express = .dts To extract the core of a dtshd you need add the -core parameter, if you put only the extension .dts, without -core, you obtain a dtshd. BTW, DTS-HD (no core) don't exist, a dtshd must have always a core. - .pcm and .raw have the same audio data but with different byte and channel order. A .raw is exact to a .wav/.w64/.rf64 without header. - Graphic subtitles. Only (PGS) = .sup is usefull With (DVD), subs from VOB container, the .sup extracted is not supported by mkvmerge to mux or subrip/suprip/subtitleedit to convert to text subtitles. If you want convert to text subs better use subrip/subtitleedit directly from VOB files. BTW the .sup extracted by eac3to (or PgcDemux) can be used, with the .IFO file from DVD structure, by BDsup2sub to obtain the graphic subtitles sub/idx accepted by MkvMerge. But there are other tools to extract sub/idx directly from VOB's The (VobSub), subs sub/idx in mkv container, aren't supported by eac3to to extract. Use MkvExtract instead. EDIT: Code:
** DTSWAV = .dtswav ** AC3WAV = .ac3wav Some times (not always) are supported like input to extract the .dts/.ac3 included in the fake wav container.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 24th June 2013 at 12:29. |
24th June 2013, 19:41 | #12353 | Link |
SuperVirus
Only if one wants/needs compliance with the Blu-Ray specifications. In the so-called "Digital Delivery" mode, the Master Audio Encoder Suite can output a pure lossless stream, but only for certain channel layouts (2.0, 5.1 and 7.1).
24th June 2013, 20:25 | #12354 | Link |
Even on Blu-ray you have DTS-HD streams without core, the so called DTS Express uses a low-bitrate HD stream without core to be able to produce a VBR stream with low bitrate for mostly voice (commentary tracks)
25th June 2013, 05:43 | #12355 | Link |
French Love
OK Thank's all
If update or error(s) send me update Code:
## Video ** VC-1 = .vc1 ** h264/AVC = .h264 ** MPEG1 = .mpeg1 ** MPEG2 = .m2v ** MS/VFW/FOURCC/XVID = .xvid ## Audio ** AC3 = .ac3 ** E-AC3 = .eac3 ** AC3 Surround = .ac3 ** TrueHD = .thd ** TrueHD/AC3 = .thd+ac3 ** DTS = .dts ** DTS Master Audio = .dts ** DTS Hi-Res = .dts ** DTS-HD (no core) = .dts ** DTS Express = .dts ** FLAC = .flac ** RAW/PCM = .pcm ** MLP = .mlp ** WAV = .wav ** W64 = .w64 ** RF64 = .rf64 ** DTSWAV = .dtswav ** AC3WAV = .ac3wav ** AAC = .aac ** MP1 = .mp1 ** MP2 = .mp2 ** MP3 = .mp3 ## Subtitles ** (PGS) = .sup ** (DVD) = .sup ** (SRT) = .srt ** (ASS) = .ass ** (SSA) = .ssa ** (VobSub) = .sup
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial Demo for MVC Player Free: Trailer 3D 3DBD's Free - v0.0.0.0005.exe Old Programing free for all. Last edited by frencher; 25th June 2013 at 06:03. |
25th June 2013, 09:06 | #12356 | Link | ||
- If this stream can be muxed in any container and extracted by eac3to. - If eac3to can decode this stream. Quote:
BTW, DTS Express was already listed. ** MPEG1 = .mpeg1 I don't know, never tested. ** MS/VFW/FOURCC/XVID = eac3to can't open avi container and can't extract this stream if present in mkv container. ** AC3 Surround = .ac3 Is a particular case of standard AC3, if you list this item separately seems you suggest than eac3to can apply a DPL decoder and is not true. ** DTS-HD (no core) = .dts I don't know, never tested. ** RAW/PCM = .pcm/.raw Both formats useless, must be extracted like .wav/.w64/.rf64 ** DTSWAV = .dts eac3to can't output .dtswav, only can convert DTSWAV to .dts ** AC3WAV = .ac3 eac3to can't output .ac3wav, only can convert AC3WAV to .ac3 ** MP1 = .mp1 I don't know, never tested. ** (VobSub) = eac3to can't extract this kind of sub.
25th June 2013, 14:13 | #12357 | Link | |||
SuperVirus
BTW, neither mkvmerge nor LAV Splitter support A_DTS/LOSSLESS thus far. Besides, http://matroska.org/technical/specs/codecid/index.html says: Quote:
http://lists.matroska.org/pipermail/...ne/004051.html Last edited by filler56789; 25th June 2013 at 14:37. Reason: yet another link |
26th June 2013, 10:33 | #12358 | Link |
I recently tried converting an HD-DVD with TrueHD audio to Bluray format using first ClownBD 0.81 and then eac3to 3.27, but each software insists on decoding and re-encoding the AC3 core of the TrueHD track.
Does anyone know why this might be occurring and how to stop it happening? |
26th June 2013, 12:05 | #12359 | Link | |
26th June 2013, 15:34 | #12360 | Link | |
A number of HD-DVD have better video and/or audio than the equivalent Bluray, still, and since I no longer have an HD-DVD player it's good to be able to get them into a playable format again. |
eac3to |
